[ALL B6] Prośba o analizę błędów
Address 01 -------------------------------------------------------
Controller: 8E0 909 518 M
Component: 1.8L R4/5VT 0002
Coding: 0011701
Shop #: WSC 63351
3 Faults Found:
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 001 - Upper Limit Exceeded - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 002 - Lower Limit Exceeded - Intermittent
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04275
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 N
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01810 - Actuating Motor for Temperature Flap: Right (V159)
41-10 - Blocked or No Voltage - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
1 Fault Found:
01498 - Bulb for Parking Lamps: Right (M3)
57-00 - Electric Circuit Failure
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 H
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 01000
Shop #: WSC 00222
WAUZZZ8EX3A018664 AUZ6Z0B0101239
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AH
Component: Komfortgerát T1B 0619
Coding: 06730
Shop #: WSC 63351
4 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
1 Fault Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
30-10 - Open or Short to B+ - Intermittent
Address 76 -------------------------------------------------------
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D07
Coding: 00104
Shop #: WSC 63351
End ----------------------------------------------------
[br]Dopisany: 16 Maj 2010, 18:09_________________________________________________jest ktos w stanie mi pomoc??
Ponawiam prośbę bo to o moje autko chodzi :confused4:
Czy po skasowaniu błędów wszystkie wracają? Bo jeżeli nie kasowałeś ich a są, to ktoś kiedyś grzebał przy elektryce i ich nie pokasował.[br]Dopisany: 22 Maj 2010, 19:37_________________________________________________16712 P0322 Czujnik uderzeniowy #1 R11; wysoke wejście(sygnał) (bank 1 lub pojedynczy sensor) - czyli był umfal :>
16795 P0411 System wprowadzania wtórnego powietrza (B2) R11; niewłaściwy przepływ
17699 p1290 Czujnik temperatury płunu chłodzącego za radiatorem g83 brak sygnału[br]Dopisany: 22 Maj 2010, 20:43_________________________________________________Address 46 -------------------------------------------------------
Coding: 06730
Shop #: WSC 63351
4 Faults Found:
35-00 - -
35-00 - -
35-00 - -
Te błędy powstały bo został uruchomiony alarm.[br]Dopisany: 22 Maj 2010, 20:45_________________________________________________Address 55 -------------------------------------------------------
Coding: 00060
Shop #: WSC 63351
1 Fault Found:
to oznacz że silniczek lamp ma zwarcie do pulsa
Czyli autko przywaliło przodem prawą stroną ;(
