dawid1 Opublikowano 9 Marca 2009 Opublikowano 9 Marca 2009 VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 906 018 B Component: 1.8L R4/5VT 0004 Coding: 11501 Shop #: WSC 00257 WAUZZZ8EZ1A034619 AUZ6Z0A0005290 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front D620 Coding: 04275 Shop #: WSC 00260 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 L Component: A4 Klimaautomat 1015 Coding: 00000 Shop #: WSC 00308 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 F Component: int. Lastmodul RDW 0617 Coding: 00011 Shop #: WSC 00000 No fault code found. Address 15 ------------------------------------------------------- Controller: 8E0 959 655 Component: Airbag 8.4E 3001 Coding: 0010602 Shop #: WSC 63351 No fault code found. Address 16 ------------------------------------------------------- Controller: 8E0 953 549 M Component: Lenksáulenmodul 0209 Coding: 02041 Shop #: WSC 00260 1 Fault Found: 01044 - Control Module Incorrectly Coded 35-10 - - - Intermittent Address 17 ------------------------------------------------------- Controller: 8E0 920 930 HX Component: KOMBI+WEGFAHRS. RB4 D15 Coding: 00100 Shop #: WSC 00186 WAUZZZ8EZ1A034619 AUZ6Z0A0005290 1 Fault Found: 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent Address 37 ------------------------------------------------------- Controller: 8E0 035 192 Component: RNS 4.1 H06 BNO 0012 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AE Component: Komfortgerát T87 0315 Coding: 06720 Shop #: WSC 00260 1 Fault Found: 01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent Address 55 ------------------------------------------------------- Controller: 4B0 907 357 C Component: dynamische LWR D05 Coding: 00060 Shop #: WSC 63351 No fault code found. Address 56 ------------------------------------------------------- Controller: 8E0 035 192 Component: Radio BNO 0001 Coding: 00207 Shop #: WSC 00308 No fault code found. End -----DZIEKI
GRazny Opublikowano 9 Marca 2009 Opublikowano 9 Marca 2009 1. jeśli masz kierownicę multifunkcyjną to ktoś ją chyba kiepsko zakodował po wstawieniu... (jeśli dobrze kojarzę) 2. problem z komunikacją z czytnikiem nawigacji - błąd częsty 3. problem z zamkiem drzwi prawych tylnych - błąd częsty (opisywany na forum - czyszczenie zamka) jak już Ci gdzieś pisałem oba ostatnie błędy posiadam (jedyna różnica to taka że nie częste) i mimo wszystko drzwi działają a navi też więc tematu jeszcze nie drążyłem...
dawid1 Opublikowano 9 Marca 2009 Autor Opublikowano 9 Marca 2009 W serwisie wymieniali mi ostatnio jakis moduł przy kierownicy moze tam cos nabroili
GRazny Opublikowano 11 Marca 2009 Opublikowano 11 Marca 2009 no to ładny serwis... możesz jechać w ciemno i reklamacja z drzwiami sobie daruj dopóki jeszcze działa... jest na forum temat o tym z navi mam to samo ale nigdy nie miałem problemów więc pewnie jakieś styki można poczyścić i będzie po problemie...
dawid1 Opublikowano 11 Marca 2009 Autor Opublikowano 11 Marca 2009 ok jutro sie troche z tym pobawie zobaczymy co wyjdzie
letallec Opublikowano 11 Marca 2009 Opublikowano 11 Marca 2009 Te z grup 17 i 46 skasuj i za jakiś czas sprawdź ponownie. A ten w grupie 16 reklamuj, bo moduł jest niewłaściwie zakodowany (02041). Jak trochę poszukasz, to znajdziesz na forum opis tego kodowania
