Błędy z B7 1.8T
Witam,
zczytałem wszystkie błędy jakie mam w Andzi i ponieżej wynik. Jak by ktoś mógł rzucić tylko okiem czy jest coś czym powinienem się szczególnie zainteresować. Z góry wielkie dzięki.
Monday,28,March,2016,16:41:31:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8E55A416089   License Plate:
Mileage: 188330km-117022mi   Repair Order:
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
          67 69 75 76 77
VIN: WAUZZZ8E55A416089   Mileage: 188330km/117022miles
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 8E0 909 518 AQ    HW: 8E0 909 018 B
   Component: 1.8L R4/5VT         0010
   Coding: 0011501
   Shop #: WSC 06325 000 00000
   VCID: 7F0DE5772D08A7E6ED9-5072
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 B    HW: 8E0 614 517 AT
   Component: ESP8 front      H04 0180
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0004871
   VCID: 264310139112D62ECEF-8073
1 Fault Found:
01314 - Engine Control Module
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 40
                    Time Indication: 0
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x0722
                    Hex Value: 0x00FF
                    Hex Value: 0xFF95
                    Hex Value: 0x00FF
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 AK
   Component:   A4 Klimaautomat   2728
   Coding: 00000
   Shop #: WSC 06325
   VCID: 6ADB2423168A324E2A7-5072
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0304
   Coding: 10021
   Shop #: WSC 06325
   VCID: 3B75D16729907BC6811-4A9C
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036M000DYXP
   Coding: 0033622
   VCID: 3B75D1677A907BC6811-806E
   Subsystem 1 - Serial number: 6332DRB400DD8A11T
   Subsystem 2 - Serial number: 6342DRB400DBCE0B2
   Subsystem 3 - Serial number: 6352ARB40031C4FEV
   Subsystem 4 - Serial number: 6362ARB40031C188G
   Subsystem 5 - Serial number: 63729RB40031E61CK
   Subsystem 6 - Serial number: 63829RB40031E526F
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 99
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 S
   Component: Lenksáulenmodul     0611
   Coding: 01012
   Shop #: WSC 06325
   VCID: 4385A98751600306C91-4A3A
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 900 Q    HW: 8E0 920 900 Q
   Component: KOMBI+WFS 3     H12 0020
   Revision: 0020        Serial number: AUX6Z0D0440262
   Coding: 0004041
   Shop #: WSC 80093 222 69422
   VCID: 326BFC43AEDABA8E527-5072
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0004041
   VCID: 326BFC43AEDABA8E527-50E6
2 Faults Found:
            004 - No Signal/Communication - Intermittent
01304 - Radio
Address 46: Central Conv.        Labels: 8E0-959-433-MIN.lbl
   Part No: 8E0 959 433 BG
   Component: Komfortgerát T85    2431
   Coding: 07024
   Shop #: WSC 06325
   VCID: 77FD0D5755389FA6A59-4A3A
   Subsystem 1 - Part No: 8E1959801B
   Component: Tőrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8E1959802B
   Component: Tőrsteuer.BF BRM 0205
Address 55: Xenon Range        Labels: 8P0-907-357.lbl
   Part No: 8P0 907 357 B
   Component: Dynamische LWR  H01 0010
   Revision: 00000001    Serial number:
   Coding: 0000005
   VCID: 3979CB6F70AC49D693D-806C
1 Fault Found:
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 0
                    Reset counter: 38
                    Time Indication: 0
Address 77: Telephone        Labels: None
   VCID: 55A167DFBFF48DB6975-5072
No Faults Found
End   ---------------------------------------------------------------------
Nie ma się czym przejmować.
a czy ten błąd z poduszką oznacze może zę była np. wymieniana ?
  • 5 lat później...
Nie chcę zakładać nowego tematu może ktoś opowie.
Wczoraj podczas ulewnego deszczu zapaliła się kontrolka esp i żółty piktogram z samochodzikiem.
Auto jechało normalnie i miało moc.
Po odczytaniu błędów a abs był 01314 .
Co może zwiastować taki błąd i gdzie zajrzeć aby nie rozwinęło się coś dalej ?
