Prośba o weryfikację kodów błędów A4 B6 Avant 2004r
VCDS-Lite Version: Release 1.2
Sunday, 14 February 2016, 22:04:33:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 AA
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63251
VCID: 60B32383F35B
11 Faults Found:
00797 - Sunlight Photo Sensor (G107)
31-00 - Open or Short to Ground
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
09-00 - Adaptation Limit Surpassed
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
30-00 - Open or Short to Plus
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-00 - Blocked or No Voltage
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
00538 - Reference Voltage
29-00 - Short to Ground
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00011
Shop #: WSC 63251
VCID: 351DA2D71C59
1 Fault Found:
01498 - Bulb for Parking Lamps; Right (M3)
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251
VCID: 3E0FBDFB296F
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1412
Coding: 07018
Shop #: WSC 00110
VCID: 73995CCF52AD
2 Faults Found:
01616 - Signal Wire to Interior Monitor
49-00 - No Communications
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Edytowane przez Boruc1331
a co sie dzieje? coś nie działa? próbowałeś kasować te usterki?
AIR BAG usunąłem, reszty nie wiem od czego są, napewno klapy mi się pieprzą od nawiewu...
a próbowałeś ustawień podstawowych?
możesz rozjaśnić co masz na myśli?
Nastawy podstawowe
08 Klima - 04 basic settings - Blok 001 - zaczekaj aż wszystkie wartości zejdą do zera
i ewentualnie potem:
08 Klima - 10 Adaptacja - Chanel 00 [Test] > [save] - (czyli przywróć ustawienia fabryczne)
  • 2 lata później...
i jak temat tej klimatyzacji ?  bo mam prawie że ideantyczne błedy coś wyszło ?
