Melya90 Opublikowano 17 Stycznia 2021 Opublikowano 17 Stycznia 2021 witam serdecznie! poproszę o wytłumaczeniu mi blędów w samochodzie. co mam zamienić? Address 01: Engine Labels: Redir Fail! Controller: 4B0 906 018 K Component: 1.8L R4 5VT 0005 Coding: 05001 Shop #: WSC 06335 VCID: 29257EA7C0E1 1 Fault Found: 16486 - Mass Air Flow Sensor (G70): Signal too Low P0102 - 35-00 - - Readiness: 0010 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL Controller: 8E0 614 111 B Component: ABS/EDS 5.3 FRONT D00 Coding: 0273004283 Shop #: BB 24332 VCID: 1D4D5A7784A9 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.LBL Controller: 8D0 820 043 P Component: A4 KLIMAAUTOMAT D53 Coding: 00040 Shop #: WSC 06335 VCID: 2D2D8AB7F409 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.LBL Controller: 8D0 959 655 J Component: Airbag Front+Seite 0001 Coding: 00104 Shop #: WSC 06335 VCID: 3D0DBAF72469 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-919-xxx-17.LBL Controller: 8D0 919 861 H Component: B5-KOMBIINSTR. VDO D15 Coding: 00042 Shop #: WSC 00000 VCID: 361FA5DB015F IMMO-IDENTNR: AUZ7Z0W0850142 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: None Controller: Bit teA dre ssu Component: e 17 eingeben VCID: CFD1703F1EC5 No Faults Found or DTCs not supported by controller or a communication error ocurred ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.LBL Controller: 8D0 862 257 C Component: ZV-Pumpe D12 Coding: 00001 Shop #: WSC 06325 VCID: 2D2D8AB7F409 2 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 00991 - Interior Lights 28-00 - Short to Plus
Muskel1 Opublikowano 18 Stycznia 2021 Opublikowano 18 Stycznia 2021 (edytowane) W silniku przepływomierz albo jego okablowanie do sprawdzenia lub wymiany. Centralny zamek albo ciśnienie w układzie zamka za niskie albo pompka centralnego zamka ma usterkę. Edytowane 18 Stycznia 2021 przez Muskel1
