sikszak Opublikowano 31 Stycznia 2017 Opublikowano 31 Stycznia 2017 kupiłem ori wzmacniacz do radia concert. zrobiłem do niego instalację zgodnie ze schematem podłączyłem wszystko i niestety nie mam nawet grama dżwięku. Po podłączeniu kompa mam takie błędy: Tuesday,31,January,2017,00:25:46:62939 VCDS Version: Release 12.12.0 (x64) Address 56: Radio Labels: 8Tx-035-1xx-56.clb Control Module Part Number: 8T1 035 186 B HW: 8T1 035 186 B Component and/or Version: Concert3 H13 0150 Software Coding: 050004820402C50D815B870002 Work Shop Code: WSC 06335 000 00000 VCID: 3663C05381B2A6AE7EF-8063 4 Faults Found: 00870 - Bass Speaker Front Left (R21) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 237 Mileage: 188356 km Time Indication: 0 Date: 2017.01.31 Time: 00:23:29 00871 - Bass Speaker Front Right (R23) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 237 Mileage: 188356 km Time Indication: 0 Date: 2017.01.31 Time: 00:23:29 00872 - Bass Speaker Rear Left (R15) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 237 Mileage: 188356 km Time Indication: 0 Date: 2017.01.31 Time: 00:23:29 00873 - Bass Speaker Rear Right (R17) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 237 Mileage: 188356 km Time Indication: 0 Date: 2017.01.31 Time: 00:23:29 Tuesday,31,January,2017,00:26:55:62939 VCDS Version: Release 12.12.0 (x64) Address 19: CAN Gateway Labels: 8T0-907-468.clb Control Module Part Number: 8T0 907 468 N HW: 8T0 907 468 J Component and/or Version: GW-BEM 6CAN H06 0095 Software Coding: 000303 Work Shop Code: WSC 02391 823 56573 VCID: 4C9782BBEF3ECC7E38B-8019 Fault Codes have been Erased 1 Fault Found: 03041 - Energy Management Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 237 Mileage: 188356 km Time Indication: 0 Date: 2017.01.31 Time: 00:26:00 Co może być przyczynę ich wyskakiwania?
olinek2 Opublikowano 31 Stycznia 2017 Opublikowano 31 Stycznia 2017 Masz kodowanie z mojego auta56 Radio Długie kodowanie: 0502008201028500C17B870100Oczywiście zapisz Twoje oryginalne. Czy gateway widzi Ci wzmacniacz? Bo wygląda jakby nie widział albo nie był wkodowany w gatewaya. Zasilanie na wzmacniaczu jest?
wrclaguna Opublikowano 31 Stycznia 2017 Opublikowano 31 Stycznia 2017 VCDS ma podpowiedzi ( nagłosnienie) jesli chodzi o Radio 56
sikszak Opublikowano 31 Stycznia 2017 Autor Opublikowano 31 Stycznia 2017 dodałem w wyposażeniu CAN GATEWAY sound system i błąd w CAN zniknął dalej mam błąd przerwy w obwodzie głośników. Co ciekawe jak wejdę w button SOUNDSYSTEM żeby zobaczyć co się tam ukrywa to nagle zaczynają mi grać głośniki ale tylko lewa strona, prawa milczy. Jak tylko zamykam okno sound system znów nic nie gra. Pojawił się za to błąd ( oprócz błędu obwodu głośników): Tuesday,31,January,2017,18:12:39:62939 VCDS Version: Release 12.12.0 (x64) Address 47: Sound System Labels: 8T0-035-223-ASC.clb Control Module Part Number: 8T0 035 223 J HW: 8T0 035 223 Component and/or Version: DSP STD H07 0210 Software Coding: 0203010102 Work Shop Code: WSC 06335 000 00000 VCID: 3561C75F9CB4ADB6775-8060 1 Fault Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 239 Mileage: 188400 km Time Indication: 0 Date: 2017.01.31 Time: 18:11:17 Freeze Frame: Voltage: 11.80 V Temperature: 12.0°C Bin. Bits: 00000000 jak wchodzę w Radio 56 i chcę zaznaczyć Standard sound system to niby akceptuje kodowanie ale go nie zapisuje i kodowanie zostaje stare Co robię źle?
olinek2 Opublikowano 31 Stycznia 2017 Opublikowano 31 Stycznia 2017 Jak lewa gra a prawa nie to Component do zdjęcia [emoji6]Standard przy wzmacniaczach.
sikszak Opublikowano 31 Stycznia 2017 Autor Opublikowano 31 Stycznia 2017 a z którego sterownika należy ściągnąć CP? I czy takie właśnie są objawy że jest nie ściągnięta, że działają tylko lewe głośniki i tylko jak wejdę przez VCDSa w sound system? normalnie nie działają żadne głośniki tylko jak wejdę w sound system zaczynają grać lewe, wyjdę i przestają grać. Czy mogę mieć pewnośc, że jak ściągnę CP wszystko zacznie działać?
wrclaguna Opublikowano 31 Stycznia 2017 Opublikowano 31 Stycznia 2017 jak sciagniesz CP to wszystko zagra
olinek2 Opublikowano 31 Stycznia 2017 Opublikowano 31 Stycznia 2017 Tak bez CP prawie nie działa. W3G high działa dźwięk tylko jak w fadery się wejdzie
sikszak Opublikowano 7 Lutego 2017 Autor Opublikowano 7 Lutego 2017 (edytowane) Ściągnąłem dzisiaj CP i dalej nie gra cały czas mam błąd przerwy między głośnikami. Jak wejdę w soundtrack system to wtedy głośnik zaczynają działać. Po ściągnięciu CP gra lewa i prawa strona wszystko fajnie do czasu aż wyjdę z tej zakładki. Wtedy znów cisza. Nie potrafię zakodowac w radio56. Zaznaczam tam opcje standard sound system . Niby przyjmuje kodowanie ale go nie zapisuje. Może powinienem coś innego kodować? Nie potrafię rozszyfrować podpowiedzi vcdsa. Powyżej dałem screeny co mi się pojawia jak koduję oraz co chcę zakodować. Co robię źle Edytowane 7 Lutego 2017 przez sikszak
