Prośba o pomoc w rozszyfrowaniu logów
Witam,
Mam prośbę aby jakaś dobra dusza pomogła mi rozszyfrować błędy i ew. pomóc w znalezieniu rozwiązania. Jestem laikiem wiec sam nie dojde co i jak.
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E1 910 018
Component: 2.0L R4/4V FSI 0030
Coding: 0000000
Shop #: WSC 63351
8E0907807F NOX 0512050057 007 4109
4 Faults Found:
17440 - Sensor for Nox (G295): Signal too High
P1032 - 001 - Upper Limit Exceeded - Intermittent
17912 - Intake Air System: Leak Detected
P1504 - 008 - Implausible Signal - Intermittent
16784 - EGR System: Malfunction
P0400 - 008 - Implausible Signal
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front D1320
Coding: 04275
Shop #: WSC 00000
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1016
Coding: 00010
Shop #: WSC 63351
2 Faults Found:
01593 - Heated Windshield (Z2)
36-00 - Open Circuit
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 00011
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 N
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00101
Shop #: WSC 00006
WAUZZZ8E24A175400 AUZ6Z0C0433556
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AS
Component: Komfortgerát T01 1210
Coding: 06720
Shop #: WSC 63351
2 Faults Found:
01561 - Left Rear Door
61-00 - Won't De-Safe
01562 - Right Rear Door
Address 56 -------------------------------------------------------
Controller: 8E0 035 195
Component: symphony II NP2 0009
Coding: 01421
Shop #: WSC 00661
End -------------------------------------------------------
skasuj błedy i pojezdzij pare dni i powtórz skanowanie .
EGR wywala któryś raz z kolei wiec coś jest na rzeczy :(
jesli wywala ci bład z EGR-a to musisz go wyczyscic razem z przepustnica i czujnikiem cisnienia w kolektorze ssacym i zrobic adaptacje przepustnicy i egr-a
Dziekuje, a orientujesz sie jak zmienic vin dla modulu klimy zeby blad nie wywalal ?
