pakotomasz Opublikowano 17 Stycznia 2017 Opublikowano 17 Stycznia 2017 Witam kolegów Dziś podpiąłem kompa pod kumpla Audi A3 8L w celu sprawdzenia tylko błędów. Wyskoczyło trochę tego w 2 blokach: Chassis Type: 8L - Audi A3/S3 Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76 VIN: WAUHF78P48A132452 Mileage: 68690km/42681miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 8P0 907 115 P HW: 8P0 907 115 B Component: 2.0l R4/4V TFSI 0010 Revision: 5BH16--- Serial number: AUX7Z0H0FN2006 Coding: 0103010A18070160 Shop #: WSC 06314 000 00000 VCID: 3F8947CF15BD 6 Faults Found: 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - Upper Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 2 Fault Frequency: 4 Mileage: 68258 km Time Indication: 0 Date: 2017.01.10 Time: 15:03:04 Freeze Frame: RPM: 973 /min Load: 57.6 % Speed: 0.0 km/h Temperature: 3.0°C Temperature: 4.0°C Absolute Pres.: 970.0 mbar Voltage: 14.351 V 000769 - Cylinder 1: Misfire Detected P0301 - 001 - Upper Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 2 Fault Frequency: 4 Mileage: 68258 km Time Indication: 0 Date: 2017.01.10 Time: 15:03:46 Freeze Frame: RPM: 1142 /min Load: 41.2 % Speed: 0.0 km/h Temperature: 3.0°C Temperature: 4.0°C Absolute Pres.: 970.0 mbar Voltage: 14.224 V 000772 - Cylinder 4: Misfire Detected P0304 - 001 - Upper Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 2 Fault Frequency: 3 Mileage: 68360 km Time Indication: 0 Date: 2017.01.12 Time: 15:35:06 Freeze Frame: RPM: 1142 /min Load: 41.2 % Speed: 0.0 km/h Temperature: 3.0°C Temperature: 4.0°C Absolute Pres.: 970.0 mbar Voltage: 14.224 V 005634 - Power Supply Terminal 30: Voltage too Low P1602 - 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: -40.0°C Temperature: -40.0°C Absolute Pres.: 0.0 mbar Voltage: 0.000 V 008518 - Supply Voltage for Fuel Injector Group A: Open Circuit P2146 - 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Mileage: 68381 km Time Indication: 0 Date: 2017.01.13 Time: 00:04:01 Freeze Frame: RPM: 1199 /min Load: 29.0 % Speed: 0.0 km/h Temperature: 27.0°C Temperature: 25.0°C Absolute Pres.: 960.0 mbar Voltage: 11.557 V 008518 - Supply Voltage for Fuel Injector Group A: Open Circuit P2146 - 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Mileage: 68381 km Time Indication: 0 Date: 2017.01.13 Time: 00:04:01 Freeze Frame: RPM: 697 /min Load: 37.6 % Speed: 0.0 km/h Temperature: 27.0°C Temperature: 25.0°C Absolute Pres.: 960.0 mbar Voltage: 10.668 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG Component: KlimavollautomatH19 0430 Revision: 233871 Serial number: 8P0820043AG Shop #: WSC 00000 000 00000 VCID: 71EDD1F71369 2 Faults Found: 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 133 Mileage: 67070 km Time Indication: 0 Date: 2016.12.01 Time: 18:25:46 Freeze Frame: Temperature: -50.0°C 01592 - Air Quality Sensor (G238) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 133 Mileage: 67244 km Time Indication: 0 Date: 2016.12.09 Time: 14:06:08 Freeze Frame: Temperature: -50.0°C Możecie pomóz i podpowiedzieć co one mogą oznaczać? Jeśli chodzi o jazdę samochodem to praktycznie nic nie czuć, żeby się działo. Samochód jeździ, rozpędza się tak jak należy. Jedynie co to na wskaźnikach świeci się "Check engine: i "EPC". Skasowałem wszystkie błędy, te 2 komunikaty na desce zniknęły jednak po kilkunastu km znowu się pojawiły.
zwonko Opublikowano 19 Stycznia 2017 Opublikowano 19 Stycznia 2017 Od tego zacznij:http://wiki.ross-tech.com/wiki/index.php/18010/P1602/005634 bo problemy z zasilaniem mogą powodować to:http://wiki.ross-tech.com/wiki/index.php/P2146/008518 a problemy z zasilaniem wtrysków pewnie robią missfire
