skan błędów w a4 b6 kolegi
Prosiłbym o pomoc co jest tutaj nie tak? Może być coś z centralnym zamkiem nie tak bo pol roku temu byla proba kradzieży tego auta
VCDS Version: Release 10.6.0
Data version: 20100630
Thursday,31,January,2013,13:03:19:46862
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E65A001976 Mileage: 192650km/119707miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 5934
Coding: 00002
Shop #: WSC 63251
VCID: 6AD0C0F67A25FF4C
WAUZZZ8E65A001976 AUZ6Z0D0222087
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04255
Shop #: WSC 06435
VCID: E5CA33CA133B5034
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1324
Coding: 00000
Shop #: WSC 63251
VCID: 60C4A2DE8C19B51C
1 Fault Found
01809 - Actuating Motor for Temperature Flap; Left (V158)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00011
Shop #: WSC 63251
VCID: 356A238A631B60B4
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251 000 00000
VCID: 3E783CA6562DA3EC
1 Fault Found
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01042
Shop #: WSC 63251
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00101
Shop #: WSC 03570
VCID: 2E580CE6864D536C
2 Faults Found
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01304 - Radio
49-00 - No Communications
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
VCID: EBDE45F2F5DF6644
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1412
Coding: 06986
Shop #: WSC 63251
VCID: 73EEDD922DEF3E84
Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 0204
Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0204
Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 1204
Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 1204
3 Faults Found
01134 - Alarm Horn (H12)
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
01562 - Right Rear Door
61-10 - Won't De-Safe - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63251
VCID: 040C8E4E7841093C
End ---------------------------------------------------------------------
Błąd 1039 z grupy 17 to problem z czujnikiem temperatury cieczy chłodzącej. Prawdopodobnie do wymiany, ale można to jeszcze sprawdzić.
Jeśli chodzi o błąd 1562 w grupie 46 to być może jakiś problem w mikrostyku drzwi prawych tylnych. Czy ten błąd po skasowaniu powraca za każdym razem? U mnie pojawia się sporadycznie taki błąd tylko że w drzwiach lewych (1561). Nic z tym nie robię, gdyż nie mam żadnego problemu np z centralnym, na wyświetlaczu normalnie sygnalizuje mi otwarcie/zamknięcie drzwi, więc jak na razie się nie przejmuję:wink:
kolega tez nie ma problemu z centralnym,a co do czujnika to mówił że źle mu na liczniku temperature wskazuje, a co to za bledy w grupie 8 i 15 coś poważnego czy też jakaś błahostka
Troszeczkę wyjaśnień poniżej, ale co dokładnie, te błędy z grup 8 i 15 oznaczają w praktyce niech określą bardziej doświadczeni koledzy:
Błąd 01809
Błąd 01217
ok to niech się ktoś bardziej doświadczony wypowie ale dzięki za info
