Okresowy log
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01,02,03,08,09,0F,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01 -------------------------------------------------------
Controller: 8E0 909 518 AA
Component: 1.8L R4/5VT 0004
Coding: 0011701
Shop #: WSC 63351
2 Faults Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 002 - Lower Limit Exceeded - Intermittent
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1729
Coding: 04475
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 03100
Shop #: WSC 00186
WAUZZZ8Exxxxxxxxxxx AUZ6Z0C0003024
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1211
Coding: 06986
Shop #: WSC 63351
3 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
Address 56 -------------------------------------------------------
Controller: 8E0 035 186 J
Component: concert II GRO 0008
Coding: 01001
Shop #: WSC 63351
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
End -------------------------------------------------------
W czym problem: Ogólnie brak problemów, log daje kontrolnie bo auto jeździło 2 miesiące od ostatniej kasacji błędów - po prostu nie wiem co może mnie czekać, stąd prośba o wyjaśnienie kodów błędów(głównie silnika)
inne błędy - potencjalne przyczyny:
ALARM -> wymiana baterii w kluczyku, na zamkniętym centralnym od kierowcy otworzyłem auto - zaczął pikać i nie znalazł kluczyka, dobrze że miałem drugi (w domu), stąd możliwy błąd alarmu...
RADIO -> sądzę że to wina moich nowych żaróweczek do tablicy rejestracyjnej... Kupiłem diody cree ze stabilizatorem napięcia... niestety sieją w instalacji, radio na granicznych(słabym zasięgu) stacjach po prostu charczy... wróciłem do zwykłych żarówek, problemu już nie ma. Radio jak grało tak gra nadal.
przyjrzyj się na 17698
czy po wykasowaniu powrócił - bo to któryś czujnik temperatury. i może chlać paliwa jak bzdurą temp ma
Co masz dokładnie na myśli, bo nie bardzo wiem...
Edit//// Dobra już wiem o co chodzi:
http://a4-klub.pl/index.php?/topic/249058-blad-17698-problem-z-czujnikiem-g83/
Jak wrócę do domu to sprawdzę logi i czujnik w jakim stanie jest
Nie wiem, dziś sprawdzę wieczorem, bo dopiero dziś samochód używany(2x 25km) więc jak coś będzie to może się pojawić.
Zlokalizowałem czujnik, ciężko było wyjąc wtyczkę, ale się udało, w środku suchutko, przeczyściłem styki papierem ściernym. Po złożeniu zrobiłem loga z AutoScan i wyszedł czysty, zero błędów.
Ale z tym pierwszym błędem odnośnie paliwa to będzie na 99% wada przepływki, już wcześniej zaniżała wskazania bo na logach dynamicznych to wyszło, tylko nie mam czasu się za nią zabrać.. ;/
Edytowane przez ExeQtoR
