Kamyk 15 Opublikowano 10 Grudnia 2013 Udostępnij Opublikowano 10 Grudnia 2013 Panowie jeśli można tematu dotknąłem już tutaj http://a4-klub.pl/diagnostyka-vag-32/parking-brake-malfunction-307377/ dzisiaj w końcu udało się podłączyć i wyskoczył niezły bałagan .... 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: Sporadic communication error 1000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAGB) Labels: None Part No SW: 03L 906 022 DL HW: 03L 906 022 B Component: R4 2,0L EDC H01 3215 Revision: --H01--- Coding: 0104002C18072118 Shop #: WSC 99999 1023 2097151 ASAM Dataset: EV_ECM20TDI03L906022DL A01014 ROD: EV_ECM20TDI03L906022DL.rod VCID: 72EFDEFB1429 2 Faults Found: 4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake U1010 00 [032] - Open or Short to Ground 4710 - Not all DTCs U0151 00 [047] - will be decoded. Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 11 Mileage: 120738 km Date: 2013.12.04 Time: 15:52:57 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 P HW: 8K0 907 379 P Component: ESP8 front H04 0180 Revision: -------- Serial number: -------------- Coding: 160500 Shop #: WSC 02399 823 56573 VCID: 4687522B4821 2 Faults Found: 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 126 Mileage: 120844 km Time Indication: 0 Date: 2013.12.10 Time: 12:27:28 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4780 Hex Value: 0x0013 Hex Value: 0x02B4 Hex Value: 0x00FF 01321 - Not all DTCs 004 - will be decoded. Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 126 Mileage: 120844 km Time Indication: 0 Date: 2013.12.10 Time: 12:27:28 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4780 Hex Value: 0x0017 Hex Value: 0x1DB4 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 C HW: 8K0 907 064 C Component: BCM2 1.1 H70 0141 Revision: 00002001 Coding: 030100 Shop #: WSC 02399 823 56573 VCID: 306B14F3DAA5 Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H35 0052 Part No SW: 8K0 905 852 C HW: 8K0 905 852 C Component: ELVAUDIB8 H35 0039 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 8K0-907-801.clb Control Module Part Number: 8K0 907 801 C HW: 8K0 907 801 C Component and/or Version: EPB Audi B8 H03 0040 Software Coding: Work Shop Code: WSC 00000 000 00000 VCID: 2F69178FC79B 1 Fault Found: 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - MIL ON do tego całe połączenie VCDSa to jedne wielkie jaja jak to mi opisał kumpel: Co do loga, to tak jak sam widziales, w momencie gdy CAN mial dostep do modulu AirBags, bledow nie bylo i log byl czysty. Jak tylko modul AirBags tracil polaczenie, co widac w naglowku loga (15-Airbags -- Status: Sporadic communication error 1000), wiekszosc modulow zaleznych wykazywala bledy. Z mojego punktu widzenia problem siedzi gdzies na laczach modulu AirBags, bo modul czasem gada i nie mozna ustalic jednoznacznie dlaczego traci polaczenie. Czasem ot tak sobie traci polaczenie podczas jazdy, a czasem traci polaczenie gdy inny modul odpytuje AirBaga czy jest sprawny. Czasem wystarczylo wylaczyc silnik i odczekac 30 sekund i modul odzyskiwal polaczenie, a czasem niestety nie proszę bardzo o pomoc :facepalm: a, jeszcze na koniec dnia, przy powrocie z pracy - nic mi się nie zapaliło, nie wariowało, nie głupiało można się załamać - WTF Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
spanky 7 Opublikowano 10 Grudnia 2013 Udostępnij Opublikowano 10 Grudnia 2013 nie zalalo Ci sterownika Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Kamyk 15 Opublikowano 10 Grudnia 2013 Autor Udostępnij Opublikowano 10 Grudnia 2013 hmmm mogę sprawdzić rzecz jasna nie wiem tylko jak i kiedy - mycie takich rzeczy u mnie odpada podpowiedz, gdzie dokładnie się znajduje, może coś tam rzeczywiście jest .... auto stoi w sumie w ciepłym garażu, dawno by chyba wszystko wyschło Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 343 Opublikowano 11 Grudnia 2013 Udostępnij Opublikowano 11 Grudnia 2013 w bagazniku po prawej stronie we wnece masz sterownik( kilka sterownikow) Po numerze znajdziesz ktory to Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Kamyk 15 Opublikowano 11 Grudnia 2013 Autor Udostępnij Opublikowano 11 Grudnia 2013 grzes ale myslisz ze to rzeczywiscie moze byc jakis wplyw wody ? dzisiaj auto podczas drogi do pracy znowu nic mi nie marudzilo ..... mozna dostac lekkiej konfuzji .... ---------- Post dopisany at 14:33 ---------- Poprzedni post napisany at 10:05 ---------- Po numerze znajdziesz ktory to grzes numerze - ale czego ???? skad ten numer wziac ?? i czy on na pewno jest z tylu, bo z tego nie za bardzo wynika Audi Portal: ECU Diagnostic . Audi A4 8K (2008-) . Airbag J234 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 343 Opublikowano 11 Grudnia 2013 Udostępnij Opublikowano 11 Grudnia 2013 Sprawdz numer sterownika od hamulca . Address 53: Parking Brake Labels: 8K0-907-801 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Kamyk 15 Opublikowano 11 Grudnia 2013 Autor Udostępnij Opublikowano 11 Grudnia 2013 grzesiu nie wiem o co biega ....... ale póki co, przestało się zapalać i problem jakby się wyleczył tyle że to nie katar, więc wolałbym pogrzebać i podziałać HGW co robić Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
