Respect15 Opublikowano 7 Stycznia 2015 Opublikowano 7 Stycznia 2015 Witam, dzis zakupilem vaga i po kilkugodzinnej walce udalo mi sie odpalic. Mam kabel vag kkl i nie dziala mi vag pl 4.9 vcds pl 12 jakims cudem udalo mi sie odpalic na vcds eng 14. I wyskoczyly mi takie bledy VCDS-Lite Version: Release 1.2 Wednesday, 07 January 2015, 17:48:00. Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06B-907-557-ALT.LBL Controller: 8E0 907 557 Component: 2.0L R4/5VS 01 0004 Coding: 0011501 Shop #: WSC 20875 VCID: EEAFCDBBB98F 15 Faults Found: 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation P1340 - 001 - Upper Limit Exceeded 17947 - Shareware Version. To Decode all DTCs P1539 - 004 - Please Register/Activate 17545 - Shareware Version. To Decode all DTCs P1137 - 002 - Please Register/Activate - Intermittent 16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow P0139 - 002 - Lower Limit Exceeded - Intermittent 17536 - Shareware Version. To Decode all DTCs P1128 - 001 - Please Register/Activate - Intermittent 17522 - Shareware Version. To Decode all DTCs P1114 - 008 - Please Register/Activate - Intermittent 17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal P1171 - 008 - Implausible Signal - Intermittent 17950 - Shareware Version. To Decode all DTCs P1542 - 008 - Please Register/Activate - Intermittent 18036 - Shareware Version. To Decode all DTCs P1628 - 008 - Please Register/Activate - Intermittent 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 008 - Implausible Signal - Intermittent 18043 - Shareware Version. To Decode all DTCs P1635 - 008 - Please Register/Activate - Intermittent 16684 - Shareware Version. To Decode all DTCs P0300 - 001 - Please Register/Activate 16687 - Cylinder 3: Misfire Detected P0303 - 001 - Upper Limit Exceeded 16688 - Shareware Version. To Decode all DTCs P0304 - 001 - Please Register/Activate 17658 - Shareware Version. To Decode all DTCs P1250 - 008 - Please Register/Activate Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.LBL Controller: 8E0 614 517 Component: ABS/ESP front D620 Coding: 04275 Shop #: WSC 00000 VCID: E5BDB2976C79 1 Fault Found: 18256 - Please check DTC Memory of Engine Controller P1848 - 35-10 - - - Intermittent Wyskoczyly tylko kody bledow, wiecie mzoe co zrobic zeby odczytac te bledy i nie wyskoczylo shareware version?
ganjaq Opublikowano 8 Stycznia 2015 Opublikowano 8 Stycznia 2015 (edytowane) Cześć, już tłumacze co się stało. Po pierwsze zrobiłeś dwie literówki bo te vcds to jeżeli już to 1.2 a nie 12 a po drugie zagadnienie Shareware version oznaczają że program nie jest pełną wersią dlatego odczyta jedynie pierwszy bądź tylko jeden błąd w danym bloku. Proponuje Tobie poszukać na necie czegoś co nazywa się Vag-Com 3.11.2 full z dokładną instrukcją instalacji. Zaznaczyć też należy że mimo iż przy pozostałych błędach widnieje napis Shareware version nie znaczy to wcale że nie da się ich odczytać, kod błędu podało a to on jest najważniejszy. Dekoduje się je tutaj: http://wiki.ross-tech.com/wiki/index.php/Main_Page a robi się to tak, że wklejasz kod błędu w miejsce które zaznaczyłem, później z racji że dekoduje po angielsku opcjonalnie można sobie to przetłumaczyć: A tak z tego co widzę to jakiś problem wynikający z: -mieszanką paliwa, raz bogata za drugim razem uboga -sondą lambda (ale ona raczej wychwyciła że mieszanka jest niewłaściwa) -komunikacją z abs, -wypadaniem zapłonów na dwóch cylindrach 3 i 4 -coś z czujnikiem prędkości albo z rozrządem -jakiś problem z przepustnicą To jest poglądowe, żeby dokładnie zdiagnozować najlepiej usunąć błędy i sprawdzić które powrócą Edytowane 8 Stycznia 2015 przez ganjaq
Respect15 Opublikowano 8 Stycznia 2015 Autor Opublikowano 8 Stycznia 2015 VCDS-Lite Version: Release 1.0 Thursday, 08 January 2015, 04:55:36:0 Chassis Type: 8E - Audi A4 B6/B7 Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Controller: 8E0 907 557 Component: 2.0L R4/5VS 01 0004 Coding: 0011501 Shop #: WSC 20875 6 Faults Found: 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation P1340 - 001 - Upper Limit Exceeded 17522 - Shareware Version. To Decode all DTCs P1114 - 008 - Please Register/Activate 16684 - Shareware Version. To Decode all DTCs P0300 - 001 - Please Register/Activate 16687 - Cylinder 3: Misfire Detected P0303 - 001 - Upper Limit Exceeded 16688 - Shareware Version. To Decode all DTCs P0304 - 001 - Please Register/Activate 17658 - Shareware Version. To Decode all DTCs P1250 - 008 - Please Register/Activate Readiness: 0010 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.LBL Controller: 8E0 614 517 Component: ABS/ESP front D620 Coding: 04275 Shop #: WSC 00000 No fault code found. VCDS-Lite Version: Release 1.0 Thursday, 08 January 2015, 04:55:36:0 Chassis Type: 8E - Audi A4 B6/B7 Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Controller: 8E0 907 557 Component: 2.0L R4/5VS 01 0004 Coding: 0011501 Shop #: WSC 20875 6 Faults Found: 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation P1340 - 001 - Upper Limit Exceeded 17522 - Shareware Version. To Decode all DTCs P1114 - 008 - Please Register/Activate 16684 - Shareware Version. To Decode all DTCs P0300 - 001 - Please Register/Activate 16687 - Cylinder 3: Misfire Detected P0303 - 001 - Upper Limit Exceeded 16688 - Shareware Version. To Decode all DTCs P0304 - 001 - Please Register/Activate 17658 - Shareware Version. To Decode all DTCs P1250 - 008 - Please Register/Activate Readiness: 0010 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.LBL Controller: 8E0 614 517 Component: ABS/ESP front D620 Coding: 04275 Shop #: WSC 00000 No fault code found. Po usunieciu zostalo 6. Dodam ze faluja obroty na zimnym silniku nieraz gasnie, dzieje sie to przy rozruchu czyli PB. Czyli jak rozumiem na 1 rzut oka do wymiany czujnik walkow rozrzadu + sprawdzenie cewek i czyszczenie przepustnicy? Od czego moze byc ta zbyt uboga mieszanka? Moze sprawdzic filtr paliwa?
ganjaq Opublikowano 8 Stycznia 2015 Opublikowano 8 Stycznia 2015 P1250 17658 004688Ten błąd (nie ma go na wiki) mówi o niskim stanie paliwa w zbiorniku, po zatankowaniu i skasowaniu błędu znika. Co do błędów i diagnozy programem, to zawęża obszar poszukiwań ale rzadko wskazuje jednoznacznie. Co do misfire na 3 i 4 cylindrze, pomyślałeś cewki ale równie dobrze może to być wtrysk gazowy, wtrysk benzynowy, wypalony tłok czy co tam jeszcze. Należy reasumując tak do tematu podejść żeby na początek pozamieniać cewki miejscami. Co do zagadnienia składu mieszanki paliwowej to jeśli powietrza wykorzystywanego do spalania jest więcej od ilości stechiometrycznej, to współczynnik jest większy od 1, jeżeli natomiast mniej, to < 1, działa to nie jakby się wydawało w dwie a w cztery strony "ubogo" korekty na plus a) mamy za dużo powietrza w względem ilości stechiometrycznej, mamy za mało ilości stechiometrycznej względem powietrza, "bogato" korekty na minus a) mamy za dużo ilości stechiometrycznej względem powietrza, mamy za mało powietrza względem ilości stechiometrycznej, Powodów więc może być kilka i to mam na myśli
