czorny27 Opublikowano 10 Maja 2017 Opublikowano 10 Maja 2017 Witam. Wczoraj robiłem pierwszy raz skan altka. Kilka błędów wyskoczyło. Dodam, że żadne kontrolki na blacie się nigdy nie świeciły, ani czeki ani abs itp. Wszystko ładnie gaśnie. Gdzie zacząć szukać???? Address 01: Engine Labels: 06B-907-557-ALT.lbl Part No SW: 8E0 909 557 R HW: 8E0 909 057 B Component: 2.0L R4/5VS G 0010 Coding: 0011501 Shop #: WSC 12345 123 12345 VCID: 428CD2271E9C762E0B-5072 3 Faults Found: 18062 - Please check DTC Memory of Instrument Cluster P1654 - 004 - - Intermittent 16523 - Oxygen (Lambda) Sensor B1 S2 P0139 - 004 - Response too Slow - Intermittent 16524 - Oxygen (Lambda) Sensor B1 S2 P0140 - 004 - No Activity - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.clb Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT Component: ESP8 front H04 0180 Revision: 00000000 Serial number: 00000000000000 Coding: 0004867 Shop #: WSC 06314 000 00000 VCID: 26446EB791F4AA0E07-8072 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AJ Component: A4 Klimaautomat 2831 Coding: 00000 Shop #: WSC 00000 VCID: 69DE258B136A4576EA-5072 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 J Component: int. Lastmodul ECE 0503 Coding: 00041 Shop #: WSC 06314 VCID: 397EB5CB234A35F65A-4A3A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H11 3530 Revision: 91H1135 Serial number: 0036M003NHWK Coding: 0033622 Shop #: WSC 06314 000 00000 VCID: 3B72AFC37A7607E648-806E Subsystem 1 - Serial number: 6332DRB401458D25L Subsystem 2 - Serial number: 6342DRB40144CBB4V Subsystem 3 - Serial number: 6352ARB400526982E Subsystem 4 - Serial number: 6362ARB4005079D5M Subsystem 5 - Serial number: 63729RB4005D8DAA% Subsystem 6 - Serial number: 63829RB4005D8D51T 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 39 Time Indication: 0 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0601 Coding: 02041 Shop #: WSC 06314 VCID: 418EDD2B4B9A6D3612-4A3A No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 900 Q HW: 8E0 920 900 Q Component: KOMBI+WFS 3 H12 0030 Revision: 0030 Serial number: AUX6Z0E0008173 Coding: 0006141 Shop #: WSC 00850 259 99283 VCID: 326C82E7AE3CC6AE9B-5072 Subsystem 1 - Part No: 8E0 920 900 Q Component: KOMBI+WFS 3 H12 0030 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 900 Q HW: 8E0 920 900 Q Component: KOMBI+WFS 3 H12 0030 Coding: 0006141 Shop #: WSC 00850 259 99283 VCID: 326C82E7AE3CC6AE9B-5000 Subsystem 1 - Part No: 8E0 920 900 Q Component: KOMBI+WFS 3 H12 0030 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 VCID: 6BD25F831996576698-5072 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BM Component: Komfortgerát T3B 2431 Coding: 06778 Shop #: WSC 06314 VCID: 7DF661DB77E2C9D636-4A3A Subsystem 1 - Part No: 8E1959801F Component: Tőrsteuer.FS BRM 1315 Subsystem 2 - Part No: 8E1959802E Component: Tőrsteuer.BF BRM 0205 Subsystem 3 - Part No: 8E0959801A Component: Tőrsteuer.HL BRM 0205 Subsystem 4 - Part No: 8E0959802A Component: Tőrsteuer.HR BRM 0205 1 Fault Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 B Component: Dynamische LWR H01 0020 Revision: 00000001 Serial number: Coding: 0000005 Shop #: WSC 06314 000 00000 VCID: 397EB5CB704A35F65A-806C No fault code found. End-------------------------(Elapsed Time: 08:04)--------------------------
rogigor Opublikowano 10 Maja 2017 Opublikowano 10 Maja 2017 Skasuj i zrób ponownie za jakiś czas. Wszystkie masz jako "intermittent" czyli mogło raz coś wyskoczyć i już nigdy więcej się nie pojawiło, ale komputer zapamiętał. Jak wróci to możesz zacząć się martwić.
czorny27 Opublikowano 10 Maja 2017 Autor Opublikowano 10 Maja 2017 Yhymm w takim razie tak zrobię. Jeszcze nie jestem kurcze aż tak oblatany. Czyta mczytam i czytam lekturę o diagnostyce ale kilka się posypało i szczerze się zdziwiłem bo niby auto chodzi ok wszystkie kontrolki ładnie gasną podczas jazdy też jest ok.
