kodzak0 Opublikowano 6 Lutego 2015 Opublikowano 6 Lutego 2015 Koledzy pojawil sie problem w Audi-cy mojego brata. Samochod jechal nagle zgasl i niechce odpalic juz. Kreci ale niemoze zalapac ;/ CO moze byc przyczyna? Ogolnie Vag takie bledy wykryl: \ VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 907 401 C Component: 2.5L V6 TDI G000SG 0004 Coding: 02015 Shop #: WSC 63351 00003059 130 106LC150_1.V77587790188 5 Faults Found: 00542 - Needle lift Sensor (G80) 30-10 - Open or Short to B+ - Intermittent 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-10 - - - Intermittent 00522 - Engine Coolant Temperature Sensor (G62) 30-10 - Open or Short to B+ - Intermittent 00575 - Intake Manifold Pressure 11-00 - Control Limit Not Reached 01318 - Control Module for Injection Pump (J399) 16-10 - Signal Outside Specifications - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 A Component: ABS/ESP allrad 1726 Coding: 04455 Shop #: WSC 06435 3 Faults Found: 00532 - Supply Voltage B+ 07-10 - Signal to Low - Intermittent 00532 - Supply Voltage B+ 35-10 - - - Intermittent 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-00 - - Address 08 ------------------------------------------------------- Controller: 8E0 820 043 C Component: A4 Klimaautomat 0712 Coding: 00000 Shop #: WSC 63351 6 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to B+ - Intermittent 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent 01206 - Signal for Duration of Ignition: OFF 27-00 - Implausible Signal 00538 - Reference Voltage 29-10 - Short to Ground - Intermittent 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 09 ------------------------------------------------------- Controller: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00111 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 L Component: Lenksáulenmodul 0308 Coding: 00042 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 17 ------------------------------------------------------- Controller: 8E0 920 930 JX Component: KOMBI+WEGFAHRS. RB4 D27 Coding: 01000 Shop #: WSC 19411 03514 AUZ6Z0A0188755 3 Faults Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent 01331 - Door Control Module: Driver Side (J386) 49-10 - No Communications - Intermittent 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent Address 37 ------------------------------------------------------- Controller: 8E0 035 192 Component: RNS 4.1 H06 BNO 0102 2 Faults Found: 00668 - Supply Voltage Terminal 30 07-10 - Signal to Low - Intermittent 00862 - Antenna for GPS Navigation (R50/R52) 36-00 - Open Circuit Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AE Component: Komfortgerát T01 0315 Coding: 06976 Shop #: WSC 63351 4 Faults Found: 01331 - Door Control Module: Driver Side (J386) 37-00 - Faulty 01560 - Passenger Door 61-00 - Won't De-Safe 01561 - Left Rear Door 61-00 - Won't De-Safe 01334 - Door Control Module: Rear Right (J398) 37-00 - Faulty Address 55 ------------------------------------------------------- Controller: 4Z7 907 357 Component: dynamische LWR D06 Coding: 00060 Shop #: WSC 63351 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal to Low - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 192 Component: Radio BNO 0001 Coding: 00207 Shop #: WSC 63351 2 Faults Found: 00668 - Supply Voltage Terminal 30 07-10 - Signal to Low - Intermittent 00852 - Loudspeaker(s): Front 36-00 - Open Circuit Address 76 ------------------------------------------------------- Controller: 8Z0 919 283 A Component: Parkingsyst. A4 RDW D06 Coding: 00114 Shop #: WSC 63351 No fault code found. End -------------------------------------------------------
KrzysiekA4 Opublikowano 7 Lutego 2015 Opublikowano 7 Lutego 2015 Napisze tylko o silniku bo jest tego mnogość 542 znaczy źe masz(brat) uwalony wtrysk sterujący lub samo zwarcie 18057 prawdopodobnie sterownik od ABS-U do wymiany 522 czujnik temperatury też do sprawdzenia (wymienienia) 575 problem z doładowaniem do sprawdzenia cały dolot czy szczelny i turbo No i wiśnia na torcie 1318 (j399) cudowna VP44 klęska możliwe źe sam sterownik i wymiana tranzystorka wystarczy jeźeli nie to regeneracja lub inną z tym samym numerem,ogólnie jest co robić.Widać źe zadbane auto Tak poważnie zaczął bym od pompy bo nie odpali za chuuuu....a
kodzak0 Opublikowano 7 Lutego 2015 Autor Opublikowano 7 Lutego 2015 Wlasnie tez pomyslalem o pompie. Tak samo o cewce ale chyba jej niema w silniku diesla. Czujnik temp napewno ma do wymiany. Cos mi nadmienial ze wtrysk mu siadal Ogolnie samochod nie jest zadbany, ma jeszcze problemy z jakimis wiazkami przez co rozladowywuje mu sie aku.
KrzysiekA4 Opublikowano 7 Lutego 2015 Opublikowano 7 Lutego 2015 Pompę tak jak pisałem można spróbować samemu naprawić wymieniając tranzystorek u mnie zadziałało masz mój temat na forum.Spróbować nie zaszkodzi bo i tak auto uwalone. Resztę też przydałoby się zrobić przynajmniej wtrysk sterujący☺
