Ciacho 0 Opublikowano 7 Grudnia 2008 Udostępnij Opublikowano 7 Grudnia 2008 VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 LF Component: 1,9l R4 EDC 0000SG 4907 Coding: 00002 Shop #: WSC 63251 WAUZZZ8E14A084263 AUZ6Z0C0237282 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 3429 Coding: 04155 Shop #: WSC 06435 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AB Component: A4 Klimaautomat 1219 Coding: 00000 Shop #: WSC 63251 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 09 ------------------------------------------------------- Controller: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00001 Shop #: WSC 63251 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 00012 Shop #: WSC 63251 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 17 ------------------------------------------------------- Controller: 8E0 920 930 R Component: KOMBI+WEGFAHRS. RB4 D37 Coding: 00000 Shop #: WSC 11111 84263 AUZ6Z0C0237282 1 Fault Found: 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent Address 37 ------------------------------------------------------- Controller: 4B0 919 887 E Component: BNS 4.2 H05 BNO 0050 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BA Component: Komfortgerát TA7 1310 Coding: 06976 Shop #: WSC 06435 2 Faults Found: 01559 - Drivers Door 59-10 - Can't Unlock - Intermittent 01705 - Selection Switch for Mirror-Adjust (E48) 27-10 - Implausible Signal - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 152 C Component: chorus II GRO 0001 Coding: 01010 Shop #: WSC 63251 2 Faults Found: 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent Address 76 ------------------------------------------------------- Controller: 8E0 919 283 A Component: Parkingsyst. A4 RDW D08 Coding: 00114 Shop #: WSC 63251 No fault code found. End ------------------------------------------------------- Witam Ostatnio na spocie Kolega podłączył vaga pod moje autko i w rezultacie otrzymałem coś takiego. ogólnie jest parę błędów, ale najbardziej interesuje mnie Skipping Address 15-Airbags jaka może być tego przyczyna ? mile widziane tez info o innych błędach co do błędu z navi to widziałem ze nie tylko ja taki mam ale to nie utrudnia pracy navi. 01705 - Selection Switch for Mirror-Adjust (E48) 27-10 - Implausible Signal - Intermittent Czy ten błąd może być związany z niedziałającym podgrzewaniem jednego z lusterek ? z góry THX Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
szogun0 9 Opublikowano 7 Grudnia 2008 Udostępnij Opublikowano 7 Grudnia 2008 Tak miał zaznaczone w AutoScan i dlatego pominęło poduszki. Cioś kombinowałeś z przekładaniem elementów? Panel klimy z niepoprawnym VIN-em. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Ciacho 0 Opublikowano 8 Grudnia 2008 Autor Udostępnij Opublikowano 8 Grudnia 2008 ja nie Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
boberek 4 Opublikowano 8 Grudnia 2008 Udostępnij Opublikowano 8 Grudnia 2008 no to pare rzeczy jest źle pokodowane i nie przuczone VINu Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
