Tomas213 Opublikowano 15 Kwietnia 2015 Opublikowano 15 Kwietnia 2015 Czy ktoś może mi pomóc i powiedzieć ,rozszyfrować te błędy?? Od czego mogą wynikać i jak je naprawić ?? Z góry dziękuję za pomoc:) VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 5934 Coding: 00002 Shop #: WSC 06335 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 16955 - Brake Switch (F): Implausible Signal P0571 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 00526 - Brake Light Switch-F . 36-00 - Open Circuit Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AA Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 06335 1 Fault Found: 00819 - High Pressure Sensor (G65) 07-10 - Signal to Low – Intermittent Address 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0606 Coding: 00001 Shop #: WSC 06335 No fault code found. Address 15 ------------------------------------------------------- Controller: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 06335 1 Fault Found: 01218 - Side Airbag Igniter: Passenger Side (N200) 001 - Upper Limit Exceeded Address 16 ------------------------------------------------------- Controller: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 01001 Shop #: WSC 06335 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 950 M Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00401 Shop #: WSC 00001 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BD Component: Komfortgerát TBF 1712 Coding: 06859 Shop #: WSC 06335 7 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch: Passenger Side 35-00 - - 00955 - Key 1 35-10 - - - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 186 D Component: concert II GRO 0004 Coding: 01001 Shop #: WSC 06335 No fault code found. End ------------------------------------------------------- VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 5934 Coding: 00002 Shop #: WSC 06335 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 16955 - Brake Switch (F): Implausible Signal P0571 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 00526 - Brake Light Switch-F . 36-00 - Open Circuit Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AA Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 06335 1 Fault Found: 00819 - High Pressure Sensor (G65) 07-10 - Signal to Low – Intermittent Address 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0606 Coding: 00001 Shop #: WSC 06335 No fault code found. Address 15 ------------------------------------------------------- Controller: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 06335 1 Fault Found: 01218 - Side Airbag Igniter: Passenger Side (N200) 001 - Upper Limit Exceeded Address 16 ------------------------------------------------------- Controller: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 01001 Shop #: WSC 06335 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 950 M Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00401 Shop #: WSC 00001 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BD Component: Komfortgerát TBF 1712 Coding: 06859 Shop #: WSC 06335 7 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch: Passenger Side 35-00 - - 00955 - Key 1 35-10 - - - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 186 D Component: concert II GRO 0004 Coding: 01001 Shop #: WSC 06335 No fault code found. End -------------------------------------------------------
wrclaguna Opublikowano 15 Kwietnia 2015 Opublikowano 15 Kwietnia 2015 kasowane były błedy ? ktore wracaja ?
Tomas213 Opublikowano 15 Kwietnia 2015 Autor Opublikowano 15 Kwietnia 2015 Tak , były kasowane...jeśli chodzi o te pierwsze błędy Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 5934 Coding: 00002 Shop #: WSC 06335 WAUZZZ8E45A110257 AUZ6Z0D0339205 1 Fault Found: 16955 - Brake Switch (F): Implausible Signal P0571 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 00526 - Brake Light Switch-F . Zostały prawdopodobnie usuniętę ponieważ po żarówki miałem spalone stopu , po wymianie już mi się nie paliła lampka Glow plung system...
wrclaguna Opublikowano 15 Kwietnia 2015 Opublikowano 15 Kwietnia 2015 czujnik stopu do wymiany pewnie .
Tomas213 Opublikowano 15 Kwietnia 2015 Autor Opublikowano 15 Kwietnia 2015 Co z resztą błędów ? Jeśli chodzi o alarm dodatkowo zacina mi się bagarznik kiedy chce go otworzyć automatycznie, kiedy włożę kluczyk i przekręcę to otworzy się ale po chwili zaczyna wyć alarm ...?
DragonGTI Opublikowano 18 Kwietnia 2015 Opublikowano 18 Kwietnia 2015 (edytowane) Co z resztą błędów ? Jeśli chodzi o alarm dodatkowo zacina mi się bagarznik kiedy chce go otworzyć automatycznie, kiedy włożę kluczyk i przekręcę to otworzy się ale po chwili zaczyna wyć alarm ...? a co z innymi drzwiami? otwierają się normalnie z pilota? i czy jak je otworzysz kluczykiem mechanicznie to włącza się alarm czy nie ? W klapie pewnie krańcówka i mikrowłącznik pierdzieli, polecam tam zajrzeć. Edytowane 18 Kwietnia 2015 przez DragonGTI
