Bledy w mojej b6
Chlopaki potrzebuje waszej wiedzy aby to rozkodować
Address 01: Engine       Labels: 038-906-019-AJM.LBL
   Controller: 038 906 019 JL
   Component: 1,9l R4 EDC 0000SG  1519
   Coding: 00002
   Shop #: WSC 63351
   VCID: 6AA741AB0567
   WAUZZZ8E83A017349     AUZ6Z0B0093923
1 Fault Found:
17965 -  Charge Pressure Control: Positive Deviation
            P1557 - 35-10 -   - - Intermittent
Readiness: N/A
Address 03: ABS Brakes       Labels: 8E0-614-517.LBL
   Controller: 8E0 614 517
   Component: ABS/ESP front       1726
   Coding: 04255
   Shop #: WSC 06435
   VCID: E5BDB2976C79
No fault code found.
Address 08: Auto HVAC       Labels: 8E0-820-043.LBL
   Controller: 8E0 820 043 N
   Component:   A4 Klimaautomat   1015
   Coding: 00000
   Shop #: WSC 63351
   VCID: 2C2B87B3CF13
3 Faults Found:
01592 -  Air Quality Sensor (G238)
            37-10 -  Faulty - Intermittent
00474 -  Control Module for Immobilizer
            49-10 -  No Communications - Intermittent
            27-10 -  Implausible Signal - Intermittent
Address 09: Cent. Elect.       Labels: 8E0-907-279-8E2.LBL
   Controller: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00001
   Shop #: WSC 63351
   VCID: 341B9FD31723
1 Fault Found:
01794 -  Control Module - Incorrect Chassis (VIN) Number
            35-00 -   -
Address 15: Airbags       Labels: 8E0-959-655-84.LBL
   Controller: 8E0 959 655
   Component: Airbag 8.4E         5001
   Coding: 0011602
   Shop #: WSC 63351
   VCID: F49BDFD3D7A3
Address 16: Steering wheel       Labels: 8E0-953-549.LBL
   Controller: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 00011
   Shop #: WSC 63351
   VCID: 361FA5DB015F
3 Faults Found:
00576 -  Terminal 15
            57-10 -  Electric Circuit Failure - Intermittent
00883 -  Ignition Switch (D) Terminal S
Address 17: Instruments       Labels: 8E0-920-9xx-8E2.LBL
   Controller: 8E0 920 900 G
   Component: KOMBI+WEGFAHRS. RB4 D27
   Coding: 00000
   Shop #: WSC 11111
   VCID: 28237BA3DBEB
1 Fault Found:
01304 -  Radio
            49-00 -  No Communications
Address 46: Central Conv.       Labels: 8E0-959-433-MIN.LBL
   Controller: 8E0 959 433 AG
   Component: Komfortgerát T87    0316
   Coding: 06720
   Shop #: WSC 63351
   VCID: 769F65DB41DF
4 Faults Found:
01561 -  Left Rear Door
            59-00 -  Can't Unlock
            61-10 -  Won't De-Safe - Intermittent
01562 -  Right Rear Door
            61-00 -  Won't De-Safe
Z gory dziekuje za pomoc :)
Oprócz pierwszego błędu mówiącego o przeładowaniu turbiny ,  występuje jakiś problem z zanikiem napięcia na szynie 15( po włączeniu stacyjki ) .
Prawdopodobnie albo jest to wina kostki w stacyjce albo przekaźnika w obudowie ECU,  cała reszta błędów może wynikać właśnie z problemu zanikającego zasilania,  dla tego od sprawdzenia kostki stacyjki i przekaźnika zasilania szyny 15 bym zaczął :hi:
Wykasował bym wszystkie błędy z wszystkich sterowników , potestował auto a potem jeszcze raz sprawdził które błędy ewentualnie wracają :naughty:
Edytowane przez piotrsob1
