Błędy 1.8T AVJ
Witam.
Może ktoś pomóc w interpretacji kodów błędów?
VCDS-Lite Version: Release 1.2
Sunday, 15 July 2018, 17:11:01:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine       Labels: Redir Fail!
   Controller: 8E0 909 518
   Component: 1.8L R4/5VT         0001
   Coding: 0011501
   Shop #: WSC 63351
   VCID: EDADCAB7B489
3 Faults Found:
17698 -  Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
            P1290 - 002 -  Lower Limit Exceeded - Intermittent
16804 -  Catalyst System; Bank 1: Efficiency Below Threshold
            P0420 - 002 -  Lower Limit Exceeded
17522 -  Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
            P1114 - 008 -  Implausible Signal
Readiness: 0000 0000
Address 03: ABS Brakes       Labels: 8E0-614-517.LBL
   Controller: 8E0 614 517
   Component: ABS/ESP front       1726
   Coding: 04275
   Shop #: WSC 06435
   VCID: E5BDB2976C79
No fault code found.
Address 08: Auto HVAC       Labels: 8E0-820-043.LBL
   Controller: 8E0 820 043
   Component:   A4 Klimaautomat   0712
   Coding: 00000
   Shop #: WSC 63351
   VCID: DECF9D7B492F
2 Faults Found:
01274 -  Air Flow Flap Positioning Motor (V71)
            41-10 -  Blocked or No Voltage - Intermittent
00604 -  Potentiometer Positioning Motor for Air Flow Flap (G113)
            30-10 -  Open or Short to Plus - Intermittent
Address 09: Cent. Elect.       Labels: 8E0-907-279-8E2.LBL
   Controller: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00001
   Shop #: WSC 63351
   VCID: 341B9FD31723
Address 15: Airbags       Labels: 8E0-959-655-84.LBL
   Controller: 8E0 959 655
   Component: Airbag 8.4E         3001
   Coding: 0010602
   Shop #: WSC 63351
   VCID: F49BDFD3D7A3
Address 16: Steering wheel       Labels: 8E0-953-549.LBL
   Controller: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 02012
   Shop #: WSC 63351
   VCID: 3C0BB7F33F73
Address 17: Instruments       Labels: 8E0-920-9xx-8E2.LBL
   Controller: 8E0 920 900 H
   Component: KOMBI+WEGFAHRS. RB4 D25
   Coding: 00000
   Shop #: WSC 00186
   VCID: 29257EA7C0E1
   WAUZZZ8E32A146291     AUZ6Z0A0267157
Address 46: Central Conv.       Labels: 8E0-959-433-MIN.LBL
   Controller: 8E0 959 433 AD
   Component: Komfortgerát T85    0315
   Coding: 06976
   Shop #: WSC 63351
   VCID: 73995CCF52AD
6 Faults Found:
01561 -  Left Rear Door
            59-10 -  Can't Unlock - Intermittent
            61-10 -  Won't De-Safe - Intermittent
01331 -  Door Control Module; Driver Side (J386)
            80-00 -  Single-Wire Operation
01560 -  Passenger Door
01812 -  Supply Voltage for Door Controller; Pass. Side (J387)
            37-10 -  Faulty - Intermittent
01802 -  Door Warning Lamp; Pass Side (W36)
            57-10 -  Electric Circuit Failure - Intermittent
Address 56: Radio       Labels: 8E0-035-1xx-56.LBL
   Controller: 8E0 035 186
   Component: concert II  GRO    0007
   Coding: 00005
   Shop #: WSC 63351
   VCID: E4BBAF936743
1 Fault Found:
00852 -  Loudspeaker(s); Front
            36-10 -  Open Circuit - Intermittent
End   --------------------------------------------------------------------------------------------------
Jeśli chodzi o błędy silnika to sprawdz czujnik temp ( możesz mieć dwa jeden dla komputera jeden dla licznika dla wskazówki ) oba musza poprawnie wskazywać  ,  drugi bład jest to od katalizatora efektywność poniżej poziomu ( bład może wywalać róznież w zwiazku z walnientym czujnikiem tem. płynu za pomocą którego ustalana jest mieszanka paliwowo powietrzna) a trzeci bład to za duża rezystancja wewnętrzna sondy lambda  poprostu moze być walnieta lub kabelki:D
