Shadow Opublikowano 11 Grudnia 2013 Opublikowano 11 Grudnia 2013 Ogólnie chodzi mi o kwestię dotyczącą silnika i jego podzespołów, bo świeci mi się kontrolka jakiegoś podzespołu. Dzięki za pomoc ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 8E0 909 518 AA HW: 8E0 909 018 A Component: 1.8L R4/5VT 0004 Coding: 0011501 Shop #: WSC 63351 000 00000 VCID: 6FE6D1E241C71A64 5 Faults Found 17978 - Engine Start Blocked by Immobilizer P1570 - 008 - Implausible Signal - Intermittent 17947 - Clutch Pedal Switch (F36): Implausible Signal P1539 - 004 - No Signal/Communication 17072 - ECM Power Relay Load Circuit: (J271): Open Circuit P0688 - 004 - No Signal/Communication 16891 - Idle Control System RPM: Higher than Expected. P0507 - 001 - Upper Limit Exceeded - Intermittent 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal P0116 - 008 - Implausible Signal - MIL ON Readiness: 0000 0000 Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04475 Shop #: WSC 06435 VCID: E5CA33CA133B5034 1 Fault Found 00526 - Brake Light Switch-F 36-10 - Open Circuit - Intermittent Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 H Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 VCID: 2648F4C6AEBD1B2C 3 Faults Found 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143) 30-00 - Open or Short to Plus 00819 - High Pressure Sensor (G65) 07-10 - Signal too Low - Intermittent 01317 - Control Module in Instrument Cluster (J285) 79-00 - Please Check Fault Codes Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00001 Shop #: WSC 63351 VCID: 346C1E8E686179BC 2 Faults Found 01498 - Bulb for Parking Lamps; Right (M3) 57-00 - Electric Circuit Failure 00987 - Lamp for Brake Light; Left (M9) 57-00 - Electric Circuit Failure Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00011 Shop #: WSC 63351 VCID: 366824867E1D6BAC No fault code found. Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 950 K Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 00400 Shop #: WSC 00586 VCID: 3162179A97734C94 WAUZZZ8E23A240728 AUZ6Z0B0344141 3 Faults Found 00779 - Outside Air Temp Sensor (G17) 30-00 - Open or Short to Plus 00562 - Sensor for Oil Level/Temperature (G266) 29-00 - Short to Ground 01176 - Key 07-10 - Signal too Low - Intermittent Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0604 Coding: 00001 Shop #: WSC 00000 VCID: EBDE45F2F5DF6644 No fault code found. Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl Part No: 8E0 959 433 BD Component: Komfortgerát TBF 1310 Coding: 06859 Shop #: WSC 63351 VCID: 74ECDE8E28E139BC Part No: 8E2959802B Component: Tőrsteuer.FS BRM 0002 Part No: 8E2959801B Component: Tőrsteuer.BF BRM 0002 14 Faults Found 01616 - Signal Wire to Interior Monitor 49-10 - No Communications - Intermittent 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch; Passenger Side 35-00 - - 01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent 01561 - Left Rear Door 61-00 - Won't De-Safe 01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent 01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent 01559 - Drivers Door 58-10 - Can't Lock - Intermittent 01331 - Door Control Module; Driver Side (J386) 80-10 - Single-Wire Operation - Intermittent 01332 - Door Control Module; Passenger Side (J387) 49-10 - No Communications - Intermittent 01802 - Door Warning Lamp; Pass Side (W36) 57-10 - Electric Circuit Failure - Intermittent 01560 - Passenger Door 58-10 - Can't Lock - Intermittent 00936 - Electric Window Switch in Front Passenger Door (E107). 27-10 - Implausible Signal - Intermittent Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 186 Component: concert II GRO 0008 Coding: 01000 Shop #: WSC 07777 VCID: E4CC2ECE1801293C 2 Faults Found 00852 - Loudspeaker(s); Front 36-00 - Open Circuit 00858 - Connection; Radio ZF Output to Antenna Amplifier 36-00 - Open Circuit
gregor10 Opublikowano 11 Grudnia 2013 Opublikowano 11 Grudnia 2013 Czujnik stopu do wymiany, pozatym mozliwy problem z czujnikiem temperatury badz termostatem, problem z immo - sporadyczny , pewnie zdazylo się że komuś nie odpalilo, dodatkowo sprawdz przekaźnik j271 w puszce kolo komputera sie powinien znajdować, jesli chodzi o sam silnik to jeszcze masz do zrobienia adaptacje przepustnicy lub jakas nieszczelnosc bo vag wykryl problem z podwyzszonymi obrotamia na beigu jalowym.
