automat afn wydruk z vaga brak biegów
brat ma problem z automatem oto wydruk z vaga może ktoś by to skomentował dzięki :
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 038 906 018 P
Component: 1,9l R4 EDC G00AG 1629
Coding: 00001
Shop #: WSC 00028
4 Faults Found:
00545 - Engine-Transmission Electrical Connection
31-10 - Open or Short to Ground - Intermittent
01262 - Solenoid Valve for Boost Pressure Control (N75)
31-00 - Open or Short to Ground
00777 - Accelerator Position Sensor (G79)
27-10 - Implausible Signal - Intermittent
01266 - Glow Plug Relay (J52)
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 01N 927 733 DG
Component: AG4 Getriebe 01N 4147
Coding: 00000
Shop #: WSC 00000
9 Faults Found:
00258 - Solenoid Valve 1 (N88)
36-10 - Open Circuit - Intermittent
00260 - Solenoid Valve 2 (N89)
00262 - Solenoid Valve 3 (N90)
00266 - Solenoid Valve 5 (N92)
00270 - Solenoid Valve 7 (N94)
00293 - Multi-function Switch (F125)
25-00 - Unknown Switch Condition
00281 - Vehicle Speed Sensor (G68)
03-00 - No Signal
00638 - Engine/Transmission Electrical Connection 2
03-10 - No Signal - Intermittent
00297 - Gearbox Speed Sensor (G38)
03-00 - No Signal
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 B
Component: CLIMATRONIC V 1.0.0
Coding: 02000
Shop #: WSC 00028
1 Fault Found:
01273 - Fresh Air Blower (V2)
35-00 - -
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 3B1 919 860 D
Component: B5-KOMBIINSTR. VDO V01
Coding: 04140
Shop #: WSC 00000
IMMO-IDENTNR: VWZ7Z0W1031157
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 Q
Component: 38 Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00028
6 Faults Found:
01329 - Convenience System Data Bus in Emergency Mode
35-10 - - - Intermittent
00930 - Locking Module for Central Locking: Rear Left (F222)
54-10 - Incorrectly Equipped - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-00 - Implausible Signal
End -------------------------------------------------------
Po usunieciu usterek, nie ma bledow. Dopiero po kilkunastu sekundach, kiedy znowu wszystko wariuje, pojawiaja sie na nowo bledy.
To passat czy audi?
adadur, z tego co wynika z opisuandrzej710127, to A4 B5 Silnik: 1.9TDi 110 KM
Rocznik: 1998 więc chyba AUDI :smile:
a w automatycznym skanowaniu wybrał: Chassis Type: 3B - VW Passat B5
faktycznie nie zauważyłem może się pomylił teraz to faktycznie już niewiem
andrzej710127, co masz Passata czy Audi
nie napisałem ale faktycznie to passat brata
[ Dodano: 11-05-2007, 20:40 ]
a może ktos wie gdzie szukac sterownika od skrzyni biegów ,którędy można sie do niego dostać.
