[B5 AHU] Prośba o analize logów
Skanowanie w poszukiwaniu bledow:
Monday,18,April,2011,10:42:44:60804
VCDS Version: Release 10.6.0 (x64)
Data version: 20100630
Address 01: Engine (038 906 012 AF)
10:42:39 Group 000
040
066
000
022
096
204
157
169
082
139
Monday,18,April,2011,11:22:25:60804
11:22:07 Group 000
042
049
000
012
098
204
087
133
128
116
11:22:07 Group 001
840 /min RPM
3.8 mg/str Inj. Quantity
1.380 V Voltage
76.5°C Temperature
11:22:07 Group 002
861 /min RPM
0.0 % Load
0 1 0 Bin. Bits
76.5°C Temperature
Monday,18,April,2011,11:53:57:60804
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: XXXXXXXXXXXXXXXXX
Address 01: Engine Labels: None
Part No: 038 906 012 AF
Component: 1,9l R4 EDC 0000SG 2825
Coding: 00002
Shop #: WSC 06335
VCID: 54ACF9A68E93
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
VCID: 5EB81B8EF05F
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D57
Coding: 00044
Shop #: WSC 00460
VCID: 2A50875EFC97
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 01104
Shop #: WSC 06335
VCID: 3D7ABC021D19
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 950 E
Component: KOMBI+WEGFAHRS. M73 D54
Coding: 00440
Shop #: WSC 00408
VCID: 2A50875EFC97
XXXXXXXXXXXXXXXXX AUZ5Z0A4303061
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 06335
VCID: 2F66964AC775
1 Fault Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
VCID: E0C4A5764A2B
End ---------------------------------------------------------------------
Logi statyczne:
http://vaglog.rtnet.pl/moscic_43261.html
http://vaglog.rtnet.pl/moscic_43262.html
http://vaglog.rtnet.pl/moscic_43263.html
Logi BS
http://vaglog.rtnet.pl/moscic_43264.html
http://vaglog.rtnet.pl/moscic_43265.html
http://vaglog.rtnet.pl/moscic_43266.html
http://vaglog.rtnet.pl/moscic_43267.html
Nie zrobilem jeszcze dynamicznych bo musze kogos poszukac kto mi w tym pomoze. Nie wiem tez ile mozna powiedziec na podstawie samych logow statycznych i BS. Ale przede wszystkim chodzi mi o to czy wogole dobrze sa wykonane. Pierwszy raz robilem :)[br]Dopisany: 18 Kwiecień 2011, 13:06_________________________________________________http://forum.tdi-tuning.pl/viewtopic.php?t=224&highlight=abc+diagnozowania
Na podstawie zalaczonych tutaj obrazkow bede teraz sam probowac rozszyfrowac wszsytko. I na sam poczatek wydaje mi sie ze kat poczatku wtrysku jest nieprawidlowy i dawka wtryskiwanego paliwa jest zbyt mala. Reszta w bloku 000 wyglada normalnie. Powedzcie czy dobrze mowie bo jednak w przyszlosci sam chcialbym sie nauczyc oceniac logi niz za kazdym razem prosic o pomoc :)
Kąt wtrysku jest ok ma być w okolicach 50. Coś z doładowaniem jest nie tak (jak dla mnie) ale to już niech mądrzejsi się wypowiedzą, niby zaworki się otwierają a nic się nie zmienia oprócz położenia zaworków. Może EGR jest zaślepiony nie wiem.
Coś masz nie tak z poduszką, autko po dzwonie?? Radziłbym w pierwszej kolejności zrobić poduszkę. Do pełnej oceny autka brakuje logów dynamicznych. A jak zrobić poprawne logi zobacz sobie tu:
http://www.a4-klub.pl/smf/index.php?topic=18478.0
Masz opisane co i jak logować oraz podstawową diagnostykę.
nie szarpie przy jezdzie na 5 ze stałą pred ?
EGR zaslepiony albo nieaktywny
termostat sie klania
A zauważyłeś że coś skacze na obrotach?? W logach widać jak obroty przysiadają, ciekawe dlaczego??
Co do termostatu to tak wlasnie czulem ze cos jest nie tak z nim. A niedawno wymienialem rozrzad i zapomnialem o tym :( Co do jazdy nigdy nie odczulem zeby cos szarpalo. A co do tych obrotow to zauwazylem od razu. Moze to byc wina pompy wtryskowej?[br]Dopisany: 18 Kwiecień 2011, 14:01_________________________________________________Chcialbym odswiezyc troche temat. Chodzi o ten EGR. Troche poszukalem na forum.
"Zaslepienie EGR powinno skutkowac
+ zmniejszeniem dymienia
+ zwiekszeniem dynamiki (nie przepala spalin tylko czyste powietrze)
+ nie powinien sie syfic kolektor
- glosniejsza praca na wolnych obrotach
- brakiem studzenia komory spalania na wolnych obrotach i bez obciazenia"
Z ta glosniejsza praca na wolnych obrotach to sie nawet zgadza. Ale teraz zastanawiam sie nad zaworem N18. Bo jezeli nie dziala N18 to jest chyba wolniejsze nagrzewanie silnika i telepanie przy zgaszaniu samochodu (informacje z forum :>). Co tez sie zgadza u mnie.
I mam pytanie co do tej malej rureczki zaznaczonej na zdjeciu na czerwono. Czy ona ma cos wspolnego z zaworem N18 i EGR. A moze tak powinno byc. Jezeli nie to gdzie powinna byc podlaczona (o ile wogole gdzies podlaczona)?
wężyk powinien iść do obudowy filtra powietrza
