[B5 ARG] Prośba o analizę logów
Witajcie chłopaki wkońcu to zrobiłem, wiem że z autem jest coś nie tak: przepływka albo może jeszcze coś gorszego.
Tak dla pewności wrzucam logi:
Auto to: 1.8 B5 z 95roku
Saturday 12 July 2008 20:23:59
8D0 907 557 C 1.8L R4/5V MOTR HS D07
Group A: '008
Time Lambda Lambda
TIME
MARKER STAMP ms % %
0.38 1.46 7 0.8 TankVent OFF
1.52 12.13 6.3 0.8 TankVent ON
2.69 12.73 5.5 0.8 TankVent ON
3.82 13.5 4.7 0.8 TankVent ON
4.99 12.64 3.9 0.8 TankVent OFF
6.13 13.5 3.1 0.8 TankVent OFF
7.28 14.71 3.1 0.8 TankVent ON
8.44 15.39 3.1 0.8 TankVent ON
9.63 16.68 2.3 0.8 TankVent ON
10.78 16.68 2.3 0.8 TankVent ON
11.96 16.86 2.3 0.8 TankVent ON
13.13 15.65 2.3 0.8 TankVent ON
14.28 14.36 1.6 0.8 TankVent OFF
15.42 13.93 1.6 0.8 TankVent OFF
16.56 13.33 1.6 0.8 TankVent OFF
Group B: '011
Engine Coolant Intake Air Ignition
TIME Speed Temperature Temperature Timing
STAMP /min ms km/h l/h
0.77 1520 5.4 27.5 6.16
1.9 1640 5.7 28.6 8.54
3.07 1880 5.9 35.2 9.24
4.21 2160 6.2 38.5 11.62
5.36 2440 6.45 45.1 11.34
6.51 2720 6.8 48.4 13.58
7.68 3000 7.35 56.1 16.24
8.86 3280 8 60.5 19.04
10.01 3600 8.5 69.3 22.4
11.18 3840 8.4 71.5 24.5
12.33 4080 8.2 79.2 25.9
13.53 4280 7.6 81.4 23.52
14.67 4480 7.2 88 23.38
15.8 4640 6.95 89.1 24.08
16.92 4760 6.6 92.4 23.1
Group C: '003
Engine Air Throttle Ignition
TIME Speed Mass Flow Angle Timing
STAMP /min V °C °C
0.01 1400 13.94 73.5 19.5
1.15 1480 13.872 73.5 19.5
2.3 1720 13.872 73.5 19.5
3.44 2000 13.872 73.5 19.5
4.61 2240 13.872 73.5 19.5
5.74 2520 13.804 73.5 19.5
6.89 2800 13.872 73.5 19.5
8.06 3080 13.872 73.5 19.5
9.24 3400 13.804 73.5 19.5
10.4 3680 13.736 73.5 19.5
11.58 3920 13.804 73.5 19.5
12.73 4160 13.872 73.5 19.5
13.92 4360 13.872 73.5 19.5
15.04 4520 13.804 73.5 19.5
16.17 4680 13.804 73.5 19.5
I Statyczne:
Group A: '014
Engine Engine Misfire Misfire
TIME Speed Load Sum Counter Recog
MARKER STAMP /min ms ° °
0.01 840 1.4 0 0
0.77 880 1.4 0 0
1.52 880 1.4 0 0
2.27 840 1.4 0 0
3.04 840 1.4 0 0
3.81 840 1.4 0 0
4.56 800 1.4 0 0
5.31 800 1.4 0 0
6.09 840 1.4 0 0
6.86 840 1.4 0 0
7.63 840 1.4 0 0
8.4 800 1.4 0 0
Group B: '018
Lowest Engine Highest Engine Lowest Engine Highest Engine
TIME Speed @ Misfire Speed @ Misfire Load @ Misfire Load @ Misfire
STAMP /min ms ms %
0.38 800 1.4 2.25 -29.7
1.13 840 1.4 2.35 -29.7
1.89 840 1.4 2.35 -29.7
2.65 840 1.4 2.35 -29.7
3.42 840 1.4 2.35 -29.7
4.19 880 1.4 2.3 -29.7
4.94 840 1.4 2.35 -29.7
5.7 880 1.4 2.25 -29.7
6.48 880 1.4 2.3 -29.7
7.24 880 1.4 2.25 -29.7
8.01 880 1.4 2.3 -29.7
8.78 880 1.4 2.25 -29.7
Group A: '004
Engine Battery Coolant Intake Air
TIME Speed Voltage Temperature Temperature
MARKER STAMP ° g/s g/s
0.51 10.4 1.71 0 Idle
1.65 10.9 1.71 0 Idle
2.8 10.4 1.71 0 Idle
3.95 10.4 1.71 0 Idle
5.12 10.4 1.71 0 Idle
6.27 10 1.71 0 Idle
7.41 10 1.71 0 Idle
8.58 9.5 1.71 0 Idle
9.71 9.5 1.71 0 Idle
10.85 9.5 1.71 0 Idle
12.02 9.1 1.71 0 Idle
Group B: '007
Lambda Voltage Duty Cycle (no units)
TIME
STAMP % V %
0.9 -18.8 0.925 0 1
2.03 -21.1 0.92 0 1
3.2 -24.2 0.92 0 1
4.35 -25 0.915 0 1
5.5 -25 0.92 0 1
6.66 -25 0.915 0 1
7.79 -25 0.91 0 1
8.96 -25 0.91 0 1
10.08 -25 0.905 0 1
11.23 -25 0.905 0 1
12.4 -25 0.9 0 1
Group A: '000
TIME
STAMP
0.3 170 41 87 199 26 150 140 128 251 129
1.4 170 40 86 200 26 150 140 132 251 129
2.48 170 40 86 199 25 150 140 118 251 129
3.58 170 40 87 200 26 150 140 137 251 129
Group B: '001
Engine Coolant O2 Sensor Adjustment
TIME Speed Temperature Control Conditions
STAMP /min ms ° °BTDC
0.68 840 2.05 11.3 12
1.77 840 2 11.3 12
2.86 840 2 10.9 12
3.96 840 2 10.9 12
5.05 840 2 10.9 12
W trybie basic:
Group: 000
TIME
STAMP
0.28 182 27 87 201 20 142 140 255 2 129
0.62 182 27 89 200 20 142 140 255 2 129
0.95 182 27 86 199 20 142 140 255 2 129
1.31 182 27 86 200 20 142 140 255 2 129
Group A: '003
STAMP /min V °C °C
0.01 840 13.6 88.5 19.5
0.38 840 13.668 88.5 19.5
0.76 840 13.668 88.5 19.5
1.15 840 13.668 88.5 19.5
1.51 880 13.6 88.5 19.5
1.9 840 13.532 88.5 19.5
2.28 840 13.668 88.5 19.5
2.67 840 13.668 88.5 19.5
Group A: '004
STAMP ° g/s g/s
0.01 8.2 1.71 0 Idle
0.37 8.2 1.71 0 Idle
0.75 8.2 1.71 0 Idle
1.13 8.2 1.71 0 Idle
1.53 8.2 1.71 0 Idle
1.92 8.2 1.71 0 Idle
2.29 8.7 1.71 0 Idle
Mam nadzieje ze za duzo tego nie dalem na raz ;/
Good Luck ;/[br]Dopisany: 12 Lipiec 2008, 21:59 _________________________________________________A jeszcze dodam że: obroty skacza na niskach obrotach.
Samochod benzyna z 250tys zrobione.
Czasami sie dusi jak chce sie szybko ruszyc:) Ja mu gaz do dechy a tu jakis dziadek by mnie na rowerkow wypszedzil;/ noga z gazu po czym powoli gaz i jest ok;/ :thumbdown:[br]Dopisany: 12 Lipiec 2008, 22:03 _________________________________________________A jeszcze cos takiego mialem w bledach od silnika, ale po usunieciu ich nie pojawily sie ponownie:
5 DTCs Found:
00515 - Camshaft Position Sensor (G40)
29-10 - Short to Ground - Intermittent
17978 - Engine Control Module Blocked by Immobilizer
35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
16514 - O2S B1 S1: Ciruit Failure
00561 - Fuel Mixture Adjustment
15-10 - Adaptation Limit (Add) Not Reached - Intermittent
Żeby ocenić przepływkę zrób dynamicznie 002, w 007 widać że przelewa mieszankę stąd 00561. Rozumiem z opisu, że auto niema LPG?
Wielkie dzięki za info: Auto nie ma LPG.
Jutro zrobię jeszcze te pomiary 002, 007 jeszcze.[br]Dopisany: 13 Lipiec 2008, 00:28 _________________________________________________Wrzucam grupę 002 i 007
Group A: '002
Engine Engine Fuel Injectors Air
TIME Speed Load Average Time Mass Flow
MARKER STAMP /min ms ms g/s
0.5 1480 6.15 13.93 28.12
0.89 1560 6.25 13.59 31.59
1.27 1600 6.3 13.5 33.12
1.66 1680 6.35 13.5 32.64
2.04 1720 6.5 13.76 29.79
2.42 1760 6.5 13.59 32.29
2.81 1800 6.55 13.5 30.69
3.18 1880 6.6 13.5 31.94
3.56 1920 6.65 13.5 31.81
3.94 1960 6.7 13.59 32.78
4.33 2040 6.8 13.76 30.9
4.71 2080 6.85 13.67 33.06
5.1 2160 6.9 13.76 35.56
5.48 2200 7 13.93 34.51
5.86 2240 7 13.93 34.93
6.25 2320 7.05 14.02 39.65
6.62 2360 7.15 14.36 42.98
7.02 2400 7.2 14.45 45.21
7.4 2480 7.3 14.79 45.69
7.78 2520 7.35 14.88 44.65
8.17 2600 7.45 15.65 44.93
8.54 2640 7.55 15.31 47.08
8.92 2720 7.6 15.39 46.67
9.29 2760 7.75 15.82 49.03
9.66 2800 7.85 15.91 50.21
10.06 2880 8 16.34 51.73
10.44 2920 8 16.25 51.67
10.82 3000 8 16.25 52.01
11.19 3040 8 16.25 54.31
11.58 3080 8.05 16.17 53.96
11.96 3120 8.1 16.25 56.18
12.34 3200 8.35 16.68 59.17
12.73 3240 8.6 17.2 62.64
13.11 3280 8.75 17.72 62.71
13.51 3360 8.85 17.46 64.86
13.88 3400 8.75 17.2 66.32
14.26 3440 8.7 17.2 66.39
14.63 3520 8.6 17.2 65.48
15.03 3560 8.55 17.11 66.18
15.42 3600 8.45 17.03 68.12
15.8 3680 8.45 17.2 69.72
16.2 3720 8.45 17.11 68.33
16.58 3760 8.5 17.46 71.53
16.97 3800 8.5 17.2 68.4
17.33 3840 8.5 17.63 73.82
17.73 3920 8.4 17.2 71.87
18.13 3960 8.35 17.03 68.12
18.5 4000 8.35 17.2 72.22
18.9 4000 8.3 17.2 72.15
19.29 4080 8.2 16.77 72.78
19.67 4080 8.1 16.77 75.69
20.04 4120 8 16.25 72.29
20.42 4160 7.9 16.08 74.09
20.81 4200 7.7 15.48 67.01
21.21 4240 7.7 15.57 73.06
21.62 4280 7.65 15.57 73.54
22.02 4320 7.5 14.88 67.15
22.42 4320 7.45 14.88 68.4
22.82 4360 7.35 14.71 73.82
23.21 4400 7.3 14.53 69.23
23.61 4440 7.25 14.36 71.32
24 4440 7.2 14.19 69.58
24.39 4480 7.1 13.93 67.08
24.76 4520 7.1 13.93 69.23
25.12 4560 7.1 13.93 68.61
25.51 4560 7.05 13.93 68.89
GRUPA 007:
Group A: '007
TIME
MARKER STAMP % V %
0.01 0 0.79 99.6 1
0.37 0 0.785 99.6 1
0.75 0 0.795 99.6 1
1.12 0 0.765 99.6 1
1.5 0 0.75 99.6 1
1.89 0 0.82 99.6 1
2.29 0 0.84 99.6 1
2.67 0 0.855 99.6 1
3.05 0 0.86 99.6 1
3.44 0 0.86 99.6 1
3.82 0 0.865 99.6 1
4.21 0 0.87 99.6 1
4.59 0 0.875 99.6 1
4.97 0 0.88 99.6 1
5.36 0 0.88 99.6 1
5.74 0 0.875 99.6 1
6.13 0 0.875 99.6 1
6.49 0 0.87 99.6 1
6.88 0 0.865 99.6 1
7.26 0 0.87 99.6 1
7.66 0 0.865 99.6 1
8.05 0 0.87 99.6 1
8.41 0 0.865 99.6 1
8.8 0 0.865 99.6 1
9.17 0 0.855 99.6 1
9.55 0 0.86 99.6 1
9.93 0 0.865 99.6 1
10.35 0 0.87 99.6 1
10.75 0 0.875 99.6 1
11.12 0 0.875 99.6 1
11.5 0 0.875 99.6 1
11.87 0 0.875 99.6 1
12.25 0 0.885 99.6 1
12.64 0 0.88 99.6 1
13 0 0.885 99.6 1
13.39 0 0.89 99.6 1
13.79 0 0.895 99.6 1
14.17 0 0.895 99.6 1
14.54 0 0.895 99.6 1
14.92 0 0.89 99.6 1
15.34 0 0.885 99.6 1
15.72 0 0.885 99.6 1
16.12 0 0.88 99.6 1
16.56 0 0.875 99.6 1
16.94 0 0.87 99.6 1
17.32 0 0.875 99.6 1
17.69 0 0.88 99.6 1
18.08 0 0.875 99.6 1
18.46 0 0.875 99.6 1
18.84 0 0.88 99.6 1
19.23 0 0.885 99.6 1
19.63 0 0.885 99.6 1
20.03 0 0.885 99.6 1
20.44 0 0.885 99.6 1
20.83 0 0.88 99.6 1
21.21 0 0.88 99.6 1
21.6 0 0.875 99.6 1
21.98 0 0.875 99.6 1
22.38 0 0.885 99.6 1
22.76 0 0.875 99.6 1
23.13 -6.3 0.895 0 1
23.51 -10.2 0.73 0 1
Robiąc logi dynamiczne kręć silnik do końca "zielonego pola", a przynajmniej do obrotów przy których twój silnik osiąga moc maksymalną.
Robiłem tak jak jest napisane od 1500-4200(4500) zresztą do czerwone pola na 4 nawet nie dojdę bo coś zrypane max 160 gdzieś poleci. Powyżej 4000 jest spadek mocy bardzo. Tak jakby komputer wchodził w tryb awaryjny.[br]Dopisany: 15 Lipiec 2008, 14:46 _________________________________________________W weekend będę czyścił przepływkę i przepływomierz to zobaczymy ;/ bo obroty też mi skaczą.
To się chyba diesla tyczyło? Pozatym możesz pociągnąć na niższym biegu, np. na dwójce...
  • 4 tygodnie później...
hey
ja właśnie też doprowadzam swojego ARG do porządku i miałem podobne objawy, powyżej 4000 to nie chciał nawet jechać, prawie sie cofał :), wypiołem wtyczke z przepływomierza i auto rakieta, chodziło super, tylko paliło około 14l na trasie, 230pln nowa przepływka (regenerowany bosh) i już jest wszystko ok
może Ci to coś pomoże ...
