AndyN 14 Opublikowano 9 Czerwca 2008 Udostępnij Opublikowano 9 Czerwca 2008 VAG-COM Version: Release 704.1 Data version: 20070422 Sunday,08,June,2008,16:42:47:55371 Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ*********** Mileage: *********km/*********miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 059-907-401-AKE.LBL Part No: 8E0 907 401 N Component: 2.5l V6 TDI G200SG 0007 Coding: 02005 Shop #: WSC 06325 Part No: 00007059 Component: 130 106KC318_1.V14568769489 WAUZZZ*********** AUZ************ No fault code found. Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.LBL Part No: 8E0 614 517 A Component: ABS/ESP allrad 4529 Coding: 04455 Shop #: WSC 06435 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.LBL Part No: 8E0 820 043 AD Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL Part No: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00111 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.LBL Part No: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.LBL Part No: 8E0 953 549 N Component: Lenksáulenmodul 0611 Coding: 04042 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL Part No: 8E0 920 930 T Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 01101 Shop #: WSC 00080 WAUZZZ*********** AUZ************ No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL Part No SW: 8E0 035 192 C HW: 8E0 035 192 C Component: RNS-E HIGH EU H50 0650 Coding: 0309217 Shop #: WSC 37605 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-192-RNSE.LBL Part No SW: 8E0 035 192 C HW: 8E0 035 192 C Component: RNS-E HIGH EU H50 0650 Coding: 0309217 Shop #: WSC 37605 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 8Z0-919-283.LBL Part No: 8Z0 919 283 A Component: Parkingsyst. A4 RDW D09 Coding: 00114 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.LBL Part No SW: 8P0 862 335 D HW: 8P0 862 335 D Component: FSE_255x BT H18 0050 Coding: 0000877 Shop #: WSC 06325 2 Faults Found: 01523 - Microphone for Telephone (R38) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 84 01305 - Databus for Infotainment 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 5 Fault Frequency: 4 Reset counter: 176 End -------------------------------------------------------------------------------------------------- Po zczytaniu błędów Vagiem mam taki błąd. O co chodzi? Może się to wiązać z modułem BT, który jak na razie nie został do końca skofigurowany? (Vas potrzebny) Błąd mikrofonu potrafię wytłumaczyć, mikrofon jest podłączony do BT Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
pre_pl 8 Opublikowano 22 Stycznia 2009 Udostępnij Opublikowano 22 Stycznia 2009 O co chodzi? Może się to wiązać z modułem BT, który jak na razie nie został do końca skofigurowany? nie, wiąże się to pewno z tym, że wsadziłeś dvd playera i czasem następuje zakłócenie w komunikacji CAN (Intermittent - sporadyczne), priorytet tego błędu to 5, więc bardzo niski. sorki, że odświeżam ale szukałem czegoś na forum dla : http://www.a4-klub.pl/smf/rnse_od_a_do_z-t12081.0.html;msg675869#msg675869 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
AndyN 14 Opublikowano 22 Stycznia 2009 Autor Udostępnij Opublikowano 22 Stycznia 2009 O co chodzi? Może się to wiązać z modułem BT, który jak na razie nie został do końca skofigurowany? nie, wiąże się to pewno z tym, że wsadziłeś dvd playera i czasem następuje zakłócenie w komunikacji CAN (Intermittent - sporadyczne), priorytet tego błędu to 5, więc bardzo niski. Jest możliwe, że ten adapter powoduje też te poniższe błędy?: ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 N Component: Lenksáulenmodul 0611 Coding: 04042 Shop #: WSC 06325 3 Faults Found: 01303 - Telephone Transceiver (R36) 49-10 - No Communications - Intermittent 01301 - Control Module for Voice Recognition (J507) 49-10 - No Communications - Intermittent 01304 - Radio 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 930 T Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 01101 Shop #: WSC 02590 WAUZZZ*********** AUZ************ 1 Fault Found: 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8P0 862 335 D HW: 8P0 862 335 D Component: FSE_255x BT H18 0050 Revision: 00000001 Serial number: xxxxxxxxxx Coding: 0001322 Shop #: WSC 06325 000 00000 2 Faults Found: 01523 - Microphone for Telephone (R38) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 41 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
