Ukasz699 Opublikowano 25 Września 2009 Opublikowano 25 Września 2009 Witajcie dziś vagowałem swojego Paździoszka i wyskoczyły mi takie błędziska. Może mi ktoś w tym pomóc grr ?? VAG-COM Version: Release 409.1-US Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 ------------------------------------------------------------------------------- Address 01: Engine Controller: 038 906 019 JQ Component: 1,9l R4 EDC 0000SG 1570 Coding: 00002 Shop #: WSC 00012 WAUZZZ8E33A296936 AUZ6Z0B0447265 1 Fault Found: 17911 - Load Signal from Alternator Term. DF: Implausible Signal P1503 - 35-10 - - - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 8E0 614 517 Component: ABS/ESP front 1729 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 18265 - Load Signal: Error Message from ECU P1857 - 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Controller: 8E0 820 043 H Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 5 Faults Found: 01809 - Actuating Motor for Temperature Flap: Left (V158) 41-10 - Blocked or No Voltage - Intermittent 01810 - Actuating Motor for Temperature Flap: Right (V159) 41-00 - Blocked or No Voltage 01842 - Potentiometer/Actuator for Temperature Flap: Right (G221) 09-00 - Adaptation Limit Surpassed 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 00716 - Air recirculation Flap Positioning Motor (V113) 41-10 - Blocked or No Voltage - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0203 Coding: 00001 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 16: Steering wheel Controller: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00002 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Controller: 8E0 920 900 K Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 00000 Shop #: WSC 11111 WAUZZZ8E33A296936 AUZ6Z0B0447265 1 Fault Found: 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 46: Central Conv. Controller: 8E0 959 433 AR Component: Komfortgerát T85 1310 Coding: 06976 Shop #: WSC 63351 2 Faults Found: 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent 01366 - Opened Due to Crash Signal 36-10 - Open Circuit - Intermittent End -------------------------------------------------------------------------------------------------- Z góry dziękuje.
spanky Opublikowano 25 Września 2009 Opublikowano 25 Września 2009 najpierw skasuj i zobacz czy powroca ...
Ukasz699 Opublikowano 25 Września 2009 Autor Opublikowano 25 Września 2009 Te Ciągle powracają bo kolejny raz mi się przewijają ------------------------------------------------------------------------------- Address 01: Engine Controller: 038 906 019 JQ Component: 1,9l R4 EDC 0000SG 1570 Coding: 00002 Shop #: WSC 00012 WAUZZZ8E33A296936 AUZ6Z0B0447265 1 Fault Found: 17911 - Load Signal from Alternator Term. DF: Implausible Signal P1503 - 35-10 - - - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 8E0 614 517 Component: ABS/ESP front 1729 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 18265 - Load Signal: Error Message from ECU P1857 - 35-10 - - - Intermittent
