Prośba o sprawdzenie logów
Witam , proszę o sprawdzenie logów. Nie wiem czy dobrze je zrobiłem :D
VCDS-Lite Version: Release 1.2
Thursday, 21 November 2013, 16:25:52:0
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77
Address 01: Engine       Labels: 078-907-551-ACK.LBL
  Controller: 4D0 907 551 F
  Component: 2.8L V6/5V  MOTR HS D02
  Coding: 04201
  Shop #: WSC 06325
  VCID: 29257EA7C0E1
9 Faults Found:
01088 -  Mixture Control Adaptation 2
           15-00 -  Adaptation Limit (Add) Not Reached
17972 - Shareware Version. To Decode all DTCs
           P1564 - 35-10 - Please Register/Activate - Intermittent
17973 - Shareware Version. To Decode all DTCs
           P1565 - 35-10 - Please Register/Activate - Intermittent
00561 -  Mixture Adaptation
18020 - Shareware Version. To Decode all DTCs
           P1612 - 35-10 - Please Register/Activate - Intermittent
16514 - Shareware Version. To Decode all DTCs
           P0130 - 35-10 - Please Register/Activate - Intermittent
16534 -  Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
           P0150 - 35-10 -   - - Intermittent
01088 - Shareware Version. To Decode all DTCs
           12-10 - Please Register/Activate - Intermittent
00561 - Shareware Version. To Decode all DTCs
Readiness: N/A
Address 03: ABS Brakes       Labels: 8E0-614-111-ABS.LBL
  Controller: 8E0 614 111 A
  Component: ABS/EDS 5.3 QUATTRO D00
  Coding: 0273004284
  Shop #: BB 24334
  VCID: 1C4B57739FB3
1 Fault Found:
00287 -  ABS Wheel Speed Sensor; Rear Right (G44)
Address 08: Auto HVAC       Labels: 8E0-614-111-ABS.LBL
  Controller: 8L0 820 043 D
  Component: A4 KLIMAVOL
  VCID: 29257EA7C0E1
  Note: Excessive Comm Errors
Address 15: Airbags       Labels: 8D0-959-655-AI7.LBL
  Controller: 8D0 959 655 C
  Component: Airbag 7 Audi      0303
  Coding: 00106
  Shop #: WSC 06325
  VCID: 361FA5DB015F
1 Fault Found:
00532 -  Supply Voltage B+
           07-10 -  Signal too Low - Intermittent
Address 17: Instruments       Labels: 8D0-919-xxx-17.LBL
  Controller: 8D0 919 860 GX
  Component: B5-KOMBIINSTR. VDO D12
  Coding: 00162
  Shop #: WSC 00550
  VCID: 8C6BA733AF53
  IMMO-IDENTNR: AUZ7Z0W0615427
No fault code found.
Address 25: Immobilizer       Labels: None
  Controller: Bit teA dre sst
  Component: e 17 eingeben
  VCID: CEEF6D3B19CF
No Faults Found
 or DTCs not supported by controller
 or a communication error ocurred
Address 35: Centr. Locks       Labels: 8D0-862-257.LBL
  Controller: 8LO 862 257 D
  Component: ZV-Pumpe, Funk      D03
  Coding: 12864
  Shop #: WSC 65535
  VCID: 55DD0257BC19
8 Faults Found:
01366 -  Opened Due to Crash Signal
           35-00 -   -
01361 -  Switch for Anti-Theft Alarm; Close
           29-00 -  Short to Ground
01360 -  Switch for Anti-Theft Alarm; Open
01362 -  Close Switch for Tailgate/Trunk (F124)
01363 -  Switch for Central Locking; Driver's Door (F59)
           27-00 -  Implausible Signal
01364 -  Switch for Central Locking; Passenger Door (F114)
01365 -  Lock/Unlock Switch; Interior
           28-00 -  Short to Plus
End   --------------------------------------------------------------------------------------------------
poczytaj co znaczy log .
To co wrzuciłeś to zrzut błedów. Z tego co widzę, to leżąca sonda Bank 2 i przekroczone progi korekt .
