Odczytanie błedów po scanie auta
Auto to Audi A5.
Chassis Type: 8T (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56
VIN: WAUZZZ8T59A020300 Mileage: 173920km-108068miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (------CABD) Labels: 06H-907-115-CAB.clb
Part No SW: 8T0 907 115 A HW: 8K1 907 115
Component: 1.8l R4/4V TF H07 0004
Revision: A5H07---
Coding: 0114000318070018
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM18TFS8T0907115A A01004
ROD: EV_ECM18TFS8K1907115B.rod
VCID: 34677AF59FEAFCE11B-8060
4 Faults Found:
2796 - Camshaft Positioner (Bank 1 Intake)
P000A 00 [096] - Slow Response
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 88
Mileage: 173829 km
Date: 2017.07.05
Time: 08:04:55
Engine speed: 1159.00 /min
Normed load value: 12.5 %
Vehicle speed: 35 km/h
Coolant temperature: 48 °C
Intake air temperature: 18 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.193 V
4113 - Camshaft Position Sensor (G40)
P0341 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 173124 km
Date: 2017.06.11
Time: 16:02:48
Engine speed: 396.00 /min
Normed load value: 54.9 %
Vehicle speed: 0 km/h
Coolant temperature: 78 °C
Intake air temperature: 53 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 10.865 V
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [104] - Incorrect Correlation
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 229
Mileage: 168322 km
Date: 2016.11.20
Time: 17:04:32
Engine speed: 800.00 /min
Normed load value: 22.7 %
Coolant temperature: 60 °C
Intake air temperature: 10 °C
5664 - Mass Air Flow Sensor (G70)
P0100 00 [096] - Supply Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 173216 km
Date: 2017.06.17
Time: 21:26:41
Engine speed: 1103.50 /min
Normed load value: 29.0 %
Coolant temperature: 65 °C
Intake air temperature: 51 °C
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 030500
VCID: 78FF8EC5CB02D881F7-802C
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 56
Mileage: 173216 km
Time Indication: 0
Date: 2017.06.17
Time: 21:26:42
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0009
Hex Value: 0x468E
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 56
Mileage: 173216 km
Time Indication: 0
Date: 2017.06.17
Time: 21:26:47
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x62A2
Hex Value: 0x0013
Hex Value: 0x02A9
Hex Value: 0x00FF
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0102.09.080688
Coding: 64060000
VCID: 428B2C2DDD5E425199-8016
1 Fault Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 254
Reset counter: 33
Mileage: 158258 km
Time Indication: 0
Date: 2008.05.27
Time: 00:37:18
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000217569
Coding: 260050914234AF000009000000005D5D001D038800010141000000
Shop #: WSC 06325 123 12345
VCID: 2F6D75997ECCDF3966-807A
Subsystem 1 - Part No SW: 8T2 955 119 C HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 260808 H11 0040
Serial number: SWF08080260376
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10254606
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000001009081357
1 Fault Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Reset counter: 33
Mileage: 158258 km
Time Indication: 0
Date: 2008.05.27
Time: 00:37:00
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0094
Revision: 4GB20042 Serial number: 4200G0882280D9
Coding: 000303
VCID: 4683303DF1767E71B5-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18040128220808
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 71
Mileage: 173884 km
Time Indication: 0
Date: 2017.07.05
Time: 13:08:00
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 10000000096384
Shop #: WSC 00000 000 00000
VCID: 316973E168F8C9C970-8064
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 56
Mileage: 173216 km
Time Indication: 0
Date: 2017.06.17
Time: 21:26:47
Freeze Frame:
Voltage: 13.70 V
Count: 58
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1010
02433 - Supply Voltage for Right Parking Brake Motor (V283)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 91
Mileage: 168440 km
Time Indication: 0
Date: 2016.11.24
Time: 17:51:04
Freeze Frame:
Voltage: 14.10 V
Count: 13
Speed: 0.0 km/h
Hex Value: 0x02E1
Hex Value: 0x0021
Hex Value: 0x0801
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000001
Shop #: WSC 06324 000 00000
VCID: 34677AF557EAFCE11B-8060
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 214
Mileage: 171777 km
Time Indication: 0
Date: 2017.04.06
Time: 21:01:36
*Pierwsze to należy się przywitać w odpowiednim dziale, a potem szukać pomocy. ->Nowicjusz
Zapraszam również tu ->Regulamin.
Ja niestety nie pomorze, bardziej dolny śląsk
wpadaj zrobimy autko :hi:
1 minutę temu, łukasza41406839682 napisał:
Uzupełnij sobie PROFIL
