Problem - błedy - Pomocy ! :D
Witam
kolegi a4 ma problem 99 rok 110km (zapomnialem sprawdzic prefa)
a wiec tak kolega dolal oleju i nie sprawdzil ile dolal a dolal 3 razy za duzo niz powinno byc :) Po przejechaniu ok 40 km nie wciskajac gazu samochod sam zaczal gazowac (obroty wskakiwaly do ponad 4.5tys) po rozmowie z kolega z forum stwierdzil ze moga byc walniete uszczelniacze zaworowe. Teraz kolega spuszcza olej i zobaczy czy wszystko bedzie ok.
Jakies sugestie co moze byc jeszcze uszkodzone?
Bledy:
VAG-COM Version: Release 311.2-N
1o9lo0m-n6r12p-o9ko4x-kkjahh-568f
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 AH
Component: 1,9l R4 EDC G000SG 2827
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: ö
Component: ö8D0
Coding:
Shop #: ö8
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 900 M
Component: KOMBI+WEGFAHRS. M73 D56
Coding: 00040
Shop #: WSC 21173
XXXXXXXXXXXXXXXXX AUZ5Z0K0047036
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
27-10 - Implausible Signal - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 12865
Shop #: WSC 06325
2 Faults Found:
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
End -------------------------------------------------------
W/g uzyskanych przez ciebie kodow nic nie wskazuje na jakiekolwiek uszkodzenia. Sterownik silnika sugeruje sprawdzic DTC (Kody bledow) w zegarach, w zegarach jedyny blad to sygnal z czujnika oleju nieprawdopodobnie wysoki czyli chodzi o ten 3krotny stan oleju, ze sterownika centralki/komfortu to tylko info ze masz upalona zarowke ktoras w oswietleniu wewnetrzyn i ze ktos probowal zaadaptowac pilot do centralki bezskutecznie. Dodatkowo pominal airbagi co jest niepokojace jak i immobilizer tez byl grzebany/jest niesprawny/interfejs go nie obsluguje tak jak airbagow.:wink:
Jak mozna, k**wa, zalac tyle oleju zeby bylo az tyle i do tego nie sprawdzic stanu bagnetem:facepalm:? To zasluguje na medal tak samo jak pani ktora odjechala z pistoletem od dystrybutora paliwa wlozonym do wlewu. Skoro obroty same wskakiwaly to znaczy ze olej dostaje sie do komory spalania wiec raczej uszczelniacze do roboty, gdyby turbo zaciagalo to raczej szukalby juz slupka 1.9 TDI do kupienia.
aha dzieki za odpowiedz :)
---------- Post dopisany at 12:57 ---------- Poprzedni post napisany at 08:54 ----------
airbaga pominolem w ogolnym skanie ;p
