1.9 TDI AWX - Weryfikacja błędów VAG
Proszę o weryfikację błędów:
VCDS Version: Beta 11.2.0
Data version: 20110305
Friday,17,March,2017,16:11:35:10074
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
          69 75 76 77
 VIN: WAUZZZ8E53A198054   Mileage: 361380km/224551miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 JQ
   Component: 1,9l R4 EDC G000SG  1570
   Coding: 00002
   Shop #: WSC 05311
   VCID: 6FE9D78F055D
   WAUZZZ8E53A198054     AUZ6Z0B0277973
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       1726
   Coding: 04255
   Shop #: WSC 05311
   VCID: E5C535A757A1
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            35-10 -  -  - Intermittent
00778 - Steering Angle Sensor (G85)
            37-10 - Faulty - Intermittent
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 H
   Component:   A4 Klimaautomat   1116
   Coding: 00000
   Shop #: WSC 05311
   VCID: 2647F2ABEA27
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            79-00 - Please Check Fault Codes
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 C
   Component: int. Lastmodul  RDW 0203
   Coding: 00001
   Shop #: WSC 05311
   VCID: 326F1EFBD6EF
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        2000
   Coding: 0010602
   Shop #: WSC 63351 000 00000
   VCID: 366722EB3A87
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 00042
   Shop #: WSC 05311
   VCID: 3E773ACB12B7
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 900 K
   Component: KOMBI+WEGFAHRS. RB4 D35
   Coding: 00100
   Shop #: WSC 05311
   VCID: 2C530083F4CB
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
            30-00 - Open or Short to Plus
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   Shop #: WSC 00000
   VCID: EBD1439FB145
Address 46: Central Conv.        Labels: 8E0-959-433-MIN.lbl
   Part No: 8E0 959 433 BD
   Component: Komfortgerát TBF    1310
   Coding: 08026
   Shop #: WSC 05311
   VCID: 74E3D8E36C7B
   Subsystem 1 - Part No: 8E1959801B
   Component: Tőrsteuer.FS BRM 0002
   Subsystem 2 - Part No: 8E1959802B
   Component: Tőrsteuer.BF BRM 0002
12 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
            37-00 - Faulty
01320 - Control Module for Climatronic (J255)
            49-10 - No Communications - Intermittent
01369 - Alarm triggered by Hood Switch
            35-00 -  -
01374 - Alarm triggered by Terminal 15
            35-00 -  -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -  -
01561 - Left Rear Door
            59-10 - Can't Unlock - Intermittent
            61-00 - Won't De-Safe
01562 - Right Rear Door
            59-00 - Can't Unlock
00956 - Key 2
01559 - Drivers Door
            61-10 - Won't De-Safe - Intermittent
01802 - Door Warning Lamp; Pass Side (W36)
            57-00 - Electric Circuit Failure
---------------------------------------------------------------------   End
Zawartość dodana 13 minutes later
Gdzie szukać przerwy w komunikacji miedzy licznikiem a klimatronikiem i modułem komfortu?
Edytowane przez wielki1980
Nikt się z takimi błędami nie spotkał?
Kolego pierw skasuj te błędy i pokaż, które zostaną po ponownym zeskanowaniu auta. Większość błędów pochodzi od odłączenia akumulatora lub jego słabej kondycji.
rób ponowny skan i wrzuć to ponownie
a tak na przyszłość to tu znajdziesz opisy błędów wraz z możliwościami ich wystąpienia:
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Edytowane przez Lukasz_mk2
