Mad_MAX Opublikowano 14 Sierpnia 2007 Opublikowano 14 Sierpnia 2007 W koncu udalo mi dorwac moje wyposazenie , dzieki KEZOR za linka A oto jak sie prezentuje : SPECS X0A national sales program Germany A8S standard equipment G0G five-speed manual transmission for four-wheel drive vehicle K8B notchback MT5 6-cyl. gasoline engine 2.4 L/121 kW V6 EU 3 (provisional solution) base engine is T7T T7T 6-cylinder gasoline engine 2.4 L unit 078.7 0DS installation differentiation for build status of vehicle class 4B0 (AUDI) 0G1 gearshift lever 1E1 activated carbon canister 1VH installation parts for six-cylinder engine 1X1 four wheel drive C02 operating permit, alteration 2 0TD front and rear floor mats 1BE sports suspension/shock absorption 2Z0 without model and capacity designation 3X1 load-through provision with ski bag 3Y2 electrically operated roll-up sun screenfor rear window 4A3 seat heater for front seats separately controlled 5K0 without paint preservative 6E3 center armrest front 9Q2 Driver Information System (DIS) 9V7 anti-theft alarm PH5 PRL right-hand drive vehicle package PX1 xenon headlights RBL radio chorus with front and rear speakers WL1 leather trim "Vienna" WM2 Sharan "Voyage II" for Belgium / Luxembourg with RHA color C1L cast alloy wheels 7J x 16 five-arm style, offset 45 H6U tires 205/55 R 16 91W N1H leather seat covering 1MR four-spoke leather-covered steering wheel 1PC wheel bolts with anti-theft protection (unlockable) 2A4 delivery equipment for shipment (transitcoating) with thick seat cover 5MB decorative aluminum inserts "stars titanium" 6Q2 leather gearshift knob/handle 6R2 leather gearshift boot 8GL alternator 120A 8JG headlight with gas discharge lamp for driving on the right 8Q2 automatic headlight-range adjustment static 8UC radio chorus 8X1 headlight washer system 9AK automatic air conditioning with sun sensor 9VD front and rear speakers B0A component parts set without country-specific design requirement B99 type approval EC E0A no special edition FA0 control of standard production F0A no special purpose vehicle, standard equipment J0L battery 340 A (70 Ah) L0L LHD vehicle Q1A standard seats U1C instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.) 0JH weight category front axle weight range 8 0LW special plates/stickers/ safety certificates for Germany 0ST labels/plates in German and French 0VC German owner's manual 0YP weight category rear axle weight range 13 1AH electronic differential lock (EDL) 1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C 1D0 without towing attachment 1EX VIN plate 1G3 alloy spare wheel with original equipment tires 1KD disc brakes, rear 1LB yellow front brake calipers 1N1 power steering 1SA without additional engine guard 1T3 first aid kit and warning triangle 1WB transmission shaft w/ 100mm in diameter 1YC transmission shafts for rear axle diameter 100 1Z2 increase in initial standard fuel filling 2B0 without additional exterior noise suppression 2G1 insert for the filling up of unleaded fuel 2K1 reinforced bumpers 2WA without additional tires 3B0 without additional child seat anchor 3CA without partition 3C7 3-point seat belt for center rear seat 3FA without roof insert (standard roof) 3NZ rear seat bench unsplit, backrest split folding 3PF electric height adjustment for both front seats 3Q6 three rear headrests 3S0 without roof rails/roof load rack 3V0 without child bench seat 4GH windshield tinted with windshield sunshield 4KC side and rear windows tinted 4K1 radio remote controlled central locking 4L2 dipping breakaway inside rear view mirror 4M0 without cup holder 4UE airbag f. driver a. front seat passenger 4W0 without cassette and CD storage unit 4X1 side airbag front 5A5 trunk lining, with stowage trays 5C0 without special body measures 5D1 Remote control and central locking system 5E2 sill top with door cover 5RQ outer right rear view mirror: convex 5SL left wing mirror: non spherical 6M1 tie down straps 6N0 without mud flaps 6U1 additional dust seal outside 6V1 rear trim panel (ECE) 6W5 front license plate bracket 6XD outer rear view mirrors: powered, heated 7A0 without CD changer/CD player 7CA without label for radio remote control 7E0 w/o heat accumulator/auxiliary heating 7M1 scuff plates in door apertures with metal inserts 7P0 without lumbar support in front and rear seats 7QA without CD ROM 7Q0 without navigation device 7X0 without park distance control 8CC speedometer sensor without seal (electronic speedometer sensor) 8KA w/o catalytic converter warning light 8K0 without special low beam mode 8TC rear fog light for driving on the right 8T0 without cruise control system (CCS) 8Z5 engine cooling system, type 1 9B0 without telepay device 9M0 without auxiliary/parking heater 9P0 without seat belt warning light 9W0 w/o car phone preparation/installation Jak byscie wypatrzyli jakies rodzynki o ktorych nie wiem to bylbym wdzieczny. Zawsze myslalem ze mam BOSE naglosnienie i sie pomylilem Kurde ale 10 glosnikow , sub i wzmacniacz siedza w srodku. To jaka jest roznica pomiedzy moim a BOSE ??
Flyer Opublikowano 14 Sierpnia 2007 Opublikowano 14 Sierpnia 2007 BOSE to instalacja + glosniki od markowej firmy... Masz albo seryjne naglosnienie, albo ktos sobie dolozyl BOSE we wlasnym zakresie - czemu sadziles, ze masz BOSE? Masz blendy na glosnikach z logo BOSE? Zagladales do samych glosnikow?
Mad_MAX Opublikowano 14 Sierpnia 2007 Autor Opublikowano 14 Sierpnia 2007 Nie mam na maskownicach logo Bose, poprzedni wlasciciel mi powiedzial ze to BOSE , to skad moglem przypuszczac ze nie jak sie na tym nie znalem . Kurde ale calkiem dobrze mi graja te glosniki A skad dorwac caly zestaw BOSE ?? Duzo lepiej to bedzie giercyc??
letallec Opublikowano 14 Sierpnia 2007 Opublikowano 14 Sierpnia 2007 W opowiadaniach poprzednich wlascicieli kryje sie wiele nieznanego wyposazenia. A pozniej to nie wiadomo, czy ktos montowal, a moze wymontowal... U Ciebie moze ktos zdjal blendy, bo sie podobaly. I zalozyl na zwykly zestaw, zeby sprzedac drozej. Oto Polska wlasnie...
Flyer Opublikowano 14 Sierpnia 2007 Opublikowano 14 Sierpnia 2007 Jesli nie jestes audiofilem to odpusc sobie BOSE. Dosc kosztowna operacja, a watpie zeby przyszly wlasciciel Ci za to doplacil...
Mad_MAX Opublikowano 14 Sierpnia 2007 Autor Opublikowano 14 Sierpnia 2007 Nie raczej nie jestem audiofilem , mysle ze moj zestaw gra calkiem dobrze Chociaz brakuje mi troche basu. OK wrocmy do wyposazenia , jak by ktos cos wypatrzyl to napiszcie
Gość Keżor Opublikowano 14 Sierpnia 2007 Opublikowano 14 Sierpnia 2007 6N0 without mud flaps wypatrzyłem
rex Opublikowano 14 Sierpnia 2007 Opublikowano 14 Sierpnia 2007 6N0 without mud flaps wypatrzyłem Tego to akurat zazdroszcze, bo mi się ich ściągać nie chce :D
Mad_MAX Opublikowano 14 Sierpnia 2007 Autor Opublikowano 14 Sierpnia 2007 A8S standard equipment pffff Ze niby co?? wyposazenie standardowe?? Pffff chcialbym zeby ktos w 98 uznal to za standard hehehehee. Calkiem pokazny jak na tamten rok [br]Dopisany: 14 Sierpień 2007, 14:53 _________________________________________________Natomiast interesuje mnie kilka kodow: 1E1 activated carbon canister 1BE sports suspension/shock absorption 5K0 without paint preservative 8JG headlight with gas discharge lamp for driving on the right 1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C 4M0 without cup holder co to oznacza??
Flyer Opublikowano 14 Sierpnia 2007 Opublikowano 14 Sierpnia 2007 1BE obnizone sportowe zawieszenie (o ile sie nie myle to -30mm) 8JG oswietlenie dla ruchu prawostronnego
rex Opublikowano 14 Sierpnia 2007 Opublikowano 14 Sierpnia 2007 4M0 without cup holder Bez uchwytu na napoje. 1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C Antyzamarzacz (nie wiem czego sie tyczy) do -25 stopni, tolerancja do - 30. 5K0 without paint preservative Bez środka konswerwującego lakier. 1E1 activated carbon canister Posiada kanister węglowy.
schiller Opublikowano 14 Sierpnia 2007 Opublikowano 14 Sierpnia 2007 1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C Antyzamarzacz (nie wiem czego sie tyczy) do -25 stopni, tolerancja do - 30. typuje na podgrzewane zamki...
