Brzozek Opublikowano 14 Maja 2015 Opublikowano 14 Maja 2015 (edytowane) Witam, dzisiaj podczas odpalania auto zgasło i migała kontrolka świec. Za drugim razem auto odpaliło normalnie. Przeskanowałem i wyskoczyły błędy. Gdzie szukać przyczyny? Chyba coś z immobilizerem. Address 01: Engine Labels: Redir Fail! Part No SW: 03G 906 016 GD HW: 03G 906 016 GD Component: R4 1,9L EDC G000SG 9577 Revision: --H05--- Serial number: XXXXXXXXXXXXXX Coding: 0000071 Shop #: WSC 60909 124 071241 Fault Found:005488 - Engine Start Blocked by Immobilizer P1570 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 1 Fault Frequency: 1 Mileage: 239768 km Time Indication: 0 Freeze Frame: RPM: 966 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.17 V Bin. Bits: 00101100 Bin. Bits: 11000000 (no units): 0.0Readiness: 0 0 0 0 0-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF Component: ESP8 FRONT H06 0140 Revision: 00000000 Serial number: 00000000000000 Coding: 0004401 Shop #: WSC 06335 000 00000No fault code found.-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BL Component: A4 Klimaautomat 3233 Coding: 00000 Shop #: WSC 00000 1 Fault Found:00474 - Control Module for Immobilizer 49-10 - No Communications - Intermittent-------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 N Component: int. Lastmodul NDL 0907 Coding: 11012 Shop #: WSC 65536 1 Fault Found:01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation-------------------------------------------------------------------------------Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H13 4230 Revision: 91H13423 Serial number: 0036M0G7TECN Coding: 0030612 Shop #: WSC 06335 000 00000No fault code found.-------------------------------------------------------------------------------Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0701 Coding: 04042 Shop #: WSC 06335 1 Fault Found:00474 - Control Module for Immobilizer 49-10 - No Communications - Intermittent-------------------------------------------------------------------------------Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 932 HW: 8E0 920 932 Component: KOMBI+WFS 4 H10 0200 Revision: 0200 Serial number: 00000000000000 Coding: 0006118 Shop #: WSC 00999 444 64523No fault code found.-------------------------------------------------------------------------------Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q Component: RNS-E HIGH EU H73 0750 Revision: 02S Serial number: AUZBZ7G1121117 Coding: 0301717 Shop #: WSC 06335 000 00000No fault code found.-------------------------------------------------------------------------------Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 No fault code found.-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CQ Component: Komfortgerát T3B 4236 Coding: 07018 Shop #: WSC 06335 Part No: 8E1959801H Component: Tőrsteuer.FS BRM 0606 Part No: 8E1959802H Component: Tőrsteuer.BF BRM 0606 Part No: 8E0959801E Component: Tőrsteuer.HL BRM 0606 Part No: 8E0959802E Component: Tőrsteuer.HR BRM 0606 No fault code found.-------------------------------------------------------------------------------Address 56: Radio Labels: 8E0-035-192-RNSE.lbl Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q Component: RNS-E HIGH EU H73 0750 Revision: 02S Serial number: AUZBZ7G1121117 Coding: 0301717 Shop #: WSC 06335 000 00000No fault code found.-------------------------------------------------------------------------------Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl Part No SW: 8E0 919 283 D HW: 8E0 919 283 D Component: Parkhilfe 4-Kan H06 0010 Revision: 00H06000 Serial number: 00067802020711 Coding: 0000014 Shop #: WSC 06335 000 00000No fault code found.-------------------------------------------------------------------------------Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8P0 862 335 H HW: 8P0 862 335 H Component: FSE_255x BT H26 0290 Revision: 00000000 Serial number: 00000005123294 Coding: 0011891 Shop #: WSC 06335 000 00000No fault code found.End --------------------------------------------------------------------- Edytowane 14 Maja 2015 przez Brzozek
