[ALL B5] Kody wyposażenia - prośba o przetłumaczenie
Co oznaczają kody;
3S0 = without roof rails/roof load rack
C1L = cast alloy wheels 7J x 16 five-arm style, offset 45
0JF = weight category front axle weight range 6
3S0 = without roof rails/roof load rack - brak relingow
C1L = cast alloy wheels 7J x 16 five-arm style, offset 45 - alufelgi 7Jx16" piecioramienne, ET45
0JF = weight category front axle weight range 6 - 6. kategoria wagowa przedniej osi (???)
dZIęKI BARDZO :a4fan:
Może mi też ktoś przetłumaczyć ?? Korzystałem z dekodera VIN'u, ale ja nie znam wogóle angielskiego <niemieckiego się uczę ;(>
COMBUSTIBIL -- MOTORINA
LITRI / CILINDREE / DESCRIERE -- 1.9 / 1896 CM3 / VEP
PUTERE / KW / CP / RPM -- 81 KW / 110 CP
CUPLU / RPM -- 235 Nm
CILINDIRI / VALVE -- 4 CILINDRI / 8 VALVE
COD TRANSMISIE -- DHF
CULOARE EXTERIOARA -- ARTITIO (A2 / Y9B)
CULOARE INTERIOARA -- SLATE (GREY) (BN)
X0A- national sales program Germany
A8S-standard equipment
G0C- 5-speed manual transmission
K8D- Station Wagon Variant/Avant
M6N- 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R
T1R- 4-cylinder diesel engine 1.9 L unit 028.R
0DY-
installation differentiation for build status of vehicle class B5 (AUDI) unit
components
0K0- without alternative drive module
1VG- installation parts for four-cylinder engine
1X0- front wheel drive
C10- operating permit, alteration 10
S5U- 100% in-plant control I/PI-S
0TD- front and rear floor mats
3CB- net partition
3S2- black roof rails
5K0- without paint preservative
5MG- decorative burr walnut inserts
7P4- manually adjustable lumbar support in front seats
PH5-
RBL- radio chorus with front and rear speakers
WM3- Sharan "Voyage II" for Belgium / Luxembourg with RCH radio "gamma"
N5G- fabric seat covering (not specified yet)
8RN- eight speakers (active)
8UC- radio chorus
9AK- automatic air conditioning with sun sensor
B0A- component parts set without country-specific design requirement
B99- type approval EC
C8N- alloy wheels 6J x 15 style not designated; 4B0 601 025 L offset 45
E0A- no special edition
FA0- control of standard production
F0Y- vehicle with optional features
H6S- tires 195/65 R 15 V
J0R-battery 380 A (80 Ah)
L0L- LHD vehicle
Q1A- standard seats
U1A -instrument insert with km/h speedometer,clock, tachometer and trip odometer
0G1 -gearshift lever
0JF -weight category front axle weight range 6
0LW -special plates/stickers/ safety certificates for Germany
0ST- labels/plates in German and French
0VC- German owner's manual
0YE- weight category rear axle weight range 5
1AC- anti-lock brake system (ABS)
1BA- standard suspension/shock absorption
1C1- antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D0- without towing attachment
1EX -VIN plate
1E0 -without activated charcoal canister
1G3 -alloy spare wheel with original equipment tires
1LB -yellow front brake calipers
1PA -standard wheel bolts
1SA- without additional engine guard
1S7 -tool kit and aluminum jack
1T3- first aid kit and warning triangle
1WD- transmission shaft for tripod joints
1YA -without transmission shafts f. rear axle
1Z0 -initial standard fuel filling
2A5 -delivery equipment (transit coating) with thin seat cover
2B1- additional exterior noise suppression
2G0- without insert for the filling up of fuel
2K1- reinforced bumpers
2PG- foam-padded steering wheel, four-spoke
2WA- without additional tires
2Z1 -type sign at rear and "Quattro" nameplates respectively
3B0- without additional child seat anchor
3C7- 3-point seat belt for center rear seat
3FA- without roof insert (standard roof)
3L1- manual height adjustment for left front seat
3NZ- rear seat bench unsplit, backrest split folding
3Q6- three rear headrests
3X0- without load-through provision
3Y0- without roll-up sun screen
4A0- without seat heater
4F1- central locking system
4GH- windshield tinted with windshield sunshield
4L2 -dipping breakaway inside rear view mirror
4M6- cup holder
4R2- power windows front, mechanical window regulators rear
4SB- vanity mirror left
4TB- vanity mirror right
4UE- airbag f. driver a. front seat passenger
4W0- without cassette and CD storage unit
4X1 -side airbag front
4ZE- black moldings
5C0- without special body measures
5D0- without carrier frequency
5E1 -without sill top with door cover
5RQ -outer right rear view mirror: convex
5SL- left wing mirror: non spherical
6E0 -without center armrest front
6M0 -without tie down straps/net/pocket
6N0 -without mud flaps
6Q1- plastic gearshift knob/handle
6RB -dashboard and door trim panel multi-piece, single-color, multi-colored
6R1 -leatherette gearshift boot
6U0- without additional seals outside
6V1 -rear trim panel (ECE)
6W5- front license plate bracket
6XC- outer rear view mirrors: powered
7AA- electronic vehicle immobilization device
7A0- without CD changer/CD player
7CA- without label for radio remote control
7M0- plastic scuff plates in door apertures
7QA- without CD ROM
7Q0- without navigation device
7X0- without park distance control
8BG- twin headlamp for left-hand drive with integrated high-beam headlight
8CC- speedometer sensor without seal (electronic speedometer sensor)
8GL- alternator 120A
8KA- w/o catalytic converter warning light
8K0- without special low beam mode
8N4- windshield wiper intermittent control with potentiometer (four speeds)
8Q1- headlight-range adjustment
8R1- center high-mounted stop light
8S4 -two reading lights front, two rear
8TC -rear fog light for driving on the right
8T0 -without cruise control system (CCS)
8X0- without headlight washer system
8Z5 -engine cooling system, type 1
9P0 -without seat belt warning light
9Q0 -without multi-function indicator/ on-board computer
9T0- without heated washer nozzles
9W0- w/o car phone preparation/installation
9X4- without heated door lock cylinder with micro switch
9Y0- without outdoor temperature gage
Wiem że trochę tego jest, z góry dzięki :)
Pozdro.
Trzeba było wpisać kody na tej stronie i dopiero wkejać wyniki.
Coś sporo tych kodów
Dużo wiem, to nie są te z nalepki w bagażniku, tylko z rozszyfrowania VIN'u <ktoś na forum podał stronkę i tam jest szczegółowy opis pojazdu.
Tutaj są kody z nalepki w bagażniku :
X0A = national sales program Germany
B0A = component parts set without country-specific design requirement
C8N = alloy wheels 6J x 15 style not designated 4B0 601 025 L offset 45"
G0C = 5-speed manual transmission
H6S = tires 195/65 R 15 V
J0R = battery 380 A (80 Ah)
M6N = 4-cylinder turbo diesel engine 1.9 L/81 kW TDIwith MVEG 2, base engine is T1R
G1A = six-speed automatic transmission
1AC = anti-lock brake system (ABS)
1G3 = alloy spare wheel with original equipment tires
2PE? = leather multi-function steering wheel rim temperature controlled
2PG? = steering wheel
<któryś z tych dwóch jest prawidłowy, bo nie mogłem się rozczytać :) >
5RQ = outer right rear view mirror: convex
5SL = outer left rear view mirror: non-spherical
T1R = components for, base engine, unit 028.R
0YE = weight category rear axle weight range 5
3S2 = black roof rails
4UE = airbag for driver and front seat passenger
0G1 = gearshift lever
8UC = radio "chorus"
8GL = alternator 120A
8RN = eight speakers (active)
1LB = disc brakes, front
3FA = without roof insert (standard roof)
1BA = standard suspension/shock absorption
Pozdro i z góry dzięki :drunk:
  • 5 tygodni później...
Podłącze się do wątku i podam swoje:
X0A national sales program Germany
A8S standard equipment
G0C 5-speed manual transmission
K8B notchback
M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
T5Z 4-cylinder gasoline engine 1.8 L unit 058.B
0DY installation differentiation for build status of vehicle class B5 (AUDI) unit components
0G1 gearshift lever
1VG installation parts for four-cylinder engine
1X0 front wheel drive
C03 operating permit, alteration 3
H6T tires 205/60 R 15 V
S0Z control (in-plant)
1AH electronic differential lock (EDL)
3C3 lap belt with retractor for the center rear seat
3NZ rear seat bench unsplit, backrest split folding
4W1 cassette storage unit
8BG twin headlamp for left-hand drive with integrated high-beam headlight
9V7 anti-theft alarm
PH5
PI1 driver information system (DIS)
PW2 heated exterior mirrors, electrically folding incl. heated washer jets
RVC Radio gamma CC with loudspeakers in the front and rear
WS1 front sports seats
Q1D front sports seats
U1C instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.)
3AF outer right rear view mirror: convex, powered, heated
3BS outer left rear view mirror: non-spherical, powered, heated
3L3 height adjustable front seats
7P4 manually adjustable lumbar support in front seats
8AD radio "gamma"
8GD alternator 90A
8RN eight speakers (active)
9AK automatic air conditioning with sun sensor
9Q2 Driver Information System (DIS)
9T1 heated washer nozzles, front
9X6 heated door lock cylinder left with micro switch
9Y1 outdoor temperature gage
B0A component parts set without country-specific design requirement
B99 type approval EC
C0V steel wheels 6J x 15 offset 45 (five-hole)
E0A no special edition
FA0 control of standard production
F0A no special purpose vehicle, standard equipment
J1P battery 220 A (44 Ah)
L0L LHD vehicle
N4A fabric seat covering
0LW special plates/stickers/ safety certificates for Germany
0SB labels/plates in German
0TC Floor mats
0VC German owner's manual
0W1 label for central electric German-speaking countries
1BA standard suspension/shock absorption
1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D0 without towing attachment
1EX VIN plate
1E1 activated carbon canister
1G2 steel spare wheel with original equipment tires
1LH disc brakes, front
1PA standard wheel bolts
1SA without additional engine guard
1T3 first aid kit and warning triangle
1Z0 initial standard fuel filling
2A5 delivery equipment (transit coating) with thin seat cover
2B0 without additional exterior noise suppression
2G1 insert for the filling up of unleaded fuel
2K1 reinforced bumpers
2PG foam-padded steering wheel, four-spoke
2WA without additional tires
2Z1 type sign at rear and "Quattro" nameplates respectively
3B0 without additional child seat anchor
3CA without partition
3FA without roof insert (standard roof)
3S0 without roof rails/roof load rack
3X0 without load-through provision
3Y0 without roll-up sun screen
4A0 without seat heater
4F1 central locking system
4GH windshield tinted with windshield sunshield
4M0 without cup holder
4R2 power windows front, mechanical window regulators rear
4SB vanity mirror left
4TB vanity mirror right
4UE airbag f. driver a. front seat passenger
4ZE black moldings
5C0 without special body measures
5K1 paint preservative (wax)
5MD decorative aluminum inserts
6E0 without center armrest front
6FA components without special surface appearance
6N0 without mud flaps
6Q1 plastic gearshift knob/handle
6R1 leatherette gearshift boot
6U0 without additional seals outside
6V1 rear trim panel (ECE)
6W5 front license plate bracket
7A0 without CD changer/CD player
8CC speedometer sensor without seal (electronic speedometer sensor)
8KA w/o catalytic converter warning light
8K0 without special low beam mode
8NA without parking light warning light
8Q1 headlight-range adjustment
8R1 center high-mounted stop light
8S0 without reading light
8TC rear fog light for driving on the right
8T0 without cruise control system (CCS)
8X0 without headlight washer system
8Z0 standard engine cooling system
9P0 without seat belt warning light
9W0 w/o car phone preparation/installation
Nie wiem czy było o tym mówione ale np u mnie nie było naklejki z kodami we wnece od zapasu, ale znalazlem ja dzis pod tylnym siedzeniem, jak przeciagalem kabel od anteny :thumbup:
Jeśli moge zapytać - z jakiego programu korzystacie odszyfrowując kody ?
Z Etki ?
Jak sie takowy nazywa ?
Z Etki ?
z dokumentacji, która powinieneś odtrzymać z autem....
niektórzy mają rozkodowany vin również (rozkodowany to znaczy jakie wyposażenie)
z tej strony : http://www.oilshop.ro/catalog/vagvin.php
wszystkie te informacje były już kilkanaście razy na forum :disgust:
Mea Culpa - zapewne tak - nie przebywam tak często na sieci a jestem deko nowy :)
Nieskromnie zapytam - wpisałem VIN i pod spodem wypadły mi dwie tabele kodów wyposażeniowych.
Gdzie mogę je przetłumaczyć ?
A co nie było angielskiego w szkole? :polew: Słownik i do roboty!
BTW trochę już jest przetłumaczone w tym temacie. ;)
jesli czegoś nie rozumiesz, to można wklejać w tym temacie na przykład.
Tylko błagam nie wklejaj wszystkiego :) Na pewno część z tego jest zrozumiała :decayed:
albo znajdziesz w tym temacie :thumbup:
można prosić
SPECS
0G1 gearshift lever
FA3 internal control
H6U tires 205/55 R 16 91W
S0C introductory volume
S61 control of deviation permit F 300 SOP (raised chassis)
1G3 alloy spare wheel with original equipment tires
1PC wheel bolts with anti-theft protection (unlockable)
3FE electric slide/tilt sunroof with sun screen/sunblind
4SD left vanity mirror illuminated
4TD right vanity mirror illuminated
5MG decorative burr walnut inserts
PH5
8Z2 engine cooling system with heavy-duty fan and radiator
C00 operating permit, initial registration
F0Y vehicle with optional features
L0L LHD vehicle
0TC Floor mats
1AC anti-lock brake system (ABS)
1EX VIN plate
4W0 without cassette and CD storage unit
4ZE black moldings
6FB exterior mirror housings and door handles in body colour
6TB outer right rear view mirror: convex, powered
6UA outer left rear view mirror: flat, powered
7AA electronic vehicle immobilization device
7P0 without lumbar support in front and rear seats
8S4 two reading lights front, two rear
X0A national sales program Germany - program sprzedaży w Niemczech
A8S standard equipment - wyposażenie standardowe
G0C 5-speed manual transmission - 5-biegowy manual
K8B notchback - styl nadwozia (coś koło sedana ;) )
M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z - 4-cylindrowy benzyniak, pojemność 1.8l/92kW, 20 zaworów, reszty nie czaję
T5Z 4-cylinder gasoline engine 1.8 L unit 058.B - j/w
0DY installation differentiation for build status of vehicle class B5 (AUDI) unit components - zróżnicowanie w budowie podzespołów??
0G1 gearshift lever - dźwignia zmiany biegów
1VG installation parts for four-cylinder engine - elementy (jak przypuszczam - elektryki lub mocowania silnika) dla 4-cylindrowego silnika
1X0 front wheel drive - napęd kół przednich
C03 operating permit, alteration 3 - ?
H6T tires 205/60 R 15 V - opony 205/60 R 15 V (V- do 240 km/h)
S0Z control (in-plant) - ?
1AH electronic differential lock (EDL) - elektroniczna blokada dyferencjału
3C3 lap belt with retractor for the center rear seat - środkowy pas tylni z napinaczem
3NZ rear seat bench unsplit, backrest split folding - tylna kanapa nie dzielona, oparcie dzielone
4W1 cassette storage unit - schowek na kasety
8BG twin headlamp for left-hand drive with integrated high-beam headlight - podwójne reflektory dla ruchu lewostronnego ze zintegrowanymi światłami drogowymi
9V7 anti-theft alarm - alarm przeciwwłamaniowy
PH5
PI1 driver information system (DIS) - system informowania kierowcy (popularny FIS)
PW2 heated exterior mirrors, electrically folding incl. heated washer jets - podrzewane lusterka zewnętrzne, elektrycznie ustawiane, podrzewane spryskiwacze
RVC Radio gamma CC with loudspeakers in the front and rear - radio Gamma z głośnikami z przodu i z tyłu
WS1 front sports seats - przednie fotele sportowe
Q1D front sports seats - przednie fotele sportowe
U1C instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.) - panel instrumentów z prędkościomierzem w km/h, zegarem, obrotomierzem, licznikiem kilometrów i dodatkowymi instumentami (woltomierz, temperatura oleju)
3AF outer right rear view mirror: convex, powered, heated - zewnętrzne prawe lusterko: sferyczne, sterowane elektrycznie, pogrzewane
3BS outer left rear view mirror: non-spherical, powered, heated - zewnętrzne lewe lusterko: asferyczne, sterowane elektrycznie, pogrzewane
3L3 height adjustable front seats - fotele przednie z regulacją wysokości
7P4 manually adjustable lumbar support in front seats - ręcznie ustawiane podparcie lędźwia
8AD radio "gamma" :)
8GD alternator 90A - 90-amperowy alternator
8RN eight speakers (active) - 8 aktywnych głośników
9AK automatic air conditioning with sun sensor - automatyczna klimatyzacja z czujnikem nagrzewania
9Q2 Driver Information System (DIS) - FIS
9T1 heated washer nozzles, front - podgrzewane spryskiwacze, przód
9X6 heated door lock cylinder left with micro switch - podgrzewany cylinderek zamka lewego z mikoprzełącznikiem (?)
9Y1 outdoor temperature gage - termometr zewnętrzny
B0A component parts set without country-specific design requirement - zestaw komponentów bez wymagań co do warunków terenowych
B99 type approval EC - ?
C0V steel wheels 6J x 15 offset 45 (five-hole) - stalowe koła 6J x 15, odsadzenie 45 (pięć dziur ;) )
E0A no special edition - edycja zwykła (niespecjalna :) )
FA0 control of standard production - kontrola produkcji standardowej (?)
F0A no special purpose vehicle, standard equipment - wyposażenie standardowe
J1P battery 220 A (44 Ah) - akumuator 220A, 44Ah
L0L LHD vehicle - pojazd do ruchu lewostronnego
N4A fabric seat covering - materiałowe porycie foteli
0LW special plates/stickers/ safety certificates for Germany - tablice/naklejki/certyfikaty bezpieczeństwa dla Niemiec
0SB labels/plates in German - oznaczenia/tablice w Niemczech
0TC Floor mats - maty podłogowe
0VC German owner's manual - instrukcja Niemiecka
0W1 label for central electric German-speaking countries - oznaczenia elektryki w języku Niemieckim
1BA standard suspension/shock absorption - standardowe zawieszenie
1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C - antyzamarzacz (?) - przypuszczam, że chodzi o zamek
1D0 without towing attachment - bez haka
1EX VIN plate - tabliczka z VINem
1E1 activated carbon canister - zbiornik z węglem aktywowanym
1G2 steel spare wheel with original equipment tires - stalowe koło zapasowe ze standardowymi oponami
1LH disc brakes, front - hamulce tarczowe z przodu
1PA standard wheel bolts - standardowe śruby kół
1SA without additional engine guard - brak dodatkowej ochrony silnika
1T3 first aid kit and warning triangle - apteczka pierwszej pomocy i trójkąt ostrzegawczy
1Z0 initial standard fuel filling - standardowe wstępne napełnianie paliwem (wtf?)
2A5 delivery equipment (transit coating) with thin seat cover - wyposażenie dostawcze z cienkim pokryciem foteli
2B0 without additional exterior noise suppression - brak dodatkowego tłumienia hałasu zewnętrznego
2G1 insert for the filling up of unleaded fuel - wkład do napełniania paliwem bezołowiowym
2K1 reinforced bumpers - wzmacniane zderzaki
2PG foam-padded steering wheel, four-spoke - kierownica wyłożona pianką, 4-ramienna
2WA without additional tires - brak dodatkowych opon
2Z1 type sign at rear and "Quattro" nameplates respectively - oznaczenie typu z tyłu oraz tabliczki 'quattro'
3B0 without additional child seat anchor - brak dodatkowego zaczepu dla fotelika dziecięcego
3CA without partition - brak przegrody
3FA without roof insert (standard roof) - brak szyberdachu
3S0 without roof rails/roof load rack - brak relingów
3X0 without load-through provision - ?
3Y0 without roll-up sun screen - brak rolety przeciwsłonecznej
4A0 without seat heater - brak podgrzewania foteli
4F1 central locking system - centralny zamek
4GH windshield tinted with windshield sunshield - przednia szyba przyciemniana z pasem przeciwsłonecznym
4M0 without cup holder - brak uchwytu na kubki
4R2 power windows front, mechanical window regulators rear - elektrycznie sterowane okna z przodu, mechanicznie z tyłu
4SB vanity mirror left - ?
4TB vanity mirror right - ?
4UE airbag f. driver a. front seat passenger - poduszka kierowcy i pasażera z przodu
4ZE black moldings - czarne odlewy
5C0 without special body measures - brak specjalnych wymiarów karoserii
5K1 paint preservative (wax) - zabezpieczenie lakieru (wosk)
5MD decorative aluminum inserts - dekoracyjne wstawki aluminiowe
6E0 without center armrest front - brak środkowego podłokietnika z przodu
6FA components without special surface appearance - elementy bez specjalnego wyglądu powierzchni
6N0 without mud flaps - brak chlapaczy
6Q1 plastic gearshift knob/handle - plastikowa dźwignia zmiany biegów
6R1 leatherette gearshift boot - skóropodobny (?) mieszek dźwigni zmiany biegów
6U0 without additional seals outside - brak dodatkowych uszczelek zewnętrznych
6V1 rear trim panel (ECE) - ?
6W5 front license plate bracket - miejsce na zamocowanie tablicy rejestracyjnej z przodu
7A0 without CD changer/CD player - brak zmieniarki/odtwarzacza CD
8CC speedometer sensor without seal (electronic speedometer sensor) - czujnik prędkości bez uszczelki (elektroniczny)
8KA w/o catalytic converter warning light - brak oświetlenia ostrzegawczego katalizatora
8K0 without special low beam mode - brak specjalnego trybu świateł mijania
8NA without parking light warning light - brak kontrolki hamulca postojowego
8Q1 headlight-range adjustment - regulacja zasięgu reflektorów
8R1 center high-mounted stop light - centralne światło stopu, montowane wysoko
8S0 without reading light - brak oświetlenia do czytania
8TC rear fog light for driving on the right - tylne światło przeciwmgłowe z prawej strony
8T0 without cruise control system (CCS) - brak tempomatu
8X0 without headlight washer system - brak układu zmywania reflektorów
8Z0 standard engine cooling system - standardowy system chłodzenia silnika
9P0 without seat belt warning light - brak kontrolki ostrzegawczej pasów
9W0 w/o car phone preparation/installation - brak isntalacji telefonu
błagania poszły na marne, wkleili wszystko.
sorka za Ot.
Ja nic nie wklejałme jeszcze - sam walcze z tym. :D
Większości nie rozumie ale nie jest tak fatalnie. Przy okazji napiszę swoje.
witam.prosił bym o rozszyfrowanie dla mnie paru kodów z góry dzienks :)
Q1A=standart front seats
OJF=weight category front axle weight range 6
1Q3=mas damper for steering whel , xxhz
2PF=leather steering wheel for airbag systemwith mass damper
5RQ=outer right rear view mirror : convex
5SL=outer left rear view mirror: non sphericial
T1R=components for base engine, unit 028.r
3FA=without roof insert ( standart roof)
niedługo pochwale sie wam moją niunią :a4fan:
