Witam liczne bledy sterownikow
Sunday,07,February,2016,15:58:14:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 227700km/141486miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 5781
Coding: 00002
Shop #: WSC 63251
VCID: 6AD1DC711664C89
WAUZZZ8E84A175921 AUZ6Z0C0423517
3 Faults Found:
18107 - Powertrain Data Bus
P1699 - 35-00 - Missing Message from Steering Wheel Electronics
18058 - Powertrain Data Bus
P1650 - 35-00 - Missing Message from Instrument Cluster
18043 - Powertrain Data Bus
P1635 - 35-00 - Missing Message from A/C Controller
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 06435
VCID: E5CB2F4D7F7A671
4 Faults Found:
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
18258 - Powertrain Data Bus
P1850 - 35-10 - Missing Message from ECU - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63251
VCID: 60C5BE59E058829
3 Faults Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
00474 - Control Module for Immobilizer
27-10 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 00000
VCID: 356B3F0D0F5A571
2 Faults Found:
79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251 000 00000
VCID: 3E7920216A6C949
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02042
Shop #: WSC 00000
VCID: 3E7920213A6C949
2 Faults Found:
01304 - Radio
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 T
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00101
Shop #: WSC 00000
VCID: 387536391848AA9
Component: A175921 AUZ6Z0C0423517
,,,,,A175921 AUZ6Z0C0423517
1 Fault Found:
01314 - Engine Control Module
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AS
Component: Komfortgerát T01 1210
Coding: 06976
Shop #: WSC 63251
VCID: 820114D18E14B09
Subsystem 1 - Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0004
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0004
2 Faults Found:
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
Dodam ze licznik nie dziala kontrolki swieca obrotomiesz nie dziala i inne wskazniki
Edytowane przez mirek72
Naładuj aku i usuń błędy. Zobacz, czy któreś wrócą. Jak aku pada i sterowniki zbyt niskie napięcie to Ci wszystko pokaże, że masz do wymiany.
Witam odpialem aku i wszystko dziala
Dzieki za pomoc
Ale błędy i tak zostały.
Musisz na dobrze naładowanym akumulatorze usunąć błędy. Potem krótka jazda próbna (z 10 km) i zobacz czy się coś pojawiło znowu.
Witam aku naladowany bledy skasowanie i pomoglo .Wielkie dzieki za pomoc
No i super :) Bezawaryjności.
