[B7 BLB] Analiza błędów
zaczynam zabawe z Vagowaniem mojej a4 i na początek sprawdziłem wszystkie moduły w poszukiwaniu błędów zrobiłem to dwa razy , raz od razu i drugi raz po skasowaniu błędów i oto co otrzymałem :
przed skasowaniem błędów :
VCDS Version: Release 10.6.0
Data version: 20100630
Sunday,01,May,2011,15:00:31:46862
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E65A448419 Mileage: 164220km/102041miles
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC 0000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 01379 264 64017
VCID: 75EAE38A239B20B4
1 Fault Found
19559 - Motor for Intake Manifold Flap (V157): Malfunction
P3103 - 000 - - - Intermittent
Freeze Frame:
RPM: 882 /min
Torque: 26.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000110
Torque: 161.0 Nm
Torque: 0.0 Nm
Readiness: 0 1 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
VCID: 2648F4C6AEBD1B2C
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AJ
Component: A4 Klimaautomat 2728
Coding: 00000
Shop #: WSC 06325
VCID: 69D2BFFA7F23F454
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 10001
Shop #: WSC 06325
VCID: 3B7E35B2453FB6C4
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M001B6BH
Coding: 0033622
1 Fault Found
01794 - Control Module - Incorrect Chassis (VIN) Number
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 00012
Shop #: WSC 06325
VCID: 438E4D523DCFCE04
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 900 R HW: 8E0 920 900 R
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0004141
Shop #: WSC 01379 264 55508
VCID: 336E1D926D6F7E84
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BH
Component: Komfortgerát T01 2431
Coding: 07024
Shop #: WSC 06325
VCID: 78F4EABE34895DDC
Part No: 8E1959801F
Component: Tőrsteuer.FS BRM 0305
Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0205
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01001
Shop #: WSC 06325
VCID: 2854FAFEA4A90D5C
End --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
odrazu można zuważyć ze grupa 01 Engine błąd skasowany tylko co to było ? zostaje błąd w grupie 15 czyli poduchy :mysli:
Sunday,01,May,2011,15:59:48:46862
69 75 76 77
Coding: 0000072
Readiness: 0 0 1 1 1
Coding: 0004401
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 00000
Shop #: WSC 06325
Coding: 10001
Shop #: WSC 06325
Coding: 0033622
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
Coding: 00012
Shop #: WSC 06325
Coding: 0004101
Coding: 07024
Shop #: WSC 06325
Part No: 8E1959801F
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
Coding: 01001
Shop #: WSC 06325
sugestie jakieś z góry dziękuje.
musisz przyuczyć poduszkę do nr VIN twojego auta
robi się to w adaptacjach
a cos wiecej jak to zrobic ? gdzie wejsc i co zmienic i dlaczego nie jest przyuczona była znieniana czy jak :mysli:
wchodzisz w airbag ---> adaptacje i tam jest jakiś kanał w którym przyucza się do VINu
w VCDS w adaptacjach jest u góry taka zakładka z dostępnymi kanałami to wybierz sobie ten dotyczący VINu
a jezeli tego nie zrobie to czy ten błąd jakoś wpływa na działanie poduszek ? czy trzeba to wogóle ustawiać , pytam bo zastanawiam sie skąd sie biorą takie błędy i czy mają wpływ jakiś na działanie danych elementów :mysli:[br]Dopisany: 08 Maj 2011, 23:45_________________________________________________znów błąd silnika w grupie 1 mi sie pojawił ten sam co w pierwszym poście co to jest ?
klapa gasząca a dokladnie silniczek
czy to groźne i czy można z tym jeździć za co to jest odpowiedzialne ? nie zauwazyłem żadnych zmian w pracy silnika :mysli:
