kodowanie sterownika ABS
Witam szanowne grono. mam problem z kodowaniem pompy abs po zmianie jej. otoz sytuacjia wyglada tak , ktos wymienil pompe abs i nie zeskanowal kodowania. czy ktos z forumowiczow moze pomoc w zakodowaniu , jakas podpowiedz lub sugestje. ponizej zrzut z vcds. to jest anglik po wypadku
Wednesday,02,September,2015,13:14:38:19673
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
www.Ross-Tech.com
VIN: WAUZZZ8K5FA112560 License Plate: GF15ESO
Mileage: 2690km-1671mi Repair Order:
Chassis Type: 8K (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6D 72
VIN: WAUZZZ8K5FA112560 Mileage: 2690km-1671miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CJCD) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 SJ HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 5104
Revision: 45H25---
Coding: 12194012242401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018SJ 003002
ROD: EV_ECM20TDI01103L906018JK.rod
VCID: 040016DF8F57C61E72-8050
3 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 17
Mileage: 2690 km
Date: 2015.08.29
Time: 18:50:46
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Mileage: 2690 km
Date: 2015.08.29
Time: 18:50:46
4996 - Glow Plug Control Module (J179)
P0684 00 [101] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 2692 km
Date: 2015.08.30
Time: 11:33:24
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 8K0 907 379 CN HW: 8K0 907 379 CN
Component: ESP8 front H09 0020
Revision: -------- Serial number: --------------
Coding: 171DCC01
Shop #: WSC 06325 000 00000
VCID: 071A01D3B661ED0617-8052
3 Faults Found:
00493 - ESP-Sensor Unit (G419)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 19:01:11
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4082
Hex Value: 0x0004
Hex Value: 0xC896
Hex Value: 0x0000
01315 - Transmission Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 9
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 19:01:11
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4082
Hex Value: 0x000D
Hex Value: 0x8596
Hex Value: 0x0000
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 15
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 19:01:13
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4282
Hex Value: 0x0045
Hex Value: 0x139C
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 KG HW: 8K0 907 064 KG
Component: BCM2 2.0 H15 0711
Revision: 00002001
Coding: 03B24040000000000000
VCID: 7F0A9933EEB1A5C62F-802A
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 86
Mileage: 2692 km
Time Indication: 0
Date: 2015.08.29
Time: 22:15:43
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 BB HW: 8K2 820 043 BB
Component: KLIMA 3 ZONEN H04 0122
Revision: D1000000 Serial number: 01030320150629
Coding: 342402E000
VCID: 6ADC58678533306EE8-803E
4 Faults Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 18:49:49
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 45
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 18:49:50
Freeze Frame:
Temperature: 18.0°C
01592 - Air Quality Sensor (G238)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 18:49:51
Freeze Frame:
Temperature: 18.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 18:49:54
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001023523901
Coding: 260000108034AFC00081400300001D0D001D070827090201000008004400020100000024000000
VCID: 78F8722FCB9F92FE6E-802C
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 190215 H06 0080
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
4 Faults Found:
03020 - Local databus 2
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 18:49:49
02069 - Front Parking Aid Sensors
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 18:51:42
01500 - Bulb for Fog-Lamps; Right (L23)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 86
Mileage: 2692 km
Time Indication: 0
Date: 2015.08.29
Time: 19:43:59
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 2692 km
Time Indication: 0
Date: 2015.08.29
Time: 19:43:59
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H48 0610
Serial number: 003KFDC673YR
Coding: 30534435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4898C2EFF3FF227EDE-801C
Crash sensor for side airbag; driver side:
Serial number: 6334MSME4F0A7421G
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME4F0D0B5E-
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME2E584268Q
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME31583F40H
Crash sensor for front airbag; driver side:
Serial number: 63732SME01105760J
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME250F3B643
No fault code found.
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OC2000PL
Coding: 000017
VCID: 4898C2EFFBFF227EDE-801C
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 983 G HW: 8K0 920 983 G
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 61+603R2G
Coding: 33A4100003012600010000
VCID: 397EB72BB0154BF651-806C
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y152240264
Coding: 80CF07FF00
VCID: 4A9CF8E7E5F3D06EC8-801E
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 86
Mileage: 2692 km
Time Indication: 0
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.00 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0510
Revision: Serial number: 0000137928592
Coding: 011002204001410001
VCID: 50A8EA8F03AFEABE86-8004
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 P HW: 8K0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0006486998
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X.rod
VCID: 3E74A437A13B6CCE64-806A
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0361330527
Coding: 013B0622A0B930408320023680000047
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
2 Faults Found:
00166 - Access/Start Authorization Switch (E415)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 86
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 18:49:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 86
Mileage: 2692 km
Time Indication: 0
Date: 2015.08.29
Time: 22:15:43
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0510
Revision: Serial number: 0000137939532
VCID: 4FAAE9F31E91F5469F-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 30000000342598
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A7CA827BD1340EE58-806E
1 Fault Found:
463616 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 2690 km
Date: 2015.08.29
Time: 18:49:47
Address 56: Radio ® Labels: Redir Fail!
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109CX0F8019038
Coding: 010103020100000001
VCID: 2B529D634A49E966D3-807E
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 666 H HW: 8R2 035 666 H
Component: H-BN-EU H48 0897
Revision: -------- Serial number: 515CU0F7514404
Coding: 0F0101010006A1ED01808B5E00000403E40000020000000000
VCID: 3E74A437A93B6CCE64-806A
Subsystem 1 - Part No: 8R0 060 884 CH
Component: EUR 2014 2004
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000139265420
Coding: 010002204001210001
VCID: 4684CCD7F1EB340E2C-8012
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 C HW: 8K9 827 851 C
Component: J605 Master H53 0330
Revision: -------- Serial number: 8K9827851C
Subsystem 1 - Part No SW: 8K9 827 852 C HW: 8K9 827 852 C
Component: J756 Slave H53 0330
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000139265421
End-------------------------(Elapsed Time: 03:06)--------------------------
Coding: 171DCC01
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 19:01:11
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4082
Hex Value: 0x0004
Hex Value: 0xC896
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 19:01:11
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4082
Hex Value: 0x000D
Hex Value: 0x8596
Hex Value: 0x0000
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 19:01:13
a twoj VCDS ma podpowiedzi ?
musisz wykodowac skrzynie zrobic adapatcje oraz przyuczyc VIN
Coding: 171DCC01
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 19:01:11
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4082
Hex Value: 0x0004
Hex Value: 0xC896
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 19:01:11
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4082
Hex Value: 0x000D
Hex Value: 0x8596
Hex Value: 0x0000
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 46
Mileage: 2690 km
Time Indication: 0
Date: 2015.08.29
Time: 19:01:13
dzieki
tak ma podpowiedzi ale nie do tego modelu, tak wiem co ale on jest zakodowany 171DCC01 i stat jest problem, chcac zrobic adaptacje musze zmienic kodowanie ale brak podpowiedzi z VCDS i nie moge nigdzie znalezc podpowiedzi, tu jest zakodowana automatyczna skrzynia a w auto jest wyposazone w manual stad blad 01315,
Edytowane przez piotrek66
To trzeba bawic sie w poszczególne Bity metoda prób i błedów :) ktorys odpowiada za skrzynie
Takie znalazłem na szybko w necie
03DD4C01
03DD4C01
dzieki , zmudna robota ale jak nie bedzie wyjscia tak bede robial, no dobrze a co z zakodowaniem vin? za skrzynie prawdopodobnie ostatni ale nie jestem pewien. a to kodowanie to jest z auto czy manual?
a skąd go zdobyć?
czy to jest przez security access?
ok vin wgrany , ale nadal poszukuje kodowania, ten kod ktory podal kolega nie idzie
U mnie w aucie z 2009 ABS ma tylko 3 Bajty ,kodowanie typu skrzyni jest w Bajcie srodkowym - podpowiedzi w VCDS oczywiscie nie ma ,metoda prob i bledow.
Tutaj widze ze jest 4 Bajty ,wiec ciezko powiedziec .... moze ktorys srodkowy
Login powinien Ci sie pojawic w podpowiedziach w VCDS.
dzieki, login sie nie pojawia, ale juz ogarnolem temat. login 61378, taki wcodzi tu podziekowania dla Pana Michala z kujawsko pomorskiego. natomiast co do kodu metoda prob i bledow 031D4C01na takim kodzie zgasly kontrolki. jeszcze tylko od PB swieci na zielono ale nie przypuszczam zeby bylo to zwiazane z kodowaniem ABS. jutro zeskanuje jeszcz raz i zobacze co sie dzieje. dam znac
temat zamykam
sprawa wyglada tak , auto trafilo do dilera stwierdzil absolutnie zle kodowanie abs, po odbiorze podpiolem vcds i co widze te same kodowanie co ja zrobilem skasowali 140 funtow i mnie w banbuko zrobili. musieli zakodowac inny modul . ale to juz przeszlosc. tak wiec dla potomnych audi a4 kombi z 2015 skrzynia manualna 18 calowe felgi bez chaka z elektonicznym recznym kod dostepu 61378 i kodowanie 031D4C01. sprawdzone. dziekuje wszystkim za zainteresowanie
