[B5 AWT] Proszę o analizę błędów
Zrobilem pelny test WAGiem i oto wynik. Moglby ktos toto zinterpretowac mi, czy jest cos do robienia itp. A ja tymczasem przeszukam forum :)
Z gory dziekuje !!
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 CG
Component: 1.8L R4/5VT 0002
Coding: 11001
Shop #: WSC 63351
WAUZZZ8DZ1A131815 AUZ7Z0A1778266
4 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AM
Component: ABS 5.3 FRONT D30
Coding: 0273004282
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 M
Component: A4 KLIMA
Coding: 00040
Shop #: WSC 63351
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 932 G
Component: B5-KOMBIINSTR. VDO D12
Coding: 00144
Shop #: WSC 02507
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 C
Component: ZV-Pumpe D16
Coding: 02049
Shop #: WSC 63351
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00201
Shop #: WSC 63351
End -------------------------------------------------------
A dodam, ze bledy imobilajzera i zlego "polaczenia" z tablica wynikaja z montazu ramek wokol zegarow i niedopchniecia jednej wtyczki :)
To jak przeszukasz forum i nie znajdziesz to napisz do mnie PW to otworzę wątek.
Poczytaj też o kasowaniu błędów i sprawdzaniu czy wracają.
Na tą chwilę zamykam.
Gość
