setho Opublikowano 11 Marca 2015 Opublikowano 11 Marca 2015 Witam. Siostra kupiła auto i podłączyłem kompa robiąc szybki autoscan i mam oto takie historie Auto ponoć dłubnięte na 170KM ze 155. VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 907 401 Component: 2.5L V6 TDI G000SG 0006 Coding: 02012 Shop #: WSC 63351 00004059 130 106JC150_1.V77978744281 1 Fault Found: 00542 - Needle lift Sensor (G80) 30-10 - Open or Short to B+ - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04455 Shop #: WSC 06435 1 Fault Found: 00526 - Brake Light Switch-F 27-10 - Implausible Signal - Intermittent Address 08 ------------------------------------------------------- Controller: 8E0 820 043 A Component: A4 Klimaautomat 0912 Coding: 00000 Shop #: WSC 63351 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00111 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 L Component: Lenksáulenmodul 0308 Coding: 00042 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 17 ------------------------------------------------------- Controller: 8E0 920 930 J Component: KOMBI+WEGFAHRS. RB4 D27 Coding: 00000 Shop #: WSC 00530 27152 AUZ6Z0A0367895 4 Faults Found: 00562 - Sensor for Oil Level/Temperature (G266) 30-00 - Open or Short to B+ 00562 - Sensor for Oil Level/Temperature (G266) 29-00 - Short to Ground 00562 - Sensor for Oil Level/Temperature (G266) 27-10 - Implausible Signal - Intermittent 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent Address 37 ------------------------------------------------------- Controller: 4B0 919 887 E Component: BNS 4.2 H05 BNO 0050 1 Fault Found: 65535 - Internal Control Module Memory Error 00-00 - - Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AE Component: Komfortgerát T01 0315 Coding: 06976 Shop #: WSC 63351 6 Faults Found: 01331 - Door Control Module: Driver Side (J386) 80-00 - Single-Wire Operation 01813 - Supply Voltage for Door Controller: Rear Left (J388) 37-10 - Faulty - Intermittent 01803 - Door Warning Lamp: Rear Left (W37) 57-10 - Electric Circuit Failure - Intermittent 01333 - Door Control Module: Rear Left (J388) 80-10 - Single-Wire Operation - Intermittent 00934 - Electric Window Motor: Rear Left (V26) 62-10 - No or Incorrect Adjustment - Intermittent 01562 - Right Rear Door 61-00 - Won't De-Safe Address 55 ------------------------------------------------------- Controller: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00060 Shop #: WSC 63351 No fault code found. Address 56 ------------------------------------------------------- Controller: 8E0 035 152 Component: chorus II GRO 0007 Coding: 00012 Shop #: WSC 63351 1 Fault Found: 00856 - Radio Antenna 36-10 - Open Circuit - Intermittent End -------------------------------------------------------
Homiczek Opublikowano 13 Marca 2015 Opublikowano 13 Marca 2015 00542 - Needle lift Sensor (G80) - to ponoć błąd czujnika we wtryskiwaczu sterującym - sprawa do zajęcia się ! ja o tym za dużo nie wiem - może na początek sprawdzić wiązki idące do wtrysków parę błędów niezgodnego VIN - tak jakby parę rzeczy było wymienionych - np po dzwonie lewe tylne drzwi - pewnie szyba nie działa - wiązka do sprawdzenia, czy sie nie przyłamała między drzwiami a słupkiem
setho Opublikowano 13 Marca 2015 Autor Opublikowano 13 Marca 2015 Dzięki za odpowiedź! Co do drzwi tak podejrzewałem że wiązki bo u mnie tez podobne błędy były i kable pourywane dosłownie Ten czujnik da się wymienić jakos? Jaka cena ?
