Liczne błędy komunikacji w wielu sterownikach
Witam,
Po odpaleniu auta pojawił się problem z kilkoma podzespołami m.in. czujniki parkowania, klimatyzacja, kierownica multifunkcyjna, brak kierunkowskazów itd. Po podłączeniu VCDS wyskoczyła długa lista błędów
Saturday,13,April,2013,19:26:58:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
         69 75 76 77
VIN: WAUZZZ8EX8A012421   Mileage: 226750km/140895miles
Address 01: Engine        Labels: Redir Fail!
  Part No SW: 03G 906 018 AQ    HW: 03G 906 018 AQ
  Component: R4 2.0l PPD1.3 G    9971
  Revision: --H43---    Serial number: XXXXXXXXXXXXXX
  Coding: 0000072
  Shop #: WSC 66565 257 00032
  VCID: 74E3D8E36C7B
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 8E0-910-517.lbl
  Part No SW: 8E0 910 517 H    HW: 8E0 614 517 BF
  Component: ESP8 FRONT      H06 0140
  Revision: 00000000    Serial number: 00000000000000
  Coding: 0004405
  Shop #: WSC 06335 000 00000
  VCID: 2C530083F4CB
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
  Part No: 8E0 820 043 BM
  Component:   A4 Klimaautomat   3233
  Coding: 00001
  Shop #: WSC 06335
  VCID: 6DD5CD870F51
10 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
           41-10 - Blocked or No Voltage - Intermittent
01317 - Control Module in Instrument Cluster (J285)
           49-10 - No Communications - Intermittent
01330 - Central Control Module for Central Convenience (J393)
00466 - Control Module for Steering Column Electronics (J527)
00457 - Control Module for Network (J519)
00474 - Control Module for Immobilizer
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
  Part No: 8E0 907 279 N
  Component: int. Lastmodul  ECE 0907
  Coding: 11021
  Shop #: WSC 00000
  VCID: 3D753DC71FB1
8 Faults Found:
00526 - Brake Light Switch-F
           27-10 - Implausible Signal - Intermittent
01326 - Control Module for Multi-Function Steering Wheel (J453)
           79-10 - Please Check Fault Codes - Intermittent
01312 - Powertrain Data Bus
01320 - Control Module for Climatronic (J255)
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
  Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
  Component:    Airbag 9.41  H14 4230
  Revision: 91H14423    Serial number: 0036M0G8NLKX
  Coding: 0030612
  VCID: 3B7133DF01A5
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
  Part No: 8E0 953 549 Q
  Component: Lenksáulenmodul     0701
  Coding: 03042
  Shop #: WSC 06335
  VCID: 418D41376349
1 Fault Found:
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
  Part No SW: 8E0 920 932     HW: 8E0 920 932
  Component: KOMBI+WFS 4     H10 0200
  Revision: 0200        Serial number: 00000000000000
  Coding: 0006108
  Shop #: WSC 00530 259 82210
  VCID: E6C732ABAAA7
8 Faults Found:
           004 - No Signal/Communication - Intermittent
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
  Part No SW: 8E0 035 192 Q    HW: 8E0 035 192 Q
  Component: RNS-E HIGH EU   H74 0760
  Revision:      04S    Serial number: AUZBZ7G1130203
  Coding: 0301717
  VCID: 326F1EFBD6EF
4 Faults Found:
00857 - CD Changer Unit (R41)
            Freeze Frame:
                   Fault Status: 01100100
                   Fault Priority: 5
                   Fault Frequency: 1
                   Reset counter: 121
                   Time Indication: 0
                   Date: 2012.10.31
                   Time: 20:59:54
            Freeze Frame:
                   Fault Status: 00100100
                   Fault Priority: 5
                   Fault Frequency: 11
                   Reset counter: 34
                   Time Indication: 0
                   Date: 2013.04.13
                   Time: 19:02:08
           008 - Implausible Signal - Intermittent
            Freeze Frame:
                   Fault Status: 00101000
                   Fault Priority: 5
                   Fault Frequency: 7
                   Reset counter: 33
                   Time Indication: 0
                   Date: 2013.04.13
                   Time: 19:02:03
01316 - ABS Control Module
            Freeze Frame:
                   Fault Priority: 5
                   Fault Frequency: 1
                   Reset counter: 33
                   Time Indication: 0
                   Date: 2013.04.13
                   Time: 19:10:30
            Freeze Frame:
                   Bin. Bits:     0000
                   Mileage: 655350 km
                   Count: 1304
                   Clock: 19:10
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
  Part No: 8E0 951 177
  Component: Innenraumueberw.   0804
  Coding: 00001
  Shop #: WSC 00000
  VCID: EBD1439FB145
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
  Part No: 8E0 959 433 CQ
  Component: Komfortgerát T3B    4236
  Coding: 07038
  Shop #: WSC 06335
  VCID: 820F0E3BA6CF
  Subsystem 1 - Part No: 8E1959801H
  Component: Tőrsteuer.FS BRM 0606
  Subsystem 2 - Part No: 8E1959802H
  Component: Tőrsteuer.BF BRM 0606
  Subsystem 3 - Part No: 8E0959801E
  Component: Tőrsteuer.HL BRM 0606
  Subsystem 4 - Part No: 8E0959802E
  Component: Tőrsteuer.HR BRM 0606
13 Faults Found:
           49-00 - No Communications
01336 - Data Bus for Comfort System
           37-00 - Faulty
Address 55: Xenon Range        Labels: 8P0-907-357.lbl
  Part No: 8P0 907 357 F
  Component: Dynamische LWR  H02 0010
  Revision: 00000001    Serial number:
  Coding: 0000005
  VCID: 3D753DC71FB1
Auto ogólnie wariuje i po skasowania błędów nadal instrumenty nie działają jak trzeba. Dodam, że auto dzisiaj myłem myjką, może zalałem jakiś sterownik...
Witam,
Podpinam się pod temat, moje auto po odebraniu od polerki fiksuje, też mi się wydaje że po myciu myjką. Objawy to miganie podświetlania zegarów, climatronica, podświetlania przycisków, migajaca lampka od świateł, kontrola trakcji świeci, brak światła wstecznego, nie działa tempomat i przełączanie komputera manetką, sterowanie w kierownicy, szyby chodzą ale zacinają się przy opuszczaniu czy podnoszeniu, centralny nie działa, climatronic warjuje włącza się i wyłącza, kontrolka od fotochroma miga, kierunki działają ale nie pokazuje na zegarach migania strzałek i nie klika, jeszcze jest takie "pstrykanie" tak jakby przekaźnik świrował w okolicach kolumny kierowniczej z lewej strony. Co najlepsze rano jade do pracy i wszystko działa normalnie a jak wracam to juz nie i tak w kółko od tygodnia. Błędy jakie mam to 00457 18043 18104 01330 01331 01332 01333 01334 00466 01320 01336. Jakieś sugestie macie Panowie? Może to coś z MCE?
---------- Post dopisany 20-05-2014 at 09:30 ---------- Poprzedni post napisany 12-05-2014 at 11:44 ----------
Pstrykanie dochodzi z przkekaźnika nr 370 zaznaczonego na zdjęciu, wymieniłem go i nic, wymieniłem MCE 8E0 907 279 F i też nie pomogło. Wie ktoś od czego jest ten przekaźnik? Dodam że strasznie się grzeje. Licznik i reszta co opisywałem wyżej fiksuje ale np w tej chwili jest dobrze. Jak miga kontrolka świateł i je wyłącze to przekaźnik "cyka", świeci się też kontrolka od trakcji. Vag Com nie łączy się z niczym tylko takim testerem znajomy mi błędy odczytał 01314 01316 00457 01330 01331 01332 01333 01334 00466 01320 01826 18265 18043 18104. Nie wiem czy nie odstawić do elektroników...
Po deszczach mój samochód zwariował, dzieje się coś takiego:
Jak zdiagnozować usterkę ? dziękuję za wszystkie wskazówki.
Samochód:
Audi a4 b6 avant 2002, 1.9 tdi, 130 KM
