Prośba o analizę błędów przed zakupem S4
Proszę o rozszyfrowanie poniższego logu, ewentualnie wskazanie czy coś jest "bardzo" nie tak , z góry dzięki:hi:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 910 560 C
Component: 4.2L V8/5V G 0010
Coding: 0007771
Shop #: WSC 09416
No fault code found.
Readiness: 0010 1101
Address 02 -------------------------------------------------------
Controller: 8E0 910 156
Component: AG6 09L 4.2L5V USA 0040
Coding: 0000002
Shop #: WSC 63351
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 Q
Component: ABS/ESP allrad 3033
Coding: 04597
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01141
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 981 G
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01131
Shop #: WSC 00186
WAUPL68EX4A258905 AUZ6Z0D0052991
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 36 -------------------------------------------------------
Controller: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
79-00 - Please Check Fault Codes
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1512
Coding: 11788
Shop #: WSC 63351
8 Faults Found:
01134 - Alarm Horn (H12)
29-10 - Short to Ground - Intermittent
00963 - Circuit to Tilt Sensor
37-10 - Faulty - Intermittent
00957 - Key 3
35-10 - - - Intermittent
01331 - Door Control Module: Driver Side (J386)
49-10 - No Communications - Intermittent
01332 - Door Control Module: Passenger Side (J387)
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
End -------------------------------------------------------
Kasowałeś te błędy i wróciły w takim samym składzie?
troche masz namieszane w module komfortu bo radio to być może masz inne niż ori i stąd ten błąd, ale mimo wszystko spróbuj skasować i zobacz które zostaną...
w zasadzie te błędy są prawdopodobnie spowodowane radiem, bo jest nieori... bardziej jednak martwią mnie te błędy:
czy mógłby ktoś pomóc ?
Na pierwszy rzut oka widać, że ma dużo błędów wiązanych ze skrzynią biegów, auto jest w automacie? Tu masz stronę (przetłumaczoną na polski) która rozszyfrowuję kody błędów, wystarczy odnaleźć swoje błędy i przeczytać co oznaczają: Ross-Tech Tłumacz Google
Dranek dzięki:hi:,
z tego co widać to błędy spowodowane są przez lpg, bo wyświetla się że mieszanka zbyt uboga... po za tym rzeczywiście auto jest w automacie i tam też ma kilka baboków, chcialem się tylko dowiedzieć czy któryś z tych błędów jest jakoś bardzo poważny...
