[B5 AJM] Prośba o sprawdzenie logu Auto Scan
Witam.
Na początku muszę uprzedzić że przeszukałem pół forum w poszukiwaniu odpowiedzi, a nawet Wiki Ross-Techa zachaczyłem. Nie znalazłem nigdzie odpowiedzi co oznaczają kody błędów w moim logu. A więc:
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 BR
Component: 1,9l R4 EDC 0000SG 1064
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
19464 - Camshaft Position Sensor (G40): Signal Out of Range
P3008 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00012
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 Q
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 930
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 00040
Shop #: WSC 00000
Ident.-Nr. Wegfahrs.:AUZ5Z0Y1105363
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 12865
Shop #: WSC 06325
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 56 -------------------------------------------------------
Controller: 8D0 035 195
Component: Radio D00
Coding: 00205
Shop #: WSC 06325
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
End -------------------------------------------------------
Informacji o podświetlonych kodach nie znalazłem.
Jeśli ktoś ma pomysł to proszę pisać.
W przyszłym tygodniu podrzucę logi stat. i dynamiczne. Narazie mojemu laptopowi bateria starcza tylko na bootowanie.
Siemka, Mogę ci je jedynie przetłumaczyć :cool1:
19464 - Czujnik pozycji wałka rozrządu CMP - przekroczony górny limit > niepewny wirnik, wyrównanie.
1367 - Wyłączenie przez pompę zamka centralnego
991 - Oświetlenie wewnętrzne
65535 - Uszkodzony sterownik ECM.
Pozdrawiam.
trzeba bylo przeszukac drugie pół ... albo nie pisac takich bzdur ... :confused4:
P3008 - 35-00 - -
19464 - http://www.a4-klub.pl/smf/empty-t66278.0.html;highlight=19464
35-00 - -
01367 - http://www.a4-klub.pl/smf/empty-t28971.0.html;highlight=01367
28-00 - Short to B+
00991 - http://www.a4-klub.pl/smf/empty-t83007.0.html;highlight=00991
Dzięki Darek11 na tyle to znam angielski :)
spanky
- odnośnie 19464, sprawdzę kabelkologię i sam czujnik(tylko jak?? organoleptycznie wystarczy?), ale na forumowym FAQ nie ma tego błędu,na Wiki również. Myślę że warto dodać.
- odnośnie 01367, jeśli jest tam hydraulika to czy nie dojdzie kiedyś do takiej sytuacji że nie będę mógł się dostać do auta lub wydostać z auta? (sprawdzę, a gdzie ta pompka się znajduje?? chcę jednak zlikwidować wyciek). Też warto dodać do FAQ. Osobiście jak już się z tym uporam to postaram się o fotostory.
- odnośnie 00991, sprawdzę, a po czym można poznać o której krańcówce jest tu mowa? jest 5 możliwości...
Pompkę CZ znajdziesz w bagazniku , w schowku po prawej stronie. Jaki wyciek chcesz w niej likwidować?, jesli coś ma się w niej zepsuć to najczęściej albo elektonika albo wirnik.
Oj, słabo coś kolega uzywał tej szukajki :wink4:
no taki właśnie, o jakim pisze w Logu. Pisałem że na tyle angielski znam a tu pisze czarno na białym.
Czy miałem się czymś innym sugerować??
to jest pompka pneumatyczna i wyciek znaczy nieszczelność układu pneumatycznego, i w 90% nie jest to nieszczelność pompki tylko jakiegoś łączenia przewodu pneumatycznego (łącznika) w :
zamki drzwi
łączniki w słupku między drzwiami
koło zamka tylniej klapy
zamykanie wlewu paliwa
tam szukaj "wycieku" sprężonego powietrza :) oczuywiście też może to być wina pompki ale jak ci zamyka normalnie wszystkie zamki to raczej nie ona
Run time Exceeded - (czas "dobicia" do zadanego ciśnienia przekroczony) pompka próbowała dobić powietrze do jakiegoś ciśnienia ale ponieważ gdzieś jest nieszczelność elektronika wyłączyła ją po jakimś czasie (logiczne) bo inaczej miałbyś po akumulatorze :)
co zrobić ? przyjrzyj się wszystkim ryglom czy opadają równo przy zamykaniu i otwieraniu, jeżeli któryś z nich wolniej sie zamyka lub otwiera to na jego lini prawdopodobnie jest nieszczelność
spanky
- odnośnie 19464. Miernik elektryczny w łapki i jazda. Na 99% jest to czujnik indukcyjny który cec**je sie małą awarujnością stąd należy zacząć spr. od instalacji i kostek. Ewentualnie spr. czujnika to pomiar oporności momiedzy poszczególnymi pinami - jaki ma być trzeba by poszperać ... może w ELSA.
- odnośnie 01367. Wykasować błędy. pobawić się zamykaniem i podglądac na VAGu. Jak wraca sporadycznie lub wcale to olać temat, jeśli błąd tkwi cały czas szukać nieszczleności (poczynając od obserwacji zamykania drzwi)
- odnośnie 01367. Zastosować sie jak w linku powyżej bo to bardzo prawdopodobne
tylko pamiętaj wiele wątków jest na tym forum które zaczynają się od zrozpaczonych pytań, potem trafnych podpowiedzi co i jak zrobić, gdzie szukać i w ogóle a na końcu nikomu się już nie chce napisać czy udało się mu rozwiązać problem, czy pomogły mu podpowiedzi, czy w ogóle w dobrym kierunku go poprowadziły. Więc proszę cię :
NAPISZ JAK ROZWIĄŻESZ JUŻ SWOJE PROBLEMY JAK TO ZROBIŁEŚ - DLA NASTĘPNYCH ŻEBY SZUKAJKA MIAŁA WIĘKSZĄ WIEDZĘ
ps. a tak w ogóle to jeszcze skasuj wszystkie błędy jakie masz i pojeździj z tydzień i zobacz wtedy czy te same się pojawią
Prawda prawda ... nie duży % ludzi odzywa się po rozwiązaniu problemu by podzielić sie dokładniej swoim doświadczeniam.
