[ALL B6] Prośba o analizę błędów B6 2,5 TDI automat
Poniżej lista błędów jakie wywaliło po auto scanie, i prośba o sprostowanie o co biega. Na fisie ciągle pali się informacja o baterii z telematica, tylko gdzie ona jest ?
Address 01 -------------------------------------------------------
Controller: 8E0 907 401
Component: 2.5L V6 TDI 0200AG 0007
Coding: 02017
Shop #: WSC 60950
00005059 130 106JC150_1.V79100725282
1 Fault Found:
01375 - Valves for Engine Mounting: Stage 1
38-10 - Output won't Switch or Short to B+ - Intermittent
Readiness: N/A
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 C
Component: A4 Klimaautomat 1012
Coding: 00000
Shop #: WSC 63251
2 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
30-10 - Open or Short to B+ - Intermittent
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 J
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 00000
Shop #: WSC 11111
WAUZZZ8E52A279070 AUZ6Z0B0058333
1 Fault Found:
01302 - Control Module for Telematic (J499)
49-10 - No Communications - Intermittent
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AF
Component: Komfortgerát T03 0316
Coding: 06976
Shop #: WSC 63351
2 Faults Found:
01561 - Left Rear Door
61-00 - Won't De-Safe
01562 - Right Rear Door
Address 75 -------------------------------------------------------
Controller: 8E0 035 617 A
Component: Telematik Nokia1 0303
Coding: 0005002
Shop #: WSC 06342
3 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground
01522 - Handset for Telephone (R37)
004 - No Signal/Communication
01531 - Emergency Battery
002 - Lower Limit Exceeded[br]Dopisany: 30 Styczeń 2011, 14:04_________________________________________________Dokładnie chodzi i o grupę 01 co to za błąd, i czy ktoś orientuje się gdzie jest bateria z tego telematica, może ktoś się wypowiedzieć ?
01375 to błąd zaworu poduszki pod silnikiem do wymiany zawór/poduszka lub do sprawdzenia kable. Podobno powinno to pokazywać też na fisie.
