kox_nwa Opublikowano 8 Listopada 2011 Opublikowano 8 Listopada 2011 Witam kolegów, postanowiłem sobie dziś wyszukać błędy, i otrzymałem coś takiego: Moglibyście powiedzieć mi cokolwiek na temat tych błędów? Najbardziej zmartwił mnie błąd Abs\Esp, o co tu chodzi??? Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 FP Component: 1,9l R4 EDC 0000SG 1538 Coding: 00002 Shop #: WSC 60551 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent Address 08 ------------------------------------------------------- Controller: 8E0 820 043 H Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 5 Faults Found: 01842 - Potentiometer/Actuator for Temperature Flap: Right (G221) 30-10 - Open or Short to B+ - Intermittent 00716 - Air recirculation Flap Positioning Motor (V113) 41-10 - Blocked or No Voltage - Intermittent 01207 - Control Module for Auxiliary Heater (J364) 49-00 - No Communications 01593 - Heated Windshield (Z2) 36-10 - Open Circuit - Intermittent 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0203 Coding: 00001 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00001 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 17 ------------------------------------------------------- Controller: 8E0 920 900 G Component: KOMBI+WEGFAHRS. RB4 D27 Coding: 00001 Shop #: WSC 11111 WAUZZZ8E72A241713 AUZ6Z0B0152111 3 Faults Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent 01207 - Control Module for Auxiliary Heater (J364) 49-00 - No Communications 01304 - Radio 49-00 - No Communications Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AD Component: Komfortgerát T85 0316 Coding: 06720 Shop #: WSC 63351 5 Faults Found: 01562 - Right Rear Door 59-00 - Can't Unlock 01562 - Right Rear Door 61-00 - Won't De-Safe 01366 - Opened Due to Crash Signal 36-10 - Open Circuit - Intermittent 01332 - Door Control Module: Passenger Side (J387) 80-00 - Single-Wire Operation 01560 - Passenger Door 58-10 - Can't Lock - Intermittent End -------------------------------------------------------
kaj82 Opublikowano 8 Listopada 2011 Opublikowano 8 Listopada 2011 A odlaczales ostatnio klemy akumulatora(lub masz slaby aku)??, po skasowaniu wiekszosc bledow powinna zniknac
kox_nwa Opublikowano 8 Listopada 2011 Autor Opublikowano 8 Listopada 2011 nie, klem nie odłączałem, a aku mam nowy, ale co do niektórych błędów, to mogę się odnieść z praktyki, np odnośnie zamka prawych tylnich drzwi: nie działa oświetlenie i czujnik otwarcia, tzn czasem działa czasem nie... a reszta błędów nic mi nie mówi
kaj82 Opublikowano 8 Listopada 2011 Opublikowano 8 Listopada 2011 nie, klem nie odłączałem, a aku mam nowy, ale co do niektórych błędów, to mogę się odnieść z praktyki, np odnośnie zamka prawych tylnich drzwi: nie działa oświetlenie i czujnik otwarcia, tzn czasem działa czasem nie... a reszta błędów nic mi nie mówi a po wymianie aku na nowy błedy pokasowałeś??[br]Dopisany: 08 Listopad 2011, 22:24_________________________________________________ nie, klem nie odłączałem, a aku mam nowy, ale co do niektórych błędów, to mogę się odnieść z praktyki, np odnośnie zamka prawych tylnich drzwi: nie działa oświetlenie i czujnik otwarcia, tzn czasem działa czasem nie... a reszta błędów nic mi nie mówi a sprawdzałeś wiązke która jest przy drzwiach
kox_nwa Opublikowano 8 Listopada 2011 Autor Opublikowano 8 Listopada 2011 Nie, nie kasowałem bo wymieniał go poprzedni właściciel, i nie przypuszczałem że ma to jakiś związek z błędami, bo skąd np pewność, że błąd dot ESP nie jest jakimś błędem fizycznym? A co do tej wiązki, to jak się do niej dobrać? drzwi trzeba rozbierać?
kaj82 Opublikowano 8 Listopada 2011 Opublikowano 8 Listopada 2011 nie miedzy drzwiami a słupkiem jest guma, trzeba ja sciagnac i popatrzec dokładnie czy żaden kabel nie jest przetarty co do błedu 01794 to mam dla ciebie niemiła wiadomość http://www.elektroda.pl/rtvforum/topic1929777.html
kox_nwa Opublikowano 8 Listopada 2011 Autor Opublikowano 8 Listopada 2011 odnośnie tego błędu, to co, mam rozumieć że ktoś przy tym grzebał?
miodzio Opublikowano 8 Listopada 2011 Opublikowano 8 Listopada 2011 na początek trzeba skasować wszystko co się będzie dało żeby uporządkować cały bałagan powstały raczej na pewno po słabym lub rozładowanym Aku (podobnie miałem u siebie). Następnie sprawdzić co dalej się będzie pokazywać. Błąd w Abs -ie to wygląda na błąd magistrali CAN tak jak zresztą połowa innych. Co do drzwi i zamków to faktycznie sprawdził bym połączenie między słupkiem a drzwiami. w adresie 08 masz błąd grzani szyby - ciekawe czy masz takowe fizycznie w aucie - możliwy błąd w kodowaniu sterownika.
czakus84 Opublikowano 9 Listopada 2011 Opublikowano 9 Listopada 2011 odnosnie błędów VIN trzeba poprostu przypisać numery VIN... często wynika z głębokiego rozładowania aku.. poszukaj w moich postach - też to przerabiałem i wszystko śmiga ok
kox_nwa Opublikowano 9 Listopada 2011 Autor Opublikowano 9 Listopada 2011 Dzięki za odpowiedzi, jutro przy tym pogrzebie i dam znać co i jak. Klimatronik już "przyuczyłem"
arris_88 Opublikowano 6 Grudnia 2011 Opublikowano 6 Grudnia 2011 Witam, VCDS pokazuje mi te błędy - są to błedy stałe gdyż są one wykrywane przez interfejs pomimo czyszczenia sterowników: "Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04255 Shop #: WSC 05311 VCID: E5CA33CA133B5034 2 Faults Found 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 G Component: KOMBI+WEGFAHRS. RB4 D22 Coding: 00000 Shop #: WSC 05311 VCID: 2854FAFEA4A90D5C WAUZZZ8E82A090235 AUZ6Z0A0231556 2 Faults Found 01314 - Engine Control Module 49-10 - No Communications - Intermittent 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl Part No: 8E0 959 433 AD Component: Komfortgerát T85 0315 Coding: 06976 Shop #: WSC 05311 VCID: 73EEDD922DEF3E84 Part No: 8E1959801B Component: Tőrsteuer.FS BRM 4.11 Part No: 8E1959802B Component: Tőrsteuer.BF BRM 4.11 5 Faults Found 01561 - Left Rear Door 59-00 - Can't Unlock 01561 - Left Rear Door 61-00 - Won't De-Safe 01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent 01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent 01560 - Passenger Door 61-10 - Won't De-Safe - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 186 Component: concert II GRO 0001 Coding: 01001 Shop #: WSC 52311 VCID: E4CC2ECE1801293C 1 Fault Found 00858 - Connection; Radio ZF Output to Antenna Amplifier 36-00 - Open Circuit End ---------------------------------------------------------------------" W tym temacie są opinie, że część z nich może być winą słabego aku. Otóż mój jest niewymieniany od czasów gdy zjechał z taśmy w Ingolstadt (początek 2002). Dodatkowo mam problemy czasami z odpalaniem auta. Zauważyłem że lepiej pali jak wyłączę przy uruchamianiu radio i ogrzewanie. Drugą opcją może być zły kąt synchronizacji? Czy mogę jakoś to wykluczyć za pomocą VCDS-a?[br]Dopisany: 30 Listopad 2011, 19:45_________________________________________________Odnośnie błędu 18258 to może być wg Wiki Ross-Tech: Spalony bezpiecznik modułu sterowania Problem z kablami Uszkodzony moduł Więc pytanie do doświadczonych użytkowników. Który bezpiecznik odpowiada za ECU?
miodzio Opublikowano 6 Grudnia 2011 Opublikowano 6 Grudnia 2011 Wymień aku co do bezpieczników masz pełną rozpiskę w aucie na deklu. Sprawdź kostkę na słupku A przy kierowcy (czarna z tego co pamiętam) Kiedyś tez podobne błędy mi wywalało w ABS jak jej zapomniałem podłączyć
michail55 Opublikowano 7 Grudnia 2011 Opublikowano 7 Grudnia 2011 mnie np wywalolo bledy esp abs na okreta przez xenon nie orginalny odpiolem i wszystko smiga jak nalezy
arris_88 Opublikowano 9 Grudnia 2011 Opublikowano 9 Grudnia 2011 Ale ja mam wszystko oryginalne, mam tylko podpięte audio a dokładniej skrzynię basową.[br]Dopisany: 09 Grudzień 2011, 11:27_________________________________________________Dziś chciałem zakupić akumulator, lecz przed zakupem postanowiłem sprawdzić ładowanie i pobór prądu. Aku trzyma jeszcze nominalne paramerty, ładowanie OK, lecz pobór prądu w trakcie postoju to 0.1 A. Podobno norma to połowa z tego - 0.05 A. Jak będę miał czas to pobawię się w wypinanie bezpieczników w aucie i sprawdzanie co jest winowajcą takiego stanu rzeczy. Czy przy odłączaniu poszczególnych obwodów na coś mam uważać, któryś nie wypinać?
michail55 Opublikowano 9 Grudnia 2011 Opublikowano 9 Grudnia 2011 dziwne moze masz jakies problem ze modulami abs esp to tez czeste w vag group
Dev Opublikowano 12 Grudnia 2011 Opublikowano 12 Grudnia 2011 najpierw poszukaj przyczyne poboru pradu moze to byc tuba albo lampka w bagazniku co do abs-u to masz uszkodzenie sterownika ale to nie ma wplywu na odpalanie
