Jacksonaia Opublikowano 24 Maja 2014 Opublikowano 24 Maja 2014 Witam. Przeskanowałem dzisiaj mojego avanta VAG-COMEM 311 i wyskoczyło mi kilka błędów, zastanawiam sie czy to może być problem z ECU ?? podaje niżej skany : VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 4D0 907 551 G Component: 2.8L V6/5V MOTR AT D01 Coding: 04251 Shop #: WSC 06325 1 Fault Found: 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent Readiness: N/A Address 02 ------------------------------------------------------- Controller: 8D0 927 156 BE Component: AG5 01V 2.8l5V RdW 7803 Coding: 00000 Shop #: WSC 00000 4 Faults Found: 65535 - Internal Control Module Memory Error 00-10 - - - Intermittent 01196 - Engine-Transmission Data Bus 27-10 - Implausible Signal - Intermittent 01044 - Control Module Incorrectly Coded 35-10 - - - Intermittent 00526 - Brake Light Switch-F 27-00 - Implausible Signal Address 03 ------------------------------------------------------- Controller: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D00 Coding: 0273004284 Shop #: BB 24334 No fault code found. Address 08 ------------------------------------------------------- Controller: ö8L 082 004 Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 034 F Component: B5-KOMBIINSTRUMENT__D12 Coding: 00062 Shop #: WSC 00186 No fault code found. Address 25 ------------------------------------------------------- Controller: 4A0 953 234 F Component: IMMO AUZ9Z0V5202014 D77 Coding: 00000 Shop #: WSC 00000 No fault code found. Address 35 ------------------------------------------------------- Controller: 8LO 862 257 D Component: ZV-Pumpe, Funk D03 Coding: 08768 Shop #: WSC 65535 8 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - End ------------------------------------------------------- Wydaje mi się, że są to objawy padniętego ECU... co o tym sądzicie ?? dodam, że audi na małych obrotach lubi szarpać... Z góry dziekuje za pomoc
radi Opublikowano 24 Maja 2014 Opublikowano 24 Maja 2014 Naladuj akumulator bo wiedze ze masz chyba slaby i wykasuj bledy i zobacz co zostanie
