MedeiS Opublikowano 21 Czerwca 2019 Opublikowano 21 Czerwca 2019 (edytowane) Address 08 ------------------------------------------------------- Controller: 8E0 820 043 Component: A4 Klimaautomat 0711 Coding: 00000 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 09 ------------------------------------------------------- Controller: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00011 Shop #: WSC 63351 1 Fault Found: 01800 - Light Switch (E1) 27-10 - Implausible Signal - Intermittent Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 N Component: Lenksáulenmodul 0308 Coding: 00042 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 900 L Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 00100 Shop #: WSC 00006 WAUZZZ8E83A323919 AUZ6Z0C0022709 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AT Component: Komfortgerát T23 1210 Coding: 06976 Shop #: WSC 63351 3 Faults Found: 00955 - Key 1 35-10 - - - Intermittent 00956 - Key 2 35-10 - - - Intermittent 00932 - Electric Window Motor: Drivers Side (V147) 35-10 - - - Intermittent Address 55 ------------------------------------------------------- Controller: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00060 Shop #: WSC 63351 No fault code found. End ------------------------------------------------------- Takich błędów nie ma na instrukcji kodów vag.... Edytowane 21 Czerwca 2019 przez MedeiS
