martin a4 Opublikowano 5 Marca 2009 Opublikowano 5 Marca 2009 ,Group A:,'013,,,,Group B:, Not Running,,,,Group C:, Not Running ,,Cyl 1,Cyl 2,Cyl 3,Cyl 4,,,,,,,,,, ,TIME,-2.8 to +2.8 mg/H,-2.8 to +2.8 mg/H,-2.8 to +2.8 mg/H,-2.8 to +2.8 mg/H,TIME,,,,,TIME,,,, Marker,STAMP, mg/str, mg/str, mg/str, mg/str,STAMP,,,,,STAMP,,,, ,0.00,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,0.34,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,0.72,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,1.07,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,1.43,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,1.79,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,2.15,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,2.50,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,2.85,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,3.21,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,3.57,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,3.93,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,4.29,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,4.66,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,5.05,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,5.43,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,5.83,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,6.22,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,6.61,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,7.00,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,7.39,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,7.78,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,8.17,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,8.56,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,8.95,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,9.34,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,9.73,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,10.12,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,10.51,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,10.90,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,11.26,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,11.62,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,11.97,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,12.33,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,12.69,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,13.05,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,13.41,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,13.77,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,14.13,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,14.49,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,14.85,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,15.21,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,15.57,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,15.93,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,16.29,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,16.66,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,17.02,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,17.41,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,17.81,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,18.20,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,18.59,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,18.98,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,19.36,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,19.71,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,20.07,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,20.43,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,20.80,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,21.15,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,21.51,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,21.86,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,22.22,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,22.58,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,22.94,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,23.30,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,23.66,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,24.02,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,24.38,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,24.74,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,25.10,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,25.46,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,25.82,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,26.18,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,26.54,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,26.90,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,27.26,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,27.64,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,28.03,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,28.42,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,28.81,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,29.20,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,29.59,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,29.95,-1.25,-0.16,0.66,0.73,,,,,,,,,, ,30.31,-1.25,-0.16,0.66,0.73,,,,,,,,,,
boberek Opublikowano 5 Marca 2009 Opublikowano 5 Marca 2009 jaki przebieg ?? jedna troche przypchana jest a reszta raczej nie ma co sie przejmowac ja mam podobne przy przebiegu 300 kkm
boberek Opublikowano 5 Marca 2009 Opublikowano 5 Marca 2009 pewnie przez to ze masz zalanego castrola i wkładke KN a to TDI tego nie lubi
martin a4 Opublikowano 5 Marca 2009 Autor Opublikowano 5 Marca 2009 mam motula specific 5w30 SAE, czyli 1 pd leje co moze wystarczy to uszczelnic ???
boberek Opublikowano 5 Marca 2009 Opublikowano 5 Marca 2009 :polew: :polew: :polew: a jak to uszczelnisz :polew: :polew: :polew: i nie leje tylko przypchany jest nic nie ruszaj zalej STP supr koncentrat do diesli na cały zbiornik moze pomoże :polew: :polew: :polew: uszczelnić no rozjebałes mnie sam robisz programy a nie znasz podstaw :polew: takie korekcje sa ok nie przejmuj sie az tak strasznie a jak cie to denerwuje to kup nowe
martin a4 Opublikowano 5 Marca 2009 Autor Opublikowano 5 Marca 2009 :polew: :polew: :polew: a jak to uszczelnisz :polew: :polew: :polew: i nie leje tylko przypchany jest nic nie ruszaj zalej STP supr koncentrat do diesli na cały zbiornik moze pomoże :polew: :polew: :polew: uszczelnić no rozjebałes mnie sam robisz programy a nie znasz podstaw :polew: takie korekcje sa ok nie przejmuj sie az tak strasznie a jak cie to denerwuje to kup nowe jak jak przeciesz jest miedziana uszczelka pod pompka a potem o ring i niewiem z czego sie smiejesz czlowieczku ,problem jest taki ze jak sie silnik nagrzeje to telepoce silnikiem i moze to byc powod
spanky Opublikowano 5 Marca 2009 Opublikowano 5 Marca 2009 jak telepie motorem to moze pompka pada ... zrob 018 i 023 ... poza tym bylo kilka postów na ten temat poszukaj ...
spanky Opublikowano 5 Marca 2009 Opublikowano 5 Marca 2009 statyczne czy dynamiczne najpierw statyczne ... na zimnym i na rozgrzanym ...
boberek Opublikowano 5 Marca 2009 Opublikowano 5 Marca 2009 :polew: :polew: :polew: a jak to uszczelnisz :polew: :polew: :polew: i nie leje tylko przypchany jest nic nie ruszaj zalej STP supr koncentrat do diesli na cały zbiornik moze pomoże :polew: :polew: :polew: uszczelnić no rozjebałes mnie sam robisz programy a nie znasz podstaw :polew: takie korekcje sa ok nie przejmuj sie az tak strasznie a jak cie to denerwuje to kup nowe jak jak przeciesz jest miedziana uszczelka pod pompka a potem o ring i niewiem z czego sie smiejesz czlowieczku ,problem jest taki ze jak sie silnik nagrzeje to telepoce silnikiem i moze to byc powod śmieje sie z tego co piszesz to ze telepie to jest jeszcze przynajmniej jakies 10 róznych przyczyn ja z tym walcze od 1,5 roku i jakos mi sie nie udało i zacznij lepiej precyzowac to o co ci chodzi a poza tym było na forum na ten temat juz obszerny topic wiec radze poszukać mam duzo lepsze korekcje i tez telepie wiec raczej nie lezy to po tej stronie
martin a4 Opublikowano 5 Marca 2009 Autor Opublikowano 5 Marca 2009 hmmm to moze kola dwumas albo plecionka bo co jeszcze ????
boberek Opublikowano 5 Marca 2009 Opublikowano 5 Marca 2009 dwumas by było słychać plecionka jak najbardziej moze którys wieszak w wydechu moze poduszka silnika / skrzyni moze zły kąt / korekcja rozrządu kurde pewnie jeszcze by sie cos znalazło spróbuj wgrac seryjny program moze sie poprawi HGW to jest naprawde trudny temat kiedys pamietam jak jeden z forumowiczów zrobił jedeną rzecz zdjął obudowe wypia sterowanie PDkami i pomogło podobno tego nie robiełm szczerze Ci powiem ale mozesz spróbować
martin a4 Opublikowano 5 Marca 2009 Autor Opublikowano 5 Marca 2009 n o wlasnie ze mam juz serie i dalej ,a jak by plecionka to tak by bujalo silnikiem na prawo i lewo ???
martin a4 Opublikowano 6 Marca 2009 Autor Opublikowano 6 Marca 2009 hmmmm poduszkiii to czemu tylko na cieplym silniku telepoce
boberek Opublikowano 6 Marca 2009 Opublikowano 6 Marca 2009 no jak na zimnym sa wieksze obroty to niweluje te telepanie mam to samo
