komoornik Opublikowano 4 Maja 2017 Opublikowano 4 Maja 2017 (edytowane) Dzisiaj zauważyłem że klimatyzacja praktycznie nie działa (potrafi włączyć się tylko na chwilę). Wednesday,04,May,2016,15:32:42:49450 VCDS Version: Release 16.8.0 Running on Windows 7 x64 www.Ross-Tech.com Address 08: Auto HVAC Labels: Redir Fail! Control Module Part Number: 8T1 820 043 AP HW: 8T1 820 043 AP Component and/or Version: KLIMA 3 ZONEN H08 0180 Software Coding: 64080000 Work Shop Code: WSC 06325 123 12345 VCID: 7F0D699AEE3C56BAD9-802A 5 Faults Found: 01207 - Control Module for Auxiliary Heater (J364) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 52 Mileage: 230474 km Time Indication: 0 Date: 2016.12.23 Time: 12:55:23 00457 - Control Module for Network (J519) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 18 Reset counter: 238 Mileage: 234438 km Time Indication: 0 Date: 2017.05.04 Time: 11:27:12 00256 - A/C Pressure/Temperature Sensor (G395) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 7 Fault Frequency: 20 Reset counter: 238 Mileage: 234438 km Time Indication: 0 Date: 2017.05.04 Time: 11:27:12 Freeze Frame: Temperature: 12.0°C 01592 - Air Quality Sensor (G238) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 20 Reset counter: 238 Mileage: 234438 km Time Indication: 0 Date: 2017.05.04 Time: 11:27:14 Freeze Frame: Temperature: 12.0°C 00256 - A/C Pressure/Temperature Sensor (G395) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 11 Reset counter: 23 Mileage: 234439 km Time Indication: 0 Date: 2017.05.04 Time: 11:46:46 Freeze Frame: Temperature: 13.0°C Temperature: 75.0°C Load: 0.0 % Absolute Pres.: 0.2 bar RPM: 960 /min Speed: 0.0 km/h Current: 0.000 A Temperature: 22.0°C Wednesday,04,May,2016,15:33:37:49450 VCDS Version: Release 16.8.0 Running on Windows 7 x64 www.Ross-Tech.com Address 09: Cent. Elect. Labels: 8K0-907-063.clb Control Module Part Number: 8K0 907 063 N HW: 8K0 907 063 N Component and/or Version: BCM1 1.0 H30 0392 Software Coding: 260050914174AF211701000000001D0D4F1C474C02010141000000 Work Shop Code: WSC 06325 123 12345 VCID: 3A7B588EB59EB392AE-806E 4 Faults Found: 03020 - Local databus 2 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 26 Reset counter: 238 Mileage: 234438 km Time Indication: 0 Date: 2017.05.04 Time: 09:07:00 01592 - Air Quality Sensor (G238) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 23 Mileage: 234476 km Time Indication: 0 Date: 2017.05.04 Time: 14:18:00 01592 - Air Quality Sensor (G238) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 11 Reset counter: 23 Mileage: 234439 km Time Indication: 0 Date: 2017.05.04 Time: 11:48:00 03207 - Charisma Switch Module 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 23 Mileage: 234439 km Time Indication: 0 Date: 2017.05.04 Time: 11:48:00 Nie działa też Drive Select. Najbardziej zastanawia mnie błąd 03020 - Local databus 2. Co to może być? Ostatnio naprawiałem samopoziomowanie - ale przez kilka tyg. było wszystko ok. Rozciąłem wtedy co prawda dwa przewody masy (szukając przewodu który idzie do lampy po stronie kierowcy), ale zlutowałem je ponownie. Edytowane 4 Maja 2017 przez komoornik
komoornik Opublikowano 4 Maja 2017 Autor Opublikowano 4 Maja 2017 Ok, doczytałem - miejmy nadzieje że wymiana G395 rozwiąże problem.
