[B5 AFN] Moje pierwsze VAGowanie - możecie rzucić okiem?
Dziś po raz pierwszy bawiłem się w kasowanie inspekcji i zrobiłem Autoscan...
Oto co wyszło:
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 028 906 021 CE
Component: 1.9l R4 EDC G00SG 0803
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
00522 - Engine Coolant Temperature Sensor (G62)
30-10 - Open or Short to B+ - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 B
Component: A4 KLIMAVOLLAUTOMAT_D72
Coding: 04143
Shop #: WSC 06435
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 034
Component: B5-KOMBIINSTRUMENT D10
Coding: 00140
Shop #: WSC 48593
Address 25 -------------------------------------------------------
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0T6880225 D77
Coding: 00000
Shop #: WSC 00000
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 A
Component: ZV-Pumpe, DWA
Coding: 01416
Shop #: WSC 65535
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01363 - Switch for Central Locking: Driver's Door (F59)
27-00 - Implausible Signal
End -------------------------------------------------------
Coś dużo chyba?
Ponadto nie miałem tak nigdy a teraz mi się pojawiło (nie wiem czy wiązać z VAGiem) iż czasem włącza mi się sygnał zapalonych świateł gdy ma się wyłączony zapłon. Tyle że mi się ów dźwięk włącza gdy otworzę drzwi przy pracującym silniku i włączonych lampach.
Gdybyście mieli ochotę rzucić okiem, byłbym wdzięczny (sam też powoli rozkodowuję logi, ale może macie ode mnie większą wprawę i doświadczenie, a na pewno macie).
PZDR!
* prosze zawsze uzywac wlasciwego prefixu [Musashi]
:szukaj:
Aha, okej, w sensie myślałem że oprócz tego, co widzę iż oczywiste jest jakieś drugie dno, ale skoro te logi to po prostu odkodowywanie tego, co szukam po kodach (jak każe Spanky), to nie ma problemu.
Dziękuję!
(wiecie - pierwsze razy...)
