silnik kuleje po wymianie świec na nowe
jak w tytule. silnik kuleje na wolnych obrotach po wymianie świec na nowe.wcześniej czasem podczas jazdy przerywał dosyć często tak jak by gasł i znów dostawał iskre i poszedł
jaką grupe logów zrobić
podejrzewam cewki ale nie mam na podmiankę żeby sprawdzić
błedy
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04140
Shop #: WSC 06325
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 860 G
Component: B5-KOMBIINSTR.UN4 D01
Coding: 00142
Shop #: WSC 00012
IMMO-IDENTNR: AUZ8Z0V6150280
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 D
Component: ZV-Pumpe, Funk D03
Coding: 12864
Shop #: WSC 65535
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
End -------------------------------------------------------
gdzie odczyt z 01 silnik?
nic nie pokazuje na 01 może vag szwankuje albo kabel
obroty na vagu skaczą od 800 do 890
---------- Post dopisany 01-04-2014 at 15:16 ---------- Poprzedni post napisany 23-03-2014 at 20:42 ----------
wymieniłem cewki na drugi jednak nic to nie dało
ale pojawiły się dwa nowe błędy
ten pierwszy po wykasowaniu powraca
---------- Post dopisany 02-04-2014 at 08:12 ---------- Poprzedni post napisany 01-04-2014 at 15:16 ----------
nikt nie ma pomysłów
najprawdopodobniej padł przepływomierz polecacie zamiennik z aso czy uzywke z alledro
przeczyściłem go czyściwem do hamulcy ale pomogło na chwile
nie było pytania dzwoniłem do aso cena kosmos
---------- Post dopisany 17-04-2014 at 00:21 ---------- Poprzedni post napisany 02-04-2014 at 08:12 ----------
po wymianie przepływomierza daje sie jezdzić (auto nie gaśnie)
ale 1120 powraca
czy może być przepchane sitko w napinaczu łańcuszka i to może być powodem
silnik pracuje prawie równo z lekką kulawką
-wymienione cewki
-przepływomierz
-świece
-czyszczona przepustnica (adoptowana Vag)
może wina tkwi w napinaczu mógł sie przepchać czy nie ???
ogólnie auto jeździ spoko ale te kulawki na wolnych i ten błąd
1120 powraca.
