TIRU SORIN Opublikowano 20 Lutego 2024 Opublikowano 20 Lutego 2024 Ok i will check the buzzer. Another problem is that park menu is gray out in navi display. I cannot chsnge tone or volume for pdc. And i cannot change camera display to display pdc lines. In the past i have make retrofit on a q5 8r but it was more easy than this.
Muskel1 Opublikowano 20 Lutego 2024 Opublikowano 20 Lutego 2024 In addition, as long as you have the error with the buzzer, the gance pdc system is deactivated. That's why you can't change anything
TIRU SORIN Opublikowano 23 Lutego 2024 Opublikowano 23 Lutego 2024 😗Ok, it was buzzer it was defect. I try with another buzzer from an Q5 and it work. What is the oem code for buzzer ? Front pdc works now Rear Works. But still not display on MMI display pdc lines Only camera. I try any posible combinations with vcds. But not display lines. Park Menu is gray out in mmi. And camera is not turning on when i push buton only with reverse. Any ideas how to activate parke menu in mmi to change volume and sound and to activate pdc line on mmi ?
Kamil27 Opublikowano 23 Lutego 2024 Opublikowano 23 Lutego 2024 Godzinę temu, TIRU SORIN napisał(a): What is the oem code for buzzer ? 8E0919279 This is the same buzzer as A4 A5 B8 B9, A6 C7, Q5
TIRU SORIN Opublikowano 24 Lutego 2024 Opublikowano 24 Lutego 2024 18 hours ago, Muskel1 said: Who retrofitted the camera,you? Yes
Muskel1 Opublikowano 24 Lutego 2024 Opublikowano 24 Lutego 2024 I looked at your coding again. You have to activate Bit 1 in Byte 4 in the control unit 6C (camera).
TIRU SORIN Opublikowano 25 Lutego 2024 Opublikowano 25 Lutego 2024 I tried it . Not working. When i activate this Bit 1 in Byte 4 in the control unit 6C Camera not work anymore. Even if i put in reverse is not working.
kiwip Opublikowano 4 Marca 2024 Opublikowano 4 Marca 2024 (edytowane) Witam. Dokładam PCD pdzod i tyl ( auto tylko z kamerą z USA) Obecnie zamontowany Bcm1 8W0 907 063 CB Z jakim indeksem kupić, aby wszystko działało? Edytowane 4 Marca 2024 przez kiwip
kiwip Opublikowano 4 Marca 2024 Opublikowano 4 Marca 2024 (edytowane) Dziękuję. Widziałem ten temat, tylko zastanawiam mnie jedna rzecz. U siebie mam ksenony i jeżeli przykładowo kupię Bcm1 który obsługuje Led lub Matrix to u mnie odpali? Czy jest jakaś hierarchia indeksów Bcm1 w zaleznosci ile rzeczy obsluguja, np Cb następnie CC itp.- Edytowane 4 Marca 2024 przez kiwip
Muskel1 Opublikowano 4 Marca 2024 Opublikowano 4 Marca 2024 (edytowane) Jeżeli założysz BCM1 obsługujący LED i lampy oraz adaptery to LED po odpowiednim kodowaniu zadziałają. 33 minuty temu, kiwip napisał(a): Czy jest jakaś hierarchia indeksów Bcm1 w zaleznosci ile rzeczy obsluguja, np Cb następnie CC itp.- Próbowaliśmy w podanym u góry temacie stworzyć własną bazę danych BCM1, na podstawie której można by określić jakie funkcje obsługują dane sterowniki, ale jak widzisz, chętnych brak lub niewielu. Każdy chciałby tylko aby mu podać na tacy, bo cytuję: "od tego jest forum aby sobie pomagać" - ale jeżeli chodzi o własną inicjatywę to cisza. Szkoda tylko, że to "pomaganie" ich zdaniem działa tylko w jednym kierunku... Edytowane 4 Marca 2024 przez Muskel1
kiwip Opublikowano 4 Marca 2024 Opublikowano 4 Marca 2024 Masz racje. Pytać chętnie, odpowiadać niekoniecznie. Jeżeli dobrze zrozumiałem, to może bez Bcm1 który obsługuje Ledy, a tylko odpowiednim kodowaniem zmienie aby zadziałały ksenony.
Muskel1 Opublikowano 4 Marca 2024 Opublikowano 4 Marca 2024 Tak, BCM1 obsługujący LED obsłuży też ksenony, wystarczy odpowiednio zakodować.
kiwip Opublikowano 4 Marca 2024 Opublikowano 4 Marca 2024 15 minut temu, Muskel1 napisał(a): Tak, BCM1 obsługujący LED obsłuży też ksenony, wystarczy odpowiednio zakodować. Dziekuje
lucasek Opublikowano 4 Marca 2024 Opublikowano 4 Marca 2024 Godzinę temu, Muskel1 napisał(a): Próbowaliśmy w podanym u góry temacie stworzyć własną bazę danych BCM1, na podstawie której można by określić jakie funkcje obsługują dane sterowniki, ale jak widzisz, chętnych brak lub niewielu. Czy dane z Q5 FY też warto do tej bazy dołaczyć?
