skan błędu kolejny raz
może ktoś powiedzieć z czego wynikają te błędy i czy jest coś groźnego w nich co by mogło niepokoić?
VCDS Version: Release 10.6.0
Data version: 20100630
Sunday,27,January,2013,13:31:59:46862
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E45A012412 Mileage: 203520km/126461miles
Address 01: Engine Labels: 03G-906-016-BKE.lbl
Part No SW: 03G 906 016 CJ HW: 028 101 188 7
Component: R4 1,9L EDC G000SG 6413
Revision: 12345678 Serial number: AUZ6Z0D0155243
Coding: 0000071
Shop #: WSC 06435 000 00000
VCID: 6DDACBEA4BCBE874
2 Faults Found
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 230.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.48 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 1.0
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001100
Torque: 162.0 Nm
Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2A5000F6BAA53F4C
1 Fault Found
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63351
VCID: 356A238A631B60B4
1 Fault Found
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 3E783CA6562DA3EC
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 03041
Shop #: WSC 00000
VCID: 4182475A27D3DC14
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00101
Shop #: WSC 01333
VCID: 2E580CE6864D536C
WAUZZZ8E45A012412 AUZ6Z0D0155243
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 T HW: 8E0 035 192 T
Component: RNS-E HIGH EU H76 0750
Revision: 07S Serial number: AUZBZ7H1124722
Coding: 0301711
Shop #: WSC 00000 000 00000
5 Faults Found
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 177
Time Indication: 0
Date: 2003.08.01
Time: 00:00:22
Freeze Frame:
Mileage: 655350 km
Count: 108
Clock: 00:00
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Time Indication: 0
Date: 2013.01.25
Time: 22:00:35
Freeze Frame:
Mileage: 655350 km
Count: 2501
Clock: 22:00
00879 - Connection to Speaker Front Right
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 170
Time Indication: 0
Date: 2013.01.26
Time: 10:27:04
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Date: 2003.08.01
Time: 00:06:51
Freeze Frame:
Bin. Bits: 0000
Mileage: 655350 km
Count: 2601
Clock: 22:12
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 126
Time Indication: 0
Date: 2013.01.25
Time: 22:00:25
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AR
Component: Komfortgerát T85 1512
Coding: 06720
Shop #: WSC 63351
VCID: 8102075AE7539C14
Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 0205
Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0205
1 Fault Found
00957 - Key 3
35-00 - -
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301711
5 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 177
Time Indication: 0
Date: 2003.08.01
Time: 00:00:22
Freeze Frame:
Mileage: 655350 km
Count: 108
Clock: 00:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Time Indication: 0
Date: 2013.01.25
Time: 22:00:35
Freeze Frame:
Mileage: 655350 km
Count: 2501
Clock: 22:00
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 170
Time Indication: 0
Date: 2013.01.26
Time: 10:27:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Date: 2003.08.01
Time: 00:06:51
Freeze Frame:
Bin. Bits: 0000
Mileage: 655350 km
Count: 2601
Clock: 22:12
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 126
Time Indication: 0
Date: 2013.01.25
Time: 22:00:25
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005094468
Coding: 0011622
Shop #: WSC 06335 000 00000
VCID: 3B7E35B2453FB6C4
End ---------------------------------------------------------------------
ok dzięki
---------- Post dopisany at 19:00 ---------- Poprzedni post napisany at 18:50 ----------
to wyszło ale nie wiem gdzie szukać przyczyny:
-Jazdy autobusem danych, brak wiadomości z centralkę ABS
-Siłownik do klapy przepływu powietrza
-Magistrala danych, brak wiadomości od elektroniki kolumny kierownicy
-Magistrala danych uszkodzony
-Antena, radia
-Połączenie między IF wyjście wzmacniacza anteny radiowej
-Połączenia do prawego głośnika
-Sterowanie hamulca
-Jednostka sterująca błędnie zakodowana
-Key 3
Wszystkie te błedy masz opisane na FORUM wystarczy poszukac i przeczytać
Pierwsze zacznij od poprawnego kodowania RNS E i sprawdzenia z tyłu anteny czy jest podpieta oraz okablowania bo cos nie łaczy głosnik .
:arrow2::arrow2::arrow2:http://a4-klub.pl/warsztat-zrob-to-26/all-rns-e-7428/index88.html
Zle zakodowany kluczyk w KOMFORCIE 46
:arrow2::arrow2::arrow2:http://a4-klub.pl/audi-a4-b6-b7-132/all-b6-dopasowanie-pilotow-centralnego-zamka-alarmu-60091/index10.html
W klimie 08 masz bład silniczka , tematy do poczytania i wszystko bedzie jasne :wink:
:arrow2::arrow2::arrow2:http://a4-klub.pl/klimatyzacja-98/all-b6-ktos-posiada-rysunek-silnikow-klap-157853/
:arrow2::arrow2::arrow2:http://a4-klub.pl/klimatyzacja-98/all-b6-klimatyzacja-dwustrefowa-prawa-strona-chlodzi-ani-grzeje-115305/
Bledy w ABS 03 oraz silnik 01 jest zwiazany z okablowaniem lub tez ze słabego AKU (
ok dzięki 03 i 01 jest związany pewnie z aku bo wczoraj mi pierwszy raz padł więc na weekend podładowałem i w poniedzialek najprawdopodobniej wymiana
