[B6 AKE] Prośba o analizę logów
Audi A4 B6 2002r. 2.5 TDI 180PS Quattro.
Czy mógłby mi ktoś pomóc w analizie tych błędów?
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 907 401 D
Component: 2.5L V6 TDI G000SG 0006
Coding: 02015
Shop #: WSC 63351
00004059 130 106LC150_1.150_1.863282
2 Faults Found:
00542 - Needle lift Sensor (G80)
30-10 - Open or Short to B+ - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04455
Shop #: WSC 32590
No fault code found.
Address 08: Auto HVAC
Controller: 8E0 820 043
Component: A4 Klimaautomat 1012
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
01842 - Potentiometer/Actuator for Temperature Flap: Right (G221)
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
Address 09: Cent. Elect.
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 P
Component: Lenksáulenmodul 0611
Coding: 01042
Shop #: WSC 32590
Address 17: Instruments
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 01000
Shop #: WSC 19411
WAUZZZ8E92A254396 AUZ6Z0B0026744
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 46: Central Conv.
Controller: 8E0 959 433 AF
Component: Komfortgerát T03 0315
Coding: 06976
Shop #: WSC 63351
4 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
36-10 - Open Circuit - Intermittent
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
01562 - Right Rear Door
Address 56: Radio
Controller: 8E0 035 186
Component: concert II GRO 0007
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
00858 - Connection: Radio ZF Output to Antenna Amplifier
29-10 - Short to Ground - Intermittent
End --------------------------------------------------------------------------------------------------
skasuj i zobacz czy wracają ...
VAG-COM Version: Release 409.1-S
Address 01: Engine
Coding: 02015
Shop #: WSC 63351
00004059 130 106LC150_1.V77064863282
1 Fault Found:
Readiness: N/A
Coding: 04455
Shop #: WSC 32590
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
07-10 - Signal too Low - Intermittent
Coding: 00001
Shop #: WSC 63351
Coding: 01042
Shop #: WSC 32590
Coding: 01000
Shop #: WSC 19411
Coding: 06976
Shop #: WSC 63351
Address 56: Radio
Coding: 00001
Shop #: WSC 63351
Powazny jest ten ....00542 - Needle lift Sensor - swiadczy o uszkodzonym wtrysku sterujacym.
Wykonaj logi statyczne... 001,004 oraz 004 Basic Settings.
Przy okazji sprawdz okablowanie przy wtrysku sterujacym.
Nie wiem czy oto chodziło?
Gdzie szukać wtrysku sterującego?
1 - wtryskiwacz z czujnikiem wzniosu iglicy -G80-
- wtryskiwacz 3 cylindra
2 - Zawór sterujący ciśnieniem doładowania -N75-
3 - Czujnik temperatury oleju -G8-
4 - złączka czujnika obrotów silnika -G28-
5 - złączka wtryskiwacza z czujnikiem wzniosu iglicy -G80-
6 - siłownik podciśnieniowy ciśnienia doładowania
7 - obudowa ECU zawierająca:
- ECU -J248- czujnikiem wysokości -F96
- przekaźnik sterownika pompy wtryskowej -J322-
- Bezpieczniki świec żarowych
8 - Czujnik obrotów walu -G28-
9 - Czujnik ciśnienia doładowania -G71-
10 - Zawór sterujący klapą gaszącą -N239-
11 - Zawór sterujący EGR -N18-
12 - Siłownik podciśnieniowy z klapą gaszącą
13 - EGR
14 - Pompa wtryskowa wraz z:
- sterownikiem pompy wtryskowej
-magnetycznym zaworem mieszającym
- czujnikiem obrotów pompy wtryskowej
- z zaworem początku wtrysku
- czujnikiem temperatury paliwa
15 - Czujnik temperatury płynu chłodzącego -G62-
16 - Miernik masy powietrza -G70- czujnik temperatury powietrza wlotowego -G42-
zmierz mu rezystancję, 90-120 musi miec
Co to jest rezystancja i jak ją zmierzyć ?
opor elektryczny, multimetrem cyfrowym
A co tu mierzyc... wtrysk sterujacy kwalifikuje sie do wymiany...
Co może spowodować uszkodzony wtrysk sterujący - nieprawidłową prace silnika, większe spalanie, uszkodzenie silnika ?? (bo nie wiem czy moge jeżdzić samochodem czy odstawić do czasu wymiany wtrysku)
Orientujesz się jaki to koszt i czy można to zrobić samemu czy lepiej oddać do warsztatu?
a co jesli wiazka ma przerwe ? [br]Dopisany: 12 Czerwiec 2011, 12:50_________________________________________________
mniejsza moc i sztywny kat wtrysku, i miganie kontrolki swiec
można samemu zdejmujesz lewą pokrywę w silniku stojąc przodem do otwartej maski wykręcasz wtrysk z kabelkiem zmieniasz i o taka to robota. Ja kiedyś wymieniałem to a kosz w ASO 2 lata temu płaciłem ok 1600PLN, bo używki nie wsadzałem kto wie w jakim jest stanie i ile pojeździ
